TIMING BELT ADVICE
Discussion in '4th Gen 4Runners (2003-2009)' started by yoho360, Mar 11, 2022.
  1. Mar 11, 2022 at 7:26 AM
    yoho360
    yoho360 [OP] New Member
    Chris
    2004 4Runner SR5 V8
    none
    Good Morning! I have a 2004 SR5 V8. It has 248k miles. I bought it at 220k and haven't had any engine issues outside of misfires which were easily fixed by new plugs. However, I can't find record of when the last time the timing belt was addressed. Since it's running smoothly it isn't a major concern but I also would like to stay ahead of it since the mileage is high. Should I get it looked at?
  2. Mar 11, 2022 at 8:23 AM
    I would, at least, remove one of the covers and inspect the belt. These are interference motors.
    My original belt ('03, V8) was replaced somewhere around 240K, and it was in pretty rough shape.
    This is how it looked.
    yoho360[OP], negusm and 2Toys like this.
  3. Mar 11, 2022 at 8:24 AM
    importman
    importman The mountains are calling and I must go...
    Danny
    Carolinas
    05 Silver SR5 V6 4X4
    Blacked out, Ironman 3" Nitro Gas Suspension lift, JBA High Caster upper control arms, Differential drop and sway bar relocate, Upgraded to Sport Front Cardone Calipers with Brembo Rotors and Akebono Pads, Added Spoiler, Sony XAV-AX100 with Apple Carplay, USB Jack, Backup Camera, Black TRD Pro Wheels with General Grabber ATX 265/70/17, Rear differential vent extension, Auto Dimming Mirror with Compass and Homelink, Map Light Mod, Tekonsha 90160 Trailer Brake Controller, Recoil SL1708 Sub, Sealight LED Headlamps, K&N drop in air filter, Weathertech floor mats, Homemade rear storage compartment with built in pull out table.
    If I were you and didn't know exactly when it was last changed I'd do it immediately. If it breaks it WILL cause major engine damage, (bent valves, possibly damaged pistons). It's not worth taking a chance.
  4. Mar 11, 2022 at 11:38 AM
    You already know the answer. If you don't know the history, it's time to change it. Belts are cheap, engines are not.
    Tama1968 and yoho360[OP] like this.
  5. Mar 15, 2022 at 5:35 PM
    4-Funner
    4-Funner New Member
    2007 Limited 4.7L V8
    As mentioned this is an interference engine that will suffer major damage if you have a belt failure. Best to have it changed at least every 100k miles.
    I suggest getting the Aisin kit (Toyota's OEM, includes all OEM parts) that includes the belt, tensioner, idler pulleys, and the waterpump. The only thing the kit doesn't include that you'll need is a tube of Toyota's FIPG (Toyota Seal Packing 1282B #08826-00100) which is needed for the top waterhose outlet and its formulated specifically for Toyota's pink super long life coolant. Many people who have used various third party sealants instead have run into the pink crusties leaking from that seal.
    It's not a terribly hard job to do but it is time consuming so if you are paying labor for someone else to do it it might cost a penny more than you might have thought it should. The waterpump is timing belt driven so if/when it goes you have to all the same work to remove the timing belt just to get to the pump so it's kinda a foolish gamble not to replace it while you are already right there.
    There are many 2UZFE V8 timing belt videos on youtube for 4runners, Lexus and Tundras. This was the most helpful one I wound up referring to when I did mine. This is by someone who has obviously done this job many many times and it shows exactly what tools and in the most ideal order to tackle it step by step along with several great tips for making it easier. One thing though he does skip the waterpump though which I obviously do not recommend doing.
    My first time doing this timing belt took me a full day from morning to sundown, though I'm deliberately slow and picky and laid each piece out in order placing the bolts in their proper locations with each removed part or otherwise labeled, I cleaned every bolt up on the bench grinder's wire wheel, etc, used a bit of blue loctite on most bolts going back in, etc. The second time, again being every bit as ridiculously meticulous, I got her done in just under 5 hrs.
  6. Mar 16, 2022 at 4:03 PM
    ToyotaRDie
    ToyotaRDie New Member
    Does a 2004 SR5 V6 have a timing belt or timing chain?
  7. Mar 16, 2022 at 4:06 PM
    I'm pretty sure the 1GR was always a chain. But, I wouldn't take my word for it. :D
  8. Mar 17, 2022 at 6:23 AM
    iamincrediboy
    iamincrediboy New Member
    South FL
    1GR (V6) has a timing chain. 2UZ (V8) has the timing belt
