Stripped trans drain plug question
Discussion in '3rd Gen 4Runners (1996-2002)' started by josh3rd, Apr 5, 2021.
  1. Apr 5, 2021 at 3:50 AM
    josh3rd
    josh3rd [OP] New Member
    Joshua
    New owner of a 2000 4runner
    Good morning members. It's a beautiful predawn day here in S.E. Pennsylvania. As some of you may know, my trans pan drain plug bolt is stripped and leaking fluid. Not radically but noticeably.
    My question is:
    If I am going to perform another trans flush say today, is it ok to rethread the trans pan drain plug hole after removing the stripped bolt and draining the trans fluid obviously and after rethreading, refill trans and flush the fluid out and the rethread shavings would mostly be removed an the shavings that don't get purged would be ok because of the new filter? or something? Thanks in adv
    cross posted
  2. Apr 5, 2021 at 6:58 AM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    If it can be saved by running a tap through it you should be fine. After you tap it use a small magnet(unless it's aluminum?) to help pick up any shavings before you flush it. Just make sure the threads have not been compromised to the point of being unusable. If that happens you should install a red head or similar device. thinking out loud here.
    Edit: If it is aluminum? it isn't as easy to repair. In which case you might look at oversized oil drain plugs…they are designed to cut their way in and oversize the hole for you and are designed for a tighter tolerance.
    josh3rd [OP] likes this.
  3. Apr 5, 2021 at 9:02 AM
    josh3rd
    Joshua
    sir, what is a "redhead"? and how does one go about using it?
  4. Apr 5, 2021 at 9:29 AM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    If you have a NAPA auto parts in your area I would strongly suggest you visit them.
    In the meantime Google this > transmission drain plug repair
  5. Apr 6, 2021 at 1:36 AM
    Ahkouchi
    Ahkouchi New Member
    Why not just drop the pan since you're doing a flush anyway. Tap it while it's off the truck, clean it with some rags and brake parts cleaner, dry and reinstall?
  6. Apr 6, 2021 at 2:25 AM
    josh3rd
    Joshua
    Laziness. And because I had already removed it, prior to being stripped, replaced filter and gasket.
  7. Apr 6, 2021 at 9:48 PM
    Ahkouchi
    Ahkouchi New Member
    lol understood. but don't let laziness and a gasket prevent you from doing a through job. say you mess up and some shavings stay in and mess up your tranny... you're going to wish you took the extra hour to take off the pan to clean it and tap it correctly..
    josh3rd [OP], negusm and Toy4X4 like this.
  8. Apr 12, 2021 at 9:27 AM
    josh3rd
    Joshua
    Sorry for the tardy response but with everyone's help, I have saved my girl from the problem of the milkshake and other things...so far, knock on wood. The only thing that i have a small issue with is my local NAPA not having the correct size of transmission drain plug.
    This is embarrassing to admit let alone even write but money is so tight that I couldn't even order a OEM transmission drain plug with the crush washer from anywhere because bills & mortgage had to come first. I just have to wait till not this Wednesday but the next one, to order it and the plastic air intake hose that connects to the aluminum intake at the top of the motor. It has a big crack that goes 1/2 way around it. As for the plug, I used the one that was originally in it along with a rubber grommet and washer. No leak so far but I don't want to push my luck. What is the exact dimensions of it again if anyone knows please.
    Well that is all for now. I am just wire brushing the surface rust off some of the undercarriage and using rustoleum spray paint to give her some protection.
    Again, members, thank you for all your help. Much appreciated
    cross posted
