Tie Rods and Wheel Bearings 4th gen
Discussion in '4th Gen 4Runners (2003-2009)' started by VMCOR3, May 16, 2024.
  1. May 16, 2024 at 10:33 AM
    VMCOR3
    VMCOR3 [OP] New Member
    2006 Black 4Runner
    3 Inch old man emu lift kit ARB front Bumper 33x12 AT tires Engine tune
    My 06 4Runner was taken to the shop for a wheel alignment and had been given the diagnosis that the Tie Rods and Wheel bearings needed to be replaced. this is fine but they wanted to charge $3000 for the service, is this expensive? it feels like a lot.
    Am i able to do this myself with the right equipment? or is the issue big enough i should leave it to a team?
    Thank you all.
  2. May 16, 2024 at 11:24 AM
    gkomo
    gkomo New Member
    San Diego, CA
    2004 4Runner Limited V8
    $3,000 is definitely too much. The wheel bearings (at least from my experience with my Tacoma) were like $350 for both, and that was for NSK assemblies from a member on Tacomaworld. You can do those yourself if you have some tools and time. In itself those aren't too hard to change. You'll need a torque wrench that goes up to 250ft/lbs as i believe the torque setting for the wheel nut is like 180-190ft/lbs or something. Again, i'm speaking from Tacoma experience, but i don't imagine the 4runner process being much different.
    Is your 4runner a 4WD or 2WD? I did make the mistake when doing my Tacoma wheel bearings, on the first one, i didn't seat the CV axle correctly, and started cranking down on the wheel nut and realized it wasn't going back together correctly, so just something to look out for. I won't make that mistake again. If yours is 2WD then the whole process gets a lot easier as you don't have to deal with CV axles.
    I have no clue about the Tie Rods, haven't done those ever, but can't image they make up the other $2,500 of their quote.
    VMCOR3[OP] likes this.
  3. May 17, 2024 at 6:44 AM
    grumpy 02
    grumpy 02 New Member
    Stan
    Colorado Springs, CO
    2007 White 4Runner SR5
    None Yet
    I don't have a link for tie rods, but RockAuto will have some as well as Amazon. You can source the hub/bearing aasy & seals elsewhere as well. Some come with the seals some don't. You will need an alignment after you do the work.
    Parts you will need:
    https://www.amazon.com/gp/product/B008PKY9W2?ie=UTF8
    https://www.amazon.com/gp/product/B0C8LYPG4J?ie=UTF8
    Installation videos: (Both of these channels have some very good videos covering many DIY project on 4Runners)
    https://www.youtube.com/watch?v=G9wC7PFzLGY&list=PLJVpHWuCEUX8-f7oRh_A8vPzIjtVGnVY2&index=23
    https://www.youtube.com/watch?v=K4bmIez6S-k&list=PLJVpHWuCEUX8-f7oRh_A8vPzIjtVGnVY2&index=45
    https://www.youtube.com/watch?v=--HcOQlv03U
    Hope this helps.
    VMCOR3[OP] and Bluesky 07 like this.
  4. May 17, 2024 at 7:33 AM
    jeepster09
    jeepster09 "Old"-Member....
    Twin Cities MN
    4Runner 2008 Sport
    A work in progress.....
    $200 per hour seems more and more common in metro Minnesota area. It could easily hit over a grand just for the labor, next add parts with mark up and taxes and $3000 is not far off. SADLY!:annoyed:
  5. May 24, 2024 at 11:42 AM
    VMCOR3
    2006 Black 4Runner
    Thanks much, i was able to fix the wheel bearings, but the tie rods where a lot more difficult since i needed to get an alignment too.
    It is 4WD witch was the main issue with the process. ended up having to pay 2200 for the tie rods, and the alignment.
    The tie rod boots did not ahow up with my order so it slowed the process a good amount
  6. May 24, 2024 at 1:07 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    Just tie rods? Or did they replace other things, too?
  7. May 24, 2024 at 5:45 PM
    4R777
    4R777 New Member
    2200 holy shit that seems high just for tie rods and alignment. Alignment couldn't have been more than $200. Which means tie rods costing $2k to install? Fkkkk
