Tailgate won't open! 2004 4Runner
Discussion in '4th Gen 4Runners (2003-2009)' started by GoBlue2004!, Sep 15, 2020.
  1. Sep 15, 2020 at 9:40 PM
    GoBlue2004!
    GoBlue2004! [OP] New Member
    Richard
    2004 4Runner 4th. Gen V8
    Icon front upper arm support and shocks and heavy duty rear springs. ARB rear locker.
    My tailgate has been acting up once in a while for about two years. It finally won't open any more. pulling the tailgate handle creates a noise and I can see the lever action happening but not allowing it to open. I bought a new motor but that didn't help. I bought a new release handle but that didn't help. So now I'm stuck with a situation whereby I want to fix the problem but not sure what is the next step. I normalized the electronics and that's not it either. Next product to replace is the computer / electronic module where all the wires go into the door and to the latch, wiper and window.
    Does anyone know what might be happening?
  2. Sep 16, 2020 at 5:54 AM
    Try pushing in on the hatch before pulling the lever. Keep leaning on it until after the mechanism does it's thing, then pull.
    If that doesn't work, there is an access panel on the inside of the hatch that I used to reach through to help the mechanism. Just be careful as you could get pinched if you put your fingers in the wrong place. I don't highly recommend this method, but it might work.
  3. Sep 16, 2020 at 6:04 AM
    Did you replace the entire latch mechanism? When mine finally quit working altogether, I got the mechanism out of another hatch and it was good as new again
  4. Sep 16, 2020 at 10:46 PM
    GoBlue2004!
    Richard
    Yes. New latch and handle.
  5. Sep 17, 2020 at 9:20 AM
    PCRIDE4RUNNER
    PCRIDE4RUNNER New Member
    SUPER DUPER
    That's where the actuator is controlling the door latch. Probably is where the issue i
  6. Sep 17, 2020 at 9:49 AM
    Hmm. I figured there was just the latch mechanism and the push button in the handle above the license plate. I didn't know there was a computer for the hatch. Weird.
    I'm curious what the solution ends up being.
  7. Sep 21, 2020 at 4:42 PM
    importman
    importman The mountains are calling and I must go...
    Danny
    Carolinas
    05 Silver SR5 V6 4X4
    Blacked out, Ironman 3" Nitro Gas Suspension lift, JBA High Caster upper control arms, Differential drop and sway bar relocate, Upgraded to Sport Front Cardone Calipers with Brembo Rotors and Akebono Pads, Added Spoiler, Sony XAV-AX100 with Apple Carplay, USB Jack, Backup Camera, Black TRD Pro Wheels with General Grabber ATX 265/70/17, Rear differential vent extension, Auto Dimming Mirror with Compass and Homelink, Map Light Mod, Tekonsha 90160 Trailer Brake Controller, Recoil SL1708 Sub, Sealight LED Headlamps, K&N drop in air filter, Weathertech floor mats, Homemade rear storage compartment with built in pull out table.
  8. Sep 24, 2020 at 11:17 PM
    4R777
    4R777 New Member
    I spent over a year trying to figure out what was wrong with mine. Turned out to be the craziest thing. The rubble handle on 4th gen are known for melting under hot temperatures. It had turned into a sticky black goo that would get stuck on the push button mechanism, so my tailgate would open itself when driving down the road, and many times I could not get it to stay closed at all. I used the bungee cord thing to hold it shut until I figure this out. So simple.
    Easy to take apart, and I used some goo-gone type cleaner to get the black stuff off the plastic mechanism. The popped it back on with the new cover and it's like new.
    Here's the replacement part.
    https://www.amazon.com/Button-Liftg...=4runner+tailgate+cover&qid=1601014587&sr=8-3
    or
    https://www.amazon.com/IMPROVED-Rep...9Y9KNSPM190&psc=1&refRID=GTT3208D09Y9KNSPM190
  9. Apr 4, 2021 at 8:37 PM
    ElkChaser
    ElkChaser New Member
    04 runner
    I’m having similar issues with mine. Can’t get the tailgate open at all. The button stopped working this weekend when I was inside there attempting to oil the latch. It was attempting to open before that when ever I pulled the handle. At a total loss at this point. No idea how to get it open.
