T9 Headunit
Discussion in 'Audio & Video' started by DannyD303, Jul 16, 2019.
  1. Aug 1, 2019 at 11:01 AM
    #61
    Normantaco
    Normantaco New Member
    Carplay is limited in the maps they allow. From Apple website, these are the Nav apps available to Carplay, as well as Apple Maps.
  2. Aug 1, 2019 at 11:02 AM
    #62
    Normantaco
    Also, one feature I do like about our stock head unit is the split screen ability. Carplay can't currently do that, but the next update (in a month or 2) will allow split screen.
    jester243 likes this.
  3. Aug 1, 2019 at 11:47 AM
    #63
    danssr5
    danssr5 New Member
    Dan
    2017 sr5 premium 4x4
    Thanks!
    Do you know if the head unit can install apps from the google play store?
    Does the head unit have GPS?
  4. Aug 1, 2019 at 11:52 AM
    #64
    Normantaco
    Not sure. I had a Carplay unit in my last vehicle. Following this thread to decide if I get another simple Carplay unit or this one.
    I think you can install apps from store, and I think it has built in GPS, but I don't know for sure. One or 2 guys on here have the unit installed and could answer better than I.
  5. Aug 1, 2019 at 12:53 PM
    #65
    fishnyc22
    fishnyc22 New Member
    The device is basically an android tablet. You can install anything from the Google Play Store into it. It does have GPS as well. So you could install Navmii from Google Play. When in CarPlay it will only run CarPlay apps. You could download maps to run offline with Google Maps as well within CarPlay.
    Normantaco likes this.
  6. Aug 2, 2019 at 7:19 PM
    #66
    kbp810
    kbp810 rebmem wen
    Not sure if an adapter is available; Seems like it’s bundled into the factory wiring harness somewhere, but not sure which wires. I looked at a couple wiring diagrams but didn’t see it (was a quick glance though, I haven’t dove very deep into it yet).
    1. No xm support (aside from using the xm streaming app on it).
    2. It does. It comes with a gps antenna (doesn’t use the oem one). It does work well though.
    3. I would assume so, yes. You’ve got the full play store to browse through. I’m running back country navigator and Avenza on it currently for off road mapping.
    4. Negative. Everything said and done, it’s the same apple car play and limitations as any other car play unit. But, pretty much anything your missing, you can just skip car play and run on the head unit directly.
  7. Aug 5, 2019 at 9:55 AM
    #67
    ruster34
    ruster34 New Member
    Ryan
    2014 graphite Limited
    LED low/high beams, yellow LED fogs
    This might be a brainfart moment, but the amp specifies 4x45watt amp. If you have the JBL system, you have 6 speakers (plus sub), correct?
  8. Aug 5, 2019 at 12:45 PM
    #68
    Compromised 4Runner
    Compromised 4Runner New Member
    2018 4Runner SR5
  9. Aug 6, 2019 at 3:38 PM
    #69
    kbp810
    kbp810 rebmem wen
    There is a wiring harness to connect to the JBL system (the harness is unused in non-JBL installs). Otherwise, you typically have 8 speakers - dash speakers, front door speakers, rear door speakers, and rear hatch speakers. The dash and front door are in parallel, and the rear door and hatch are in parallel; so for the average install, 4 channels is correct. If you have the JBL, I think it's moot, as it's wired to the stock amp, and the amp is powering your system and not the radio.
    I have mine connected to an aftermarket amp, using the RCA outs; so can't really confirm how the audio performance is for JBL or non-JBL though.
  10. Aug 13, 2019 at 6:48 AM
    #70
    ruster34
    ruster34 New Member
    Ryan
    Ahh - that makes sense, and me happier knowing that the speakers would be powered by the existing amp. Much thanks to the detailed response!
  11. Aug 16, 2019 at 9:51 PM
    #71
    Texags08
    Texags08 New Member
    Do you have to manually enter CarPlay when you start the car every time, or will it remember and automatically launch?
  12. Aug 17, 2019 at 12:37 AM
    #72
    kevlar3d
    kevlar3d New Member
    I just got mine installed tonight. First impressions, pretty good!
    Overall fit wasn't great. Kept popping out at the top and I had to slightly modify the top clips to get a snug fit. The brackets didn't line up perfectly and I was only able to get one screw into the sides of the head unit using the oem bracket. I plugged it in, and everything worked immediately. I was pretty impressed.
    Boot time is good, overall speed is good, just like a very decent android tablet. I did want to install it before the end of the Las Vegas summer to see how it does in 120 degree heat. The OEM unit has a fan, this does not. It seemed pretty warm at 11pm tonight and it was only 103 degrees at that time. We will see how it does tomorrow during the day.
    I haven't tried a phone call yet, the whole mic situation is pretty concerning. I bought the wifi obdII thingy and I really should have gone with the bluetooth option.
    At this point, I've just been tethering my phone- or more accurately, using the house wifi since I was just in the driveway. I might try a sim chip tomorrow to see how it does.
    Does anyone know how to change the default icons on the bottom of the home screen? I'd like to put my own down there but it doesn't appear to be possible.
