Swapping transfer manual lever in sr5
Discussion in '5th Gen 4Runners (2010-2024)' started by Beachgoing, Aug 15, 2022.
  1. Aug 15, 2022 at 4:44 PM
    Beachgoing
    Beachgoing [OP] New Member
    2015 T4R SR5
    Working progress.
    Let me start with saying I'm sorry if this has been asked and I'm positive it has, but for the life of me I can not find the thread. What makes matters worse is that swear I saw it before but can no longer find it, so if you answer is just a link to that thread than I would also be happy with that answer too.
    Now into the reason I am posting.
    I love my sr5 4unner but seriously wish I have the sweet ass lever to switch into 4 wheel drive! I could care less about MTS and Craw control.
    If I am willing to spend some money how much would it cost me to have a manual lever swapped? Also, is that something I could have the dealership do?
    Again, sorry if this has been asked and thank you for your time and patience. :)
    Slopemaster likes this.
  2. Aug 15, 2022 at 7:45 PM
    I agree with you, it would have been nice to have the manual transfer case shifter. My 97’ Tacoma had the lever. I do exercise it at least once a month. I’ve read that if you use it, you won’t have issues. Even the off-road trim has an electric actuated ADD and rear locker, so they still rely on electronics.
    My wife’s Sequoia has the electric controlled transfer case and she never uses it. As a result it will barely go into 4H and 4L no longer works. I believe all of the new Tacoma’s use the electric transfer case.
    As far as converting, it may be more trouble than it’s worth. But if you pull it off, I will be watching with interest.
    I would have gone with the Off-Road if it didn’t have the silly fake hood scoop, front and rear valances and the wagon rims.
    Beachgoing[OP] likes this.
  3. Aug 16, 2022 at 11:43 AM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    '24 ORP
    What's super lame is that the pre 13 SR5s had the lever
    Trail Runnah likes this.
  4. Aug 16, 2022 at 11:46 AM
    MeefZah
    Lexington, Ohio
    '24 ORP
    Agreed on the skewp and the valances but the wheels are great... And useful... And better than the SR5 or even PRO wheels for actual off road. Plus IMO they look BA Baracus.
    Thatbassguy and nimby like this.
  5. Aug 16, 2022 at 12:12 PM
    Very true, I just don’t like the look.
    MeefZah[QUOTED] likes this.
  6. Aug 16, 2022 at 12:19 PM
    GrantA
    North Carolina
    Fully locked 2020 SR5 Premium
    Maybe this is what you saw?
  7. Aug 16, 2022 at 2:37 PM
    It can be done but honestly it isn't worth it. The manual case still has the ADD front axle. The dealer will more than likely not touch a job like this.
  8. Aug 16, 2022 at 2:47 PM
    Beachgoing
    2015 T4R SR5
    Working progress.
    I appreciate your feedback.
  9. Aug 16, 2022 at 3:08 PM
    I think this needs to turn into a discussion on why ADD doesnt do much and why we should all want locking hubs manual locking hubs:D
    TN_FunRunner and 2ndGen22re like this.
  10. Aug 16, 2022 at 3:35 PM
    There is a guy in HI that offers a full locking up setup for ADD axle equipped Toyotas. It isn't cheap and you add another failure point to the drivetrain.
  11. Aug 17, 2022 at 12:16 AM
    So my understanding is that the axles spin when in 2wd no matter what, and what ADD does is just disconnect the axles from the front differential. Not sure if Im right though. If this is how it works, then I wonder if you'd really increase drag all that much by disabling ADD?
    I wish there was a cheap way to retrofit manual locking hubs. I wonder if austrailians get locking hubs on toyotas that we could use as a starting point for the 4runner. Disconnecting at the hubs would make the loud needle bearing a thing of the past.
    Back on topic…if I wanted to convert my electro-knob equipped SR5 to a physical lever, I would seriously consider using that money towards retrofitting manual locking hub disconnects instead ;):D:D
    2ndGen22re and Beachgoing[OP] like this.
  12. Aug 17, 2022 at 3:42 AM
    Beachgoing
    2015 T4R SR5
    Working progress.
    That might be worth looking into.
    2ndGen22re likes this.
  13. Aug 17, 2022 at 7:19 AM
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
    I added Toyota Asin manual hubs on my 90 with ADD and have had them for decades. Zero wear on the CVs on street driving and a overlooked benefit as it allows 2wd low range which in the 22RE’s case helps a lot with power at elevation on twisty mountain trails(more fun too). I put Dynatrac hubs on my Cummins 12 years ago as well, drives like a 2wd on the street without all the axle components/differential/drive shaft spinning, no ADD here, everything(big stuff) spins back to the transfer case without the hubs and I think it is worth at least 1mpg.
    I would love to have them on my new 4R and it might make a difference in the wheel shimmy.
  14. Aug 17, 2022 at 3:22 PM
    So what is all involved in retrofitting hub disconnects? It would need new spindles and CVs right to fit the hub, right? What about wheels? I honestly like this idea and could see myself going down this rabbit hole.
  15. Aug 17, 2022 at 3:24 PM
    GrantA
    North Carolina
    Wouldn’t it be better to just go with a SAS and call it done? This conversion doesn’t sound easy and will be a lot of work in itself.
  16. Aug 17, 2022 at 3:52 PM
    Single axle? Is it really that much of a job. Yikes!
  17. Aug 17, 2022 at 3:55 PM
    2ndGen22re
    CR
    Carson Valley, NV
    I only can say the 1st and 2nd gen Toyota hub conversation is a piece of cake. Take off the fixed hub and put the selectable one on, no other parts required. There is a difference between the Toyota solid axle and IFS manual hubs, they are not interchangeable. It takes almost longer to jack up and R&R the wheels than installing the hubs.
    The Cummins was a bit more involved, but not bad. New outside yokes/spindles.
  18. Aug 20, 2022 at 1:38 PM
    Beachgoing
    2015 T4R SR5
    Working progress.
    How intensive is the job? Does it require a ton of work? If the transfer cases are so similar it seems like it wouldn't be to hard. Also, what is the difference between 2013 and 2015 sr5 transfer case?
  19. Aug 20, 2022 at 1:48 PM
    Pavo
    Pavo New Member
    A lot of tacoma guys (all 2nd and 3rd gen tacomas including trd have the knob) do the fj cruiser transfer case swap. I haven't looked too in depth but didn't seem prohibitively complicated
  20. Aug 20, 2022 at 1:49 PM
    You'd need the entire case unless there's a conversion kit and then you need to trick the 4WD ECU to think nothing changed.
