T9 Headunit
Discussion in 'Audio & Video' started by DannyD303, Jul 16, 2019.
  1. May 2, 2020 at 8:36 PM
    #181
    Daytonaviolet
    Daytonaviolet TRD Bro
    Bay Area, CA
    Blizzard Pearl TRD Bro
    There are two yellow connectors. Did you try both ?
  2. May 3, 2020 at 5:10 AM
    #182
    DannyD303
    DannyD303 [OP] New Member
    2019 Voodoo Blue Pro
    Yup. I remember seeing something about the display setting. 720 vs 1080 but I tried everyone and zip
  3. May 3, 2020 at 10:35 AM
    #183
    Daytonaviolet
    Bay Area, CA
    when it’s in reverse camera mode, you can tap on the screen. When the option comes up, select auto.
  4. May 3, 2020 at 4:33 PM
    #184
    DannyD303
    I figured it out. Long story short I was missing a connection.
    The family and I went out for food today and having the bigger screen and all touch screen was nice. Still have a lot to learn about the unit though
  5. May 4, 2020 at 11:32 PM
    #185
    brochachoT4R
    brochachoT4R New Member
    Rob
    Early 5th Gen Trail
    Mr. Fusion
    I just placed the order for Mine on the 2nd. Looking forward to getting rid of the factory unit. I will still hold on to it just incase things go south.
    Daytonaviolet and DannyD303[OP] like this.
  6. May 5, 2020 at 8:59 AM
    #186
    Daytonaviolet
    Bay Area, CA
    Definitely hold on to it. I had my T9 since mid March and I just sent it back last week. My 2nd one should be arriving in a few weeks :)
    brochachoT4R[QUOTED] likes this.
  7. May 22, 2020 at 2:44 PM
    #187
    hergonthegreat
    hergonthegreat New Member
    Forrest
    I know I'm way behind the party here, but did the radio have preamp outputs for front, rear, and sub? Looking to do a pretty similar setup to you looks like!
    kbp810[QUOTED] likes this.
  8. May 22, 2020 at 3:02 PM
    #188
    Daytonaviolet
    Bay Area, CA
    Yes it has pre-outs.
  9. May 22, 2020 at 3:22 PM
    #189
    hergonthegreat
    Forrest
    Thanks! Considering this for a future project.
    Daytonaviolet[QUOTED] and kbp810 like this.
  10. May 24, 2020 at 10:22 AM
    #190
    Normantaco
    Normantaco New Member
    How do the steering wheel controls work with the T9? Is an adapter needed? Can you custom program what the buttons do?
  11. May 24, 2020 at 11:34 AM
    #191
    Daytonaviolet
    Bay Area, CA
    The t9 comes with a harness which has a canbus to control all native steering buttons; volume, next/previous. Canbus also displays door and HVAC stays to the screen. Custom programming is available but you’ll need to switch wires in a plug.
  12. May 31, 2020 at 3:44 PM
    #192
    brochachoT4R
    Rob
    Early 5th Gen Trail
    Mr. Fusion
    I've had it for a couple weeks now and love it! I'm an Apple fan but the android unit works fine and I heard the skipping thing when it was 1st installed a couple times but that was when it was tethered to my phone's wifi. Androids and Apples don't get along:p The unlimited SIM card from ATT was kind of a struggle to get started. I set up the SIM card with an old 4g capable iPhone and installed it in the sim holder because the head unit would only register 2G. The sim holder itself wasn't making contact with the SIM card so I bent the contact pins and used a shim to hold it tight then wrapped the holder in electrical tape. Hopefully this help the next person who installs!
    peter2772000 and Daytonaviolet like this.
  13. May 31, 2020 at 5:29 PM
    #193
    Daytonaviolet
    Bay Area, CA
    Yesterday I added a hardwire to my wireless CarPlay. I wired it to the console to this usb/audio port. It allows me to connect to CarPlay and charge 3.4A rate.
  14. May 31, 2020 at 10:55 PM
    #194
    brochachoT4R
    Rob
    Early 5th Gen Trail
    Mr. Fusion
    That's cool! Maybe next week I will do the same!
    Daytonaviolet likes this.
  15. Jun 1, 2020 at 3:17 AM
    #195
    peter2772000
    peter2772000 New Member
    Peter
    Montreal/Cape Coral
    2019 TRD Pro
    Damn! Makes me wish I didn't have heated seats, coulda used those spots to do what you did..
    Clayman14 and Daytonaviolet like this.
  16. Jul 10, 2020 at 8:10 PM
    #196
    Moose Wranger
    Moose Wranger New Member
    Los Angeles, Ca
    2020 Black SR5 4x4
    vision phase still
    Is this available for the 2020s? Internet seems to say 'no'.
    MW
  17. Jul 11, 2020 at 8:46 AM
    #197
    peter2772000
    Peter
    Montreal/Cape Coral
    2019 TRD Pro
    From what I understand, no. But don't the 2020's come with the bigger screen?
    newlife likes this.
  18. Aug 10, 2020 at 12:45 PM
    #198
    Runnin4mo
    Runnin4mo New Member
    Just installed the T9 from Rhino... everything is working fantastic EXCEPT Torque Pro. I got the OBD2 Bluetooth from Rhino and plugged it in, turned it on... then on the T9 I hit the Bluetooth app. Search, it finds the OBD2, touch and hold it, it pops up with a window saying OK - OBD2 - CANCEL i hit OK, and get the message "Pairing Successful". I then go to Torque Pro, go into settings to select the BOD2 scanner... but does not find it.
