Third GEN water temperature gage
Discussion in '3rd Gen 4Runners (1996-2002)' started by CoolToyota, May 3, 2023.
  1. May 3, 2023 at 2:57 AM
    CoolToyota
    CoolToyota [OP] New Member
    98 4Runner 1A5
    Actual mechanical water, temperature gauge. Has anyone done this ? I’m at 312k+ miles and I’ve only had it a couple months. I did have the oil light coming on and I checked my oil and it seems OK so I added a mechanical oil pressure gauge disconnected the switch and the pressure seems within range according to the Toyota service manual so it got me thinking what about the water temperature and since it’s just basically a light. I’d like to also keep the current water temp light/ gauge connected as well.
  2. May 3, 2023 at 3:44 PM
    Can't you get this through the OBD2 port with a dongle?
    I know I monitor a bunch of stuff with my phone.
    CoolToyota[OP] likes this.
  3. May 3, 2023 at 4:47 PM
    Kwikvette
    Kwikvette Kwik Fab
    Multiple
    As mentioned above, use your OBDII port and monitor actual ECT as well as other vital information.
    The gauge on your dash is a dummy gauge and relies on a single-wire sender. This is problematic as you can get false readings and have altogether different results for example -
    Engine not overheating, a bad sender can fail to tell you that you're running too hot
    OR
    Engine running fine, a bad sender can falsely tell you that you're overheating
    The actual sensor that not only monitors your engine coolant, but also communicates with your PCM (open loop operation, etc) reads out to your OBDII and is in no way tied to the sender or gauge I explained above.
  4. May 3, 2023 at 6:43 PM
    CoolToyota
    98 4Runner 1A5
    Great idea ! Any recommendations on what to plug into the OBDII that communicates to my iPhone ? Kwikvette and Negusm
  5. May 3, 2023 at 6:56 PM
    Kwikvette
    Kwikvette Kwik Fab
    Multiple
    I wouldn't bother tying up a phone; the two most popular choices arw Scangauge and Ultragauge.
    I ran an Ultragauge when I had my 4Runner -
    If I recall correctly, I think Scangauge came out with a newer modern looking setup.
    Either connect via OBDII.
  6. May 3, 2023 at 7:18 PM
    CoolToyota
    98 4Runner 1A5
    Looks good - I will check that out ! Thanks
  7. May 3, 2023 at 8:21 PM
  8. May 4, 2023 at 3:56 AM
    Alan-in-Alabama
    Alan-in-Alabama New Member
    Alan
    1999 Limited
    None.
  9. May 4, 2023 at 9:49 AM
    4scooter19
    4scooter19 New Member
    Oregon
    98 and 86 4Runners
    https://www.amazon.com/Dewhel-Alumi...t=&hvlocphy=9033087&hvtargid=pla-570191884470
    I use one of these spliced into the upper radiator hose of my 66 mustang. The temp sender goes to a digital water temp gauge and also kicks on my electric fans.
  10. Nov 2, 2023 at 4:37 PM
    Scarpia
    Scarpia New Member
    25 miles from downtown Seattle in King County
    2019 4Runner
    When your thermostat opens and coolant flow throughs the upper hose from the radiator into the engine, do you see a temperature change on the gauge? If so, then the gauge should show increase in temperature as the hot engine coolant flows through the radiator thence the hose with sensor. My goal is to verify the thermostat is working so if the temperature changes, the thermostat must be functioning; however, with the sensor in the radiator hose, it does not show at what temperature the thermostat is opening.
