Ticking at Idle/low rpms in my 3rd gen
Discussion in '3rd Gen 4Runners (1996-2002)' started by GandalfTheWhite, Jun 14, 2019.
  1. Jun 14, 2019 at 7:24 AM
    GandalfTheWhite
    GandalfTheWhite [OP] New Member
    Elliott
    Seattle, Washington
    2001 White 4Runner SR5 4X4
    I have a ticking in the rear end of my rig... anyone know what it could be? It happens when at a higher rpm idle (around 1k). I shook the exhaust and no sound. I wouldn’t think it would be the driveline or axle because it happens in park as well. I also pulled the trim to look at the body mounts and everything. I recently did a tundra brake swap/flushed the system and got the rear shoes adjusted. Bigger wheels/tires followed because stock ones don’t fit after swap. I’m trying to upload a video but it won’t work :/ thanks in advance for the help!
  2. Jun 14, 2019 at 7:26 AM
    GandalfTheWhite
    Elliott
    Seattle, Washington
    Doesn’t start happening until after driving for around 10 minutes
  3. Jun 14, 2019 at 8:28 PM
    4scooter19
    4scooter19 New Member
    Oregon
    98 and 86 4Runners
    The catalytic converter in my third gen had started to internally fall apart. It would rattle/tick once warmed up. I cut it open got all the gunk out of it and welded it back up. No rattles since. It would never make noise if you physically shook it, but once it warmed up it rattled pretty good. Might be worth checking. Hard to tell without hearing the noise tho.
  4. Jun 14, 2019 at 8:59 PM
    GandalfTheWhite
    Elliott
    Seattle, Washington
    I just pulled my spare tire out and found out it was my charcoal canister. Thanks for the advice though!
  5. Jun 15, 2019 at 7:09 AM
    4scooter19
    Oregon
    98 and 86 4Runners
    No problem glad you figured it out.
  6. Jun 17, 2019 at 9:32 PM
    jross20
    jross20 New Member
    Any pics?
