Taco Trailhunter in the Wild
Discussion in 'Other Toyota Vehicles' started by ThomasL, Jan 5, 2025.
  1. Jan 5, 2025 at 5:25 PM
    ThomasL
    ThomasL [OP] New Member
    Florida
    24 TRD Off Road Prem
    Just saw my 1st Trailhunter in the wild and wanted to share.
    That is all
    SR5 Limited and ChessGuy like this.
  2. Jan 5, 2025 at 5:29 PM
    Congratulations! Is this your new toy? How do you like it?
  3. Jan 5, 2025 at 5:36 PM
    ThomasL
    Florida
    Oh no, I “wish” lol more of a car spotting situation.
    djwantke likes this.
  4. Jan 5, 2025 at 6:23 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Little bit bigger tires would give it that wow factor, nice truck that persons got.
  5. Jan 5, 2025 at 7:15 PM
    Let me guess: $75,000.00? I like the H.A.I.?
    Makavelli likes this.
  6. Jan 5, 2025 at 7:36 PM
    Makavelli
    Makavelli New Member
    2024 4Runner V6
    Those r a joke! 4bang-turbo junk
  7. Jan 6, 2025 at 5:08 AM
    ThomasL
    Florida
    Lol I didn’t think I would start, truck look pretty sweet and very cool Toyota is selling a OEM+ modded overlander.
    now, yes 65k is fucking insane, especially when you can get a Ranger Raptor for 57k with a none hybrid twin turbo V6
    Trail Runnah likes this.
  8. Jan 10, 2025 at 5:08 PM
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    Way better looking than the new 4Runner
  9. Jan 10, 2025 at 7:07 PM
    They seem nice except for the price and only coming as a hybrid. Losing the underseat storage to a battery in a vehicle meant for travel seems counterintuitive. Also a hybrid system that can’t be fixed in the field also seems counterintuitive to an overland vehicle.
    Jennyjo14 and Makavelli like this.
  10. Jan 28, 2025 at 1:37 PM
    Dang :drool:
    PRO
    ThomasL[OP] likes this.
  11. Jan 28, 2025 at 5:58 PM
    Imagine spending close to 70k on a truck and then immediately having to spend another 2-3k to replace the tires and wheels.
  12. Jan 28, 2025 at 8:37 PM
    USD!
  13. Jan 29, 2025 at 2:25 AM
    Jennyjo14
    Jennyjo14 New Member
    Jennifer
    None
    Especially when the back seat is smaller than a midget's fedora. Back seats of the new Tacoma are completely useless for travel.
