T9 Headunit
Discussion in 'Audio & Video' started by DannyD303, Jul 16, 2019.
  1. Sep 20, 2019 at 2:53 PM
    #121
    Compromised 4Runner
    Compromised 4Runner New Member
    2018 4Runner SR5
    $450 for a screen mirroring device? Yikes. That said, if you want oem look, and are really only after AA/ACP, then is a solid choice. Too bad on being wired though.
    ANNIE_GOT_A_RUN likes this.
  2. Sep 20, 2019 at 3:13 PM
    #122
    Dark Knight
    Dark Knight Get off my lawn
    That is not screen mirroring. Beat sonic does have that option but they are coming out with a new CarPlay/Android auto plug and play module. For those who don’t mind the factory head unit this will solve the few dislikes without the bugs of the T9 headunit.
  3. Sep 29, 2019 at 7:44 PM
    #123
    ANNIE_GOT_A_RUN
    ANNIE_GOT_A_RUN New Member
    2021 TRD Pro
    Too many to list...
    As an update... I installed my amp and subs this weekend. The buzzing noise from the T9 went away after I did some jostling of the wires in back. It is a clean sound now that the subs are hooked up. I'm pretty happy with how it all turned out!
  4. Sep 29, 2019 at 8:34 PM
    #124
    Compromised 4Runner
    2018 4Runner SR5
    No adapter needed for the sub & amp?
  5. Sep 30, 2019 at 8:02 AM
    #125
    ANNIE_GOT_A_RUN
    2021 TRD Pro
    Too many to list...
    Nope. The T9 comes with everything you need. RCA plug in which has many different Audio Visual outputs as well as the remote wire. Really easy plug and play.
  6. Oct 5, 2019 at 3:36 PM
    #126
    future_itisnow
    future_itisnow New Member
    2016 TRD Pro
    Recently finished up installing the T9 and overall I'm very happy with the purchase after a few days. I've been through most of the settings and I'm still finding little things I'd like to customize (assuming I can do these things), and after the post above I'm hoping some of you have found these settings and can assist.
    1. Would like to find the toggle for having the unit stop from muting the music when the backup camera is on. I don't want it to stop the music.
    2. Would like to stop the climate control from showing up on the screen.
    3. Would like the steering wheel button for voice activation to actually do that again, after the install that button just becomes a mute button.
    4. Also interested in getting some feedback on android car launchers you all like. I'll play around with some from the google play store but I'm down for recs.
    I'll post some thoughts on the unit in the coming days as I get more acclimated to it.
  7. Oct 7, 2019 at 1:57 PM
    #127
    ANNIE_GOT_A_RUN
    2021 TRD Pro
    Too many to list...
    Please let me know if you find a solution to number 1. I've been struggling with that as well.
  8. Oct 9, 2019 at 8:22 AM
    #128
    Living the dream
    Living the dream New Member
    ABQ
    2019 T4R Off-Road KDSS
    1. Settings-Car Settings-Reversing Settings-Reverse Mute-Reverse Mute CLOSE.
    2. (Edit) car settings-extra settings-password 123456- check box for air control
    3. Not available on this unit.
    4. Can’t help on that one I use Apple.
  9. Oct 9, 2019 at 8:23 AM
    #129
    Living the dream
    ABQ
  10. Oct 9, 2019 at 1:07 PM
    #130
    ANNIE_GOT_A_RUN
    2021 TRD Pro
    Too many to list...
    Thanks!
  11. Oct 26, 2019 at 4:47 PM
    #131
    Shinobi
    Shinobi New Member
    I attempted to install the t9 unit today got everything plugged in and turned it on. Everything works but no sound or music. Been playing with it for awhile and I can’t figure out why I’m not getting any sound to come out.
    any advice?
  12. Oct 26, 2019 at 5:38 PM
    #132
    Living the dream
    ABQ
    If you turn up the volume do you see a bar across the top of the screen with an indicator of it getting louder? Pressing the voice commands button on the steering wheel mutes it.
  13. Oct 26, 2019 at 8:36 PM
    #133
    Shinobi
    Shinobi New Member
    Yes it does.
  14. Oct 26, 2019 at 8:50 PM
    #134
    Living the dream
    ABQ
    My best guess is the connection to the head unit has come loose. The connectors come loose easy you have to push on the tab with something flat and push in to get them to lock.
    https://youtu.be/lUaoB47w7YE
  15. Oct 26, 2019 at 10:44 PM
    #135
    Shinobi
    Shinobi New Member
    I did do that. I’ve pretty much done everything I’ve found online. I’m lost with it. Thank you for the help I really appreciate it guys.
  16. Oct 29, 2019 at 2:47 PM
    #136
    snowruner
    snowruner New Member
    AMEET
    2016 4RUNNER TRAIL PREMIUM
    TOYTEC ALUMA SERIES SCS SR8 BFG 285 70 17 KO2 T9 HEAD UNIT ROUGH COUNTRY LIGHT BAR
    hey guys have any of you tried the tpms sensors on the t9 or t8. is it possible to get that info through the obdii or have to get the tpms senors that are android compatible from Amazon. pics of what the obdii adapter can display will be much appreciated. btw I had the t8 it was great. just ordered the t9.
