Thoughts on suspension
Discussion in '3rd Gen 4Runners (1996-2002)' started by Bcrainshaw, Feb 17, 2021.
  1. Feb 17, 2021 at 3:34 PM
    Bcrainshaw
    Bcrainshaw [OP] New Member
    Blake
    2002 4Runner limited 4x4
    Wheels and tires Rest in the works
    So I recently posted on everyone’s thoughts on suspension (wore out subject) but I came across some kyb front and rear struts and shock absorbers for 250. Thinking about putting these on with some tundra springs, will this work?
  2. Feb 17, 2021 at 3:38 PM
    gunsnob
    gunsnob New Member
    Vince
    2019 4Runner TRD ORP
    Personally, I've never heard of them. My thoughts, speaking from experience... better to do it right the first time than redo with what you wanted to begin with later.. I fell into that trap... fortunately not too deep when I realized...
    ruiz4251 likes this.
  3. Feb 17, 2021 at 3:50 PM
    Bcrainshaw
    Blake
    Crazy, I have seen tons of threads on kyb suspensions and using tundra springs on many other types of suspensions
  4. Feb 17, 2021 at 5:25 PM
    Kwikvette
    Kwikvette New Member
    Multiple
    KYB has been out for a long time, good shocks.
    Can't go wrong with them really if you're just looking to regain that factory ride.
    Toy4X4 likes this.
  5. Feb 17, 2021 at 5:45 PM
    Bcrainshaw
    Blake
    will tundra springs work with them? What ear tundra if so?
  6. Feb 17, 2021 at 5:48 PM
    Kwikvette
    Multiple
    So, why not just use what the 4Runner requires?
    What is your end goal?
    Your initial post implies that you're replacing your suspension and keeping it factory.
  7. Feb 17, 2021 at 5:55 PM
    Bcrainshaw
    Blake
    From what I hear tundra springs will give it a slight lift not much. Either-way works for me!
  8. Feb 17, 2021 at 6:00 PM
    Kwikvette
    Multiple
    You will regain the height lost you had when your vehicle was new when replacing your coils front and back.
    Yes Tundra springs will raise it even higher than that, but like you said...you want to do it right so why not get something that's made for your 4Runner?
  9. Feb 17, 2021 at 6:03 PM
    Kwikvette
    Multiple
    treyus30 likes this.
  10. Feb 17, 2021 at 6:07 PM
    Bcrainshaw
    Blake
  11. Feb 17, 2021 at 10:26 PM
    Kwikvette
    Multiple
    Well, refer back to the other thread as I made a lot of points there...just not with specific information.
    OME 880 springs up front which should net a 1" lift; you may as well go with trim packers in the rear with new factory coils because the lowest lift for the rear by OME are 906 springs. Those are supposed to provide 2" and they did when I had them. I've got a pair with less than 4k miles on them and they've been replaced by longer coils.
    Tundra springs can lift the front, but will yield roughly 2.5" of height. May as well go with OME 881's which will net you the same lift. Hope this answers your question about Tundra springs.
    There is one model 4Runner in which you can purchase springs from, new, which will give you roughly 1" height all around and it's from the Highlander model.
    Front passenger spring part number is 48131-35400, driver is 48131-35350, and rears are 48231-35210
    I'm thinking the last option is truly your best bet as you want minimal lift.
  12. Feb 18, 2021 at 5:49 AM
    Bcrainshaw
    Blake
    awesome! Appreciate it this answered everything I needed
  13. Feb 18, 2021 at 6:17 PM
    Bcrainshaw
    Blake
    Ended up going with kyb (red) front and rear shock/ struts with eibach pro lift springs. Think that’s gonna be worth a damn? It’s in my budget and I’m not to hard on a vehicle