    I tried to remove the OBD2 and pair about 4 times. It will not connect to Torque even though it says it's Paired int he Bluetooth app.
    Ideas?
    Thanks all!
  19. Aug 10, 2020 at 12:49 PM
    #199
    hergonthegreat
    Forrest
    Not for the t9 specifically, but I have used Torque with the adapters and have found the adapters are usually the problem. It took me returning my adapter and getting another one for it to work correctly when using the app on my phone. Exact same type of adapter, exact same phone, exact same vehicle. Just bad QC I guess.
  20. Aug 10, 2020 at 12:52 PM
    #200
    Runnin4mo
    I'll try that out, I have another OBD2 that i have used before... it's about 3 times bigger but at least i can see if thats the issue.
    hergonthegreat likes this.
  21. Aug 10, 2020 at 1:22 PM
    #201
    Runnin4mo
    It's not the OBD2 unit. I tested it on my phone with Torque and it works fine. Also swapped the OBD2 with another i have and it's doing the same thing in the T9. There must be a certian way to setup the OBD2 in the T9 for it to read it correctly as an incoming Bluetooth connection instead of Outgoing like a phone.
  22. Aug 11, 2020 at 8:08 AM
    #202
    DannyD303
    I don't have the head unit in front of me so I might get this wrong but Ill try to explain how I have to do it....
    Go to the Bluetooth app, click on settings, there should be a list of 4 or 5 setting (one should be the code to connect to Bluetooth, 1234) click on the last setting at the bottom, it should show a graphic about having 2 different Bluetooth devices, click OK at the bottom of the screen, should take you to the next page where you have to turn on the secondary Bluetooth.
    I don't remember if you have to connect the OBDII unit to that Bluetooth or not but I do know that I have to go through these steps every time I get into the car because that setting always gets turned off when the unit power cycles.
    Hope this helps and I think I have all the steps listed but let me know if that helps you
  23. Aug 11, 2020 at 9:28 AM
    #203
    AsianAnts
    AsianAnts New Member
    '18 TRD Offroad Prem. BLK
    Too many to list.
    anyone got issues with the bluetooth cutting in and out every couple of minutes or so?
  24. Aug 16, 2020 at 8:35 PM
    #204
    HAMAM
    HAMAM New Member
    Hello everyone,
    I am a newbie here. I plan on modifying my 2011 SR5 and the T9 head unit looks pleasant. Thanks for all the inputs from everyone. Very helpful.
    Few questions;
    1- I plan on adding a reverse and maybe a dash cam. Will the T9 work? Since the reverse cam isn't stock, it will be powered via the reverse light. Will that work with the T9?
    2- Rhinoradios or Cartrimhome? Rhinoradios offers an openbox/cheaper option.
    3- Is there any antifinger print screens that fit the T9 display?
    4- I believe the car built in XM won't work but the XM android app will, is that right?
    5- Any issues with getting steering buttons working on 2011 SR5?
    6- Does it use the car mic or the T9 mic?
    7- How to get the TPMS connected?
    8- Texas is hot, like +100F. Does the unit have any issues with that?
    9- Any idea when T10 is coming out?
  25. Sep 13, 2020 at 4:38 AM
    #205
    ap-batou
    ap-batou New Member
    Got my T9 installed and working, pretty happy all over, but having issues with the whole android auto. What are people using for connecting their phone to the head unit, I don't really trust the easyconnection app that comes installed on the unit.
  26. Sep 28, 2020 at 8:02 AM
    #206
    ATrn
    ATrn New Member
    2018 4runner TRD Off Road
    Anyone have a T9 they are looking to sell?
  27. Dec 2, 2020 at 7:12 PM
    #207
    c0011j
    c0011j New Member
    Dark Grey 2018 TRD OR 4Runner
    Bilstein Suspension - OEM Audio+ upgrade - Morimoto XB headlight swap - RiGD rear swing out carrier - Aftermarket wheels
    Don't know if this helps but I just installed my T9 and used this camera after I purchased the RiGD swing carrier. There is a harness with a power lead built in. Plug and play.
    https://www.rigdsupply.com/products/toyota-backup-camera-relocation-kit
    I am interested in this as well. Native Android Auto is better than nothing but I haven't figured out to get the calls/messages to sync.
    Also I couldn't find any real info on the steering wheel controls. I tried to program them but that does not seem to be working.
  28. Jan 20, 2021 at 5:11 AM
    #208
    Miker18
    Miker18 New Member
    2014 grey 4runner limited
    Did you ever get the wifi connection figured out? My T9 is doing the same thing, however, now the unit can't find any wifi signals at all. Even my phone's mobile hotspot.
  29. Jan 21, 2021 at 3:38 PM
    #209
    ANNIE_GOT_A_RUN
    ANNIE_GOT_A_RUN New Member
    2021 TRD Pro
    Too many to list...
    I can only use when using my phone as a Hotspot. I usually need to go into settings, then hit the network button to make sure my cell is linked. Once it is, it works great.
    Overall, I've been pretty happy with the T9.
  30. Jul 18, 2021 at 8:03 AM
    #210
    replica9000
    replica9000 New Member
    Jason
    New Vertiform City
    2019 TRD OR Premium
    So has anyone picked up the T10 version yet?
    I'm hesitant to buy a Chinese-based Android device, not because of quality, but because I wonder how quickly it'll become outdated.
    Even with brand-name smartphones, after 3 years or so, the OS starts to fall behind as apps are continually updated to Google's newer standards. GMaps comes to mind the most.
    DrewMan likes this.
