Tire balancing issues!!!
Discussion in '5th Gen 4Runners (2010-2024)' started by Sean M., Mar 5, 2025.
  1. Mar 5, 2025 at 11:08 PM
    I’ve been told by where I buy my tires that KO2’s are really hard to get balanced.
    Sean M.[OP] likes this.
  2. Mar 6, 2025 at 3:52 AM
    maybe that’s part of the problem
  3. Mar 6, 2025 at 5:00 AM
    Sean M.
    Sean M. [OP] New Member
    Sean
    2024 ORP
    Rock rails
    Thanks, I appreciate the link. I will make sure to ask them to document the run-out numbers, in case any need replacement.
    TrailSpecial22 and nimby[QUOTED] like this.
  4. Mar 6, 2025 at 5:01 AM
    Sean M.
    Sean
    2024 ORP
    Rock rails
    Thanks, yeah. I already took it back to Toyota once so going elsewhere. They also tried to say it was just how it was and then later said they had to rebalance all 4 tires
  5. Mar 6, 2025 at 5:04 AM
    Sean M.
    Sean
    2024 ORP
    Rock rails
    Yeah, I am definitely not going back to Toyota, except to request a refund when I can prove another shop did it correctly.
  6. Mar 6, 2025 at 5:04 AM
    Sean M.
    Sean
    2024 ORP
    Rock rails
    I did not
  7. Mar 6, 2025 at 11:17 AM
    BoiseG
    BoiseG New Member
    2024 ORP
    They came out with a new version, the KO3. It supposedly does better in wet conditions. I've had multiple sets of KO2s, and now the KO3, they both are difficult to balance, but they're excellent tires, which is why they're so popular.
  8. Mar 6, 2025 at 11:46 AM
    Sean M.
    Sean
    2024 ORP
    Rock rails
    Yeah, I have heard good things about the KO3's too
  9. Mar 6, 2025 at 12:23 PM
    It may be that the dealership you got those tires from were trying to get rid of old inventory. I second the motion to check the mfg. date on the tire sidewall.
  10. Mar 6, 2025 at 1:25 PM
    Sean M.
    Sean
    2024 ORP
    Rock rails
    Yeah, looks like I will have to check that out when I get off of work today. Appreciate it.
    Thatbassguy and TrailSpecial22 like this.
  11. Mar 6, 2025 at 3:40 PM
    Cajunchuck
    Cajunchuck New Member
    Arkansas, USA
    2023 TRD ORP
    BFG KO2, stock size RCI 20 degree sliders RCI engine/trans skids
    I bought my KO2s (stock size) at DT. Now have almost 15k miles on 'em and they still ride smooth as glass. All the way up to 90 mph. Find a different shop lol.
  12. Mar 6, 2025 at 6:39 PM
    RUNNER4DAN
    Daniel
    Doesn't need any
    My son worked at a tire shop and runs KO2s on his Taco. He knows how go properly balance tires and has never had a problem
    They have up to date tire balancing .equipment but nothing out of the ordinary.
  13. Mar 6, 2025 at 8:23 PM
    Great, then all the KO2 owners should pay him a visit. ;)
  14. Mar 6, 2025 at 11:37 PM
    andrewtheadventurer
    Ko2s are old. Try ko3s. 5g 4r are picky with balancing
    Sean M.[QUOTED][OP] likes this.
  15. Mar 7, 2025 at 3:49 AM
    RUNNER4DAN
    Daniel
    Doesn't need any
    At least find someone competent with a tire balance machine.
  16. Mar 7, 2025 at 5:41 AM
    Sean M.
    Sean
    2024 ORP
    Rock rails
    i took the advice of a couple people on here and checked the manufacture date of the tires. I thought the first 2 digits were the week and the last 2 digits were the year but that cant be right with these lol. 20250307_070306.jpg
  17. Mar 7, 2025 at 7:36 AM
    7Runner
    7Runner Forum Loiterer
    2018 Silver SR5P
    Check the other side of the tire. Should be an additional date code.
