Suspension lift
Discussion in 'General 4Runner Talk' started by 4Runnernewkid, Jan 6, 2025.
  1. Jan 6, 2025 at 6:12 PM
    4Runnernewkid
    4Runnernewkid [OP] New Member
    2013 white 4runner
    None
    I’m looking to put a 2” front and back suspension lift on my 2013 4Runner. I’m looking for some information. At what point do I need to start worrying about drive train, sway bar and other geometry issues? Anyone have information on this?
    Shredder likes this.
  2. Jan 6, 2025 at 6:33 PM
    Shredder
    Shredder New Member
    tip of the mitt, Michigan
    23 OR
    Tires, shocks
    From my brief research on the subject i seem to remember 2” as a line to stay under so as not need adding other parts. I ended up with a cheap but good shocks (bilstein 5100’s) set at .85 in the front with stock coils. My biggest concern was replacing the stock shocks. But these shocks can be set for a bigger lift in the front if desired. For a rear lift you need different coils.
    I’m sure others will give you a lot more detailed info. Good luck
  3. Jan 6, 2025 at 9:38 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    ^5100’s are a great start for a mild lift.
    I’d stay under 2.5” of lift. Many people shoot for 2.5 front 1.5 rear. Still retains a bit of rake but it’s a good look. Especially with a meaty 33” tire
  4. Jan 7, 2025 at 4:05 AM
    welcome
  5. Jan 7, 2025 at 6:35 AM
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    Welcome fellow 4Runner enthusiast!
  6. Jan 7, 2025 at 4:23 PM
    4Runnernewkid
    2013 white 4runner
    None
    Thanks all. Hopefully I can get a little more info before I pull the trigger.
  7. Jan 7, 2025 at 4:53 PM
    Yep check out my info page and my set up. Love it!
    i think once you go over 2.5 or 3” then you may need UCAs and start watching for geometry issues
  8. Jan 7, 2025 at 5:27 PM
    Shredder
    Shredder New Member
    23 OR
    Tires, shocks
    Try you tube videos. I watched a ton and learned a lot after i started driving my 4runner. That’s the biggest reason i stuck with a small lift and new shocks, stock size tires. With just those 2 things, shocks and tires it’s a very capable truck that suits my needs nicely. Although big lifts with big tires look great.
  9. Jan 7, 2025 at 6:11 PM
    they do! Mine is only a 2” lift with 285s
    Shredder[QUOTED] likes this.
  10. Jan 7, 2025 at 6:42 PM
    4Runnernewkid
    2013 white 4runner
    None
    What’s the kit you’re using? That sits awesome! I’m looking to put a 2” front and back lift on mine..
  11. Jan 7, 2025 at 6:51 PM
    Thanks!
    2” lift Bilstein 6112 w/600 lb coils front, 1.5” lift Eibach T13 coils rear, Bilstein 5100 rear shocks, 285/70/17 Falken WP AT3, Energy Suspension front bumpstops, Durobumps 4.25” rear