  13. Aug 17, 2019 at 6:29 PM
    #73
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    Meh...
    20190817_192212.jpg 20190817_192222.jpg 20190817_192212.jpg 20190817_192234.jpg 20190817_192324.jpg
    Apple car play or android auto also, which I hate. But... meh.. she does ok for what it is
  14. Aug 17, 2019 at 7:41 PM
    #74
    kbp810
    kbp810 rebmem wen
    you have to launch it each time; and it takes a little while to connect to the phone and launch. There’s also a funky audio issue via car play that causes intermittent skips in music, and crackles in things like the navigation voice and stuff.
    On the bright side you don’t totally need CarPlay, since you’ve got full blown android and can run pretty much anything off the head unit directly... but yeah, the CarPlay part is not currently a strong selling point on the t9.
  15. Aug 18, 2019 at 5:49 AM
    #75
    ruster34
    ruster34 New Member
    Ryan
    This is a Kenwood unit... Why'd you post the pics in this thread?
  16. Aug 18, 2019 at 9:44 AM
    #76
    Kyblack76
    Layton, Utah
    18 TRD O.R
    Pretty neat huh!? Cheaper and easier, does a lo . Pretty cool huh!?
  17. Aug 19, 2019 at 2:51 AM
    #77
    PinchedNerve
    PinchedNerve New Member
    2019 TRD Off-Road
  18. Aug 19, 2019 at 5:22 PM
    #78
    kevlar3d
    kevlar3d New Member
    Not really. I don't feel like the photos of the unrelated device add to this thread.
    shmaez, Sundy, MattAK and 4 others like this.
  19. Aug 20, 2019 at 8:42 PM
    #79
    Kyblack76
    Layton, Utah
    18 TRD O.R
    You got it,.. chief
  20. Aug 22, 2019 at 3:44 PM
    #80
    Living the dream
    Living the dream New Member
    ABQ
    2019 T4R Off-Road KDSS
    So pulled the trigger on the T9 unit. I just was over the stock Entune and didn’t want to fork out $1500 for the Sony unit. Might have been a mistake but what the hell, we will see. I’ll post when I get it and give a review.
    Sundy, kbp810, Normantaco and 2 others like this.
  21. Aug 23, 2019 at 7:38 AM
    #81
    akebruin
    akebruin New Member
    2018 4Runner TRD Off Road
    Thanks for all the great info. Is it easy to customize the background screen? Are there lots of options?
  22. Aug 23, 2019 at 10:34 AM
    #82
    Compromised 4Runner
    2018 4Runner SR5
    Yes it is. This is really just an android tablet in a vehicle. Anything you can do on your phone, you can do to this.
  23. Aug 29, 2019 at 5:32 PM
    #83
    Living the dream
    ABQ
    Okay so got the T9 head unit today. Ordered it on August 22nd so 7 days to SoCal. Install was reasonably okay, had a bit of trouble figuring out the back up camera but re-watched the wiring YouTube video a couple times and figured it out.
    Can’t get the steering wheel controls to work, double checked my connections but still nothing.
    The Apple CarPlay wireless connection just plan sucks. It continues to unpair itself with my phone then takes 10 minutes or more to reconnect. I may try the dongle route but shouldn’t have too if it worked as advertised.
    It shows every fingerprint you touch the screen with.
    It looks cool and a better screen than Entune for sure.
    I will try playing with it some more but as far as a recommendation goes, save you money! I’ll post back if I figure out the bugs.
  24. Aug 29, 2019 at 6:00 PM
    #84
    Mfavic89
    Mfavic89 New Member
    I had the same issues with the wireless CarPlay and bought the USB adapter on Amazon. It has worked flawlessly since then and have since been very happy with the purchase after being disappointed with the wireless CarPlay.
    jgcaps likes this.
  25. Aug 29, 2019 at 6:22 PM
    #85
    Living the dream
    ABQ
    Which adapter did you purchase? Link?
  26. Aug 29, 2019 at 6:55 PM
    #86
    Living the dream
    ABQ
    Okay feeling better about the purchase. Got the CarPlay to sync and stay synced but still some skips. Got the apps to work without disconnecting every time.
  27. Aug 29, 2019 at 7:34 PM
    #87
    onaquest
    onaquest New Member
    What did you do to get the sync to be more stable?
  28. Aug 29, 2019 at 7:46 PM
    #88
    Mfavic89
    Mfavic89 New Member
  29. Aug 29, 2019 at 8:47 PM
    #89
    Living the dream
    ABQ
    Okay cool thanks. And do you plug it into the OEM USB under the A/C or did you plug it into the AUX USB on the T9 unit? Did you have to download any app or software?
  30. Aug 30, 2019 at 8:42 AM
    #90
    Living the dream
    ABQ
    Just an update from one day of use. I found out Verizon wireless is not compatible with the T9. So if you have Verizon and want to add a line for the 4G sim you can’t. You will have to sign up with another service provider or turn your phone into a hotspot. The CarPlay just won’t connect in Bluetooth. Guess I’ll have to get the dongle. I researched it and it said you have to connect to the unit and to Topway, my phone finds Topway but it can’t connect to it.
