Tire options for 17" wheels?
Discussion in '4th Gen 4Runners (2003-2009)' started by Gaberocks52, Jan 27, 2018.
  1. Jan 27, 2018 at 5:06 PM
    Gaberocks52
    Gaberocks52 [OP] New Member
    Gabe
    06 4runner
    3” lift/level
    Hey all, new to the site (Love it so far) I have an 06 SR5 2WD with 72k and a 3” lift/level and wheel spacers. I wanted to keep my stock wheels because I like the stock look and I wanted to get bigger tires for it so it looked good with the truck. What are the tire options for the 17” stock wheels? Thanks for the input!
  2. Jan 31, 2018 at 1:38 PM
    mrseth
    mrseth New Member
    Seth
    2004 Limited v8
    3" Rancho, 2.5" Delrin BL, 1.5" Supreme Spacer Lift, 35" Cooper MTP, Chopped Fenders, Racing buckets, 1.5" Spidertrax
    Simply:
    Lots of road driving? Light offroading?
    BFG AT/KO2: 31x17 or 32x17
    PROS: Quiet on the highway
    Incredible Sidewalls
    Functional siping
    Harder compound, wear slowly
    CONS:Hard in the winter, not a lot of good traction
    Price is a little steep- but you are paying for quality
    Cooper Tire STT Pro: 31x17 or 32x17
    PROS: Quiet on the highways
    Average sidewall
    Aggressive siping
    Good bead
    CONS:Softer compound, faster wear
    Sidewall will be penetrated by relatively sharp rocks when around 2.5-10PSI
    Again, $$$
    Michelin LTX AT: 33x17
    PROS: Readily available
    Cost efficient
    Extremely Quiet
    Good tread wear
    CONS: Harder rubber compound, can be slippery in winter
    Cannot air down as much, decent sidewall, but I never trusted them.
    Not as an aggressive look as the others
    Road Driving, Moderate to Heavy Offroad Use
    BFG MT KM2: 31x17 32x17
    PROS: Aggressive tread and siping
    Even tread wear
    Strong bead
    Can run low PSI, strong sidewall
    After driving 75mph for 50 miles, tire temps were average
    CONS:They sing the song of my people on the highway.
    Still moderately hard rubber compound, but can be good with the lugs in snow
    With your lift/level, be cautious with tire size as you may need to trim a little
    Cooper Tire MTP Pro: 31x17 32x17
    PROS: Aggressive tread and incredible siping
    Good tread wear
    Decent Sidewall
    Can run low PSI without concern
    CONS:They hum. Bad.
    They are a softer compound, and wear a little faster than most
    If your alignment is off, you will see it on your treadwear within 1k miles
    Kelley Safari TSR: 31x17 32x17
    PROS: Pricing, pricing, pricing
    Even treadwear
    Good sidewall
    Aggressive tread pattern and decent siping similar to Goodyear
    CONS: Soft compound
    Noticed sidewall weathering and cracking early on (8 months)
    Lost the bead lock more often than not at low PSI
    Goodyear Wrangler Duratrac: 31x17
    PROS: Name Brand, everyone loves them
    Kevlar reinforced sidewalls
    Good wear
    Relatively Quiet
    Medium/Hard Compound
    CONS: $$$
    No sidewall punctures, but have lost the bead at low PSI
    Hope that helps a little. In the end, there are HUNDREDS of manufacturers out there. These are just a few either I have run on my vehicle, or on client vehicles I have built.
    Have a good one!
    rsimi72, Bob and brochacho like this.
  3. Jan 31, 2018 at 8:44 PM
    Gaberocks52
    Gabe
    06 4runner
    3” lift/level
    Thanks for the help! I’d probably do light-moderate off-roading, I want a tire that will fill in the wheel well and look nice with the lift. Also open to getting new wheels but would prefer stock
  4. Feb 1, 2018 at 8:21 AM
    brochacho
    brochacho New Member
    2018 Sequoia TRD Sport
    Love my Nitto Ridge Grapplers. Aggressive looking all terrain and very quiet on the road.
    Also check out:
    Toyo AT2
    Falken AT3W
  5. Feb 2, 2018 at 2:23 PM
    Roccoeight
    Roccoeight New Member
    2016 Trail