  17. Nov 12, 2019 at 2:53 PM
    #137
    Radvntr
    Radvntr New Member
    Jarrod
    2015 Black 4Runner
    Got everything installed but have not been able to get the Backup camera to work. I tried both yellow RCA plugs. One says no video signal and the other shows this colored bar. Anybody else had this or have a fix for it? Thanks!
    brochachoT4R and snowruner like this.
  18. Nov 12, 2019 at 3:30 PM
    #138
    snowruner
    AMEET
    I had the same issue when I installed mine on Friday. the resolution is set to 1080 you need to select auto. when you put in reverse tap the screen when you get the settings icon selected it and you'll get a options menu. select auto.
    c0011j, brochachoT4R and peter2772000 like this.
  19. Nov 12, 2019 at 4:29 PM
    #139
    Radvntr
    Radvntr New Member
    Jarrod
    2015 Black 4Runner
    @snowruner
    Perfect. That worked like a charm! Thanks
    SlvrSlug and snowruner like this.
  20. Nov 12, 2019 at 9:03 PM
    #140
    Living the dream
    ABQ
    I finally found the answer to #2. It can be turned off.
    Settings-Car settings-Extra settings- config password 123456-check box for air control
  21. Nov 13, 2019 at 12:02 PM
    #141
    replica9000
    replica9000 New Member
    Jason
    New Vertiform City
    2019 TRD OR Premium
    Does the T9 button illumination match with the stock setup?
  22. Nov 30, 2019 at 2:49 PM
    #142
    elevenrunner
    elevenrunner New Member
    Can someone tell me if the T9 unit will work with my 2011 SR5 runner with non JBL system? Cartrimhome site says 14-19 but some description says from 2010 and up. Also is there any splicing or is this full plug and play?
  23. Dec 1, 2019 at 4:27 PM
    #143
    kbp810
    kbp810 rebmem wen
    Not sure about the compatible years... but for the second part, it is otherwise all plug and play. No splicing necessarily, can be switched back to stock like it never happened.
    elevenrunner[QUOTED] likes this.
  24. Dec 11, 2019 at 8:16 PM
    #144
    Nealylikeawheelie
    Nealylikeawheelie New Member
    2013 Red SR5
    Roof rack, leveling kit, aftermarket grilles, chrome delete, XD wheels,
    Hey all. New here. Read through quite a few posts but I was wondering is this compatible without a backup camera? I don’t have JBL either but I put in aftermarket speakers. I don’t have a sub or amp yet but they could use a boost as the original head unit doesn’t push enough for them to reach full potential.
  25. Dec 11, 2019 at 8:29 PM
    #145
    Welcome, i do not think a backup camera is needed for this unit to operate correctly.
  26. Dec 12, 2019 at 2:29 PM
    #146
    snowruner
    AMEET
    you don't need a back up camera, I used mine with stock door speaker and 3.5 jl's in the dash. I'm also runner a kicker 750 watt amp with a kicker 10 inch l7 on 2 ohms. sounds great.
  27. Jan 8, 2020 at 2:09 PM
    #147
    YourBoyRoy
    YourBoyRoy New Member
    2019 Limited
    T9 Head Unit
    Can anyone get Android Auto to work? I've tried the easy connect app and it's just stuck on the screen asking you to plug in your phone via USB.
  28. Jan 11, 2020 at 9:42 AM
    #148
    mikeymtbs
    mikeymtbs New Member
    19 TRD ORP
    Have read this thread and lots of others... what’s the consensus of the T9? It’s been out 6 months now... worth it? I can’t help but to wonder if a t10 is on the way soon.
  29. Feb 3, 2020 at 3:27 PM
    #149
    Radvntr
    Radvntr New Member
    Jarrod
    2015 Black 4Runner
    I'm still on the fence. I love the screen size. That's about it. Can anybody answer these if they have a fix?
    - The Mic audio is really bad from what people tell me while talking on the phone with Bluetooth.
    - Apple Play sometimes won't connect at all via Bluetooth or takes 10-15 min to connect. I have the apple play adapter but that doesn't seem to work either.
    - Can't adjust the audio (front/Back) or EQ
    - I have an Apple so not sure how all the Google Play apps work. I keep trying to download apps with it connected to my hotspot but won't actually download it.
    So minus the screen size and clarity, I sorta wanna put the OEM unit back in.
  30. Feb 3, 2020 at 4:04 PM
    #150
    Daytonaviolet
    Daytonaviolet TRD Bro
    Bay Area, CA
    Blizzard Pearl TRD Bro
    i'm on the fence as well. but i''m part of this FB group and there seems to be a lot of support regarding the T9 purchased @ cartrimhome.com