    The code you're looking at could be the manufacturing plant/DOT code.
  18. Mar 7, 2025 at 7:52 AM
    Sean M.
    Sean
    2024 ORP
    Rock rails
    Thanks, I will have to check later when home.
    7Runner[QUOTED] likes this.
  19. Mar 7, 2025 at 8:11 AM
    #49
    thats why I like Falkens. Never any balancing issues, knock on wood.
  20. Mar 7, 2025 at 8:15 AM
    #50
    thats the date stamp for sure. Wow, gave you almost 4 year old tires
  21. Mar 7, 2025 at 8:38 AM
    #51
    Not everyone is lucky. I think most cases its not about tires, its about the shop. :)
    When shop is unable to balance you see Falken issues on forums of 4Runner, Tacoma, Tundra, FJ, Land cruiser, Ford, GM, Subaru etc..
  22. Mar 7, 2025 at 9:36 AM
    #52
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    E or C load?
  23. Mar 7, 2025 at 9:49 AM
    #53
    true about being a shop issue as opposed to a tire
  24. Mar 7, 2025 at 10:10 AM
    #54
    AR1978
    AR1978 New Member
    2015 4Runner Trail Premium
    I can't speak to these tires, but after doing research online I did the road force balance at Discount Tire and it solved about 95% of my steering wheel vibration issue.
  25. Mar 7, 2025 at 11:26 AM
    #55
    andrewtheadventurer
    Ive had 3 sets of falkens. All three have had a tire or two replaced due to high road force and shake at 50-60mph. Its par for the course with t4r, lifts, tires
  26. Mar 7, 2025 at 2:40 PM
    #56
    Gumpus
    Gumpus New Member
    I agree that it's key to ask for the numbers. The numbers are Road Force Variation, called R1H. Simple concept, the tire sidewall stiffness is not exactly the same at every point on the tire and if the variation is excessive it feels just like imbalance. The Hunter machine mounts the tire/wheel assembly and presses it against a small metal cylinder that can measure the force so by turning the tire/wheel they get the variation in force around the whole tire. 20 is a good bogey, as I recall 18 pounds was a spec I've seen. If your tires have excessive R1H a "road force balance" may help but may not eliminate vibration.
    Sean M.[QUOTED][OP] and nimby like this.
  27. Mar 7, 2025 at 4:19 PM
    #57
    i got lucky with mine. No issues on the 07,11 or 22 with AT3s
  28. Mar 8, 2025 at 4:47 AM
    #58
    Matt83
    Matt83 New Member
    Northeast
    I had KO2s warrantied because they could not be balanced by 4x4 shops, Toyota Dealers, etc.
    In my time owning Toyota trucks with 6 lug wheels the only shop that was able to get tires perfect for me was Sullivan who are only in the Northeast I believe.
    They used a finger plate adapter to secure the wheel to the road force machine versus securing via a cone. So last two sets of Michelins on my Tacoma and 4Runner were done with the finger plate adapter and both have been perfect. I chased the balancing devil on the 4Runner for some time, Toyota dealers did not even know what the finger plate adapter was. Whatever the factors may be, some 4Runners are super sensitive to balance but a dealer or tire shop who states that its a characteristic of the truck/tires is just coming up with excuses.
    nimby and Sean M.[OP] like this.
  29. Mar 8, 2025 at 4:53 AM
    #59
    Mine always balanced fine, when they were balanced at a good shop.
    This
    A friend returned a set of AT3's to Discount tire for balancing issues. To be fair, it could have been the shop. But, I think that's generally the case with KO2's as well.
  30. Mar 8, 2025 at 10:53 AM
    #60
    CA4runner
    CA4runner New Member
    Nor Cal
    2019SR5
    6112s, TRD F2 wheels
    This is the only way..
    nimby[QUOTED] and Sean M.[OP] like this.
