Steering wheel twitching at low speed
Discussion in '4th Gen 4Runners (2003-2009)' started by T92, Jan 20, 2023.
  1. Jan 20, 2023 at 3:11 PM
    T92
    T92 [OP] New Member
    2023 Black Tacoma SR5 SX
    Hi, today the steering wheel started twitching left and right suddenly while driving at low speeds of 20-30MPH. I call it twitching because it didn't just steer, it was twitching. Even if I let it go and kept driving slowly on the straight road, it kept twitching left and right little by little, but the vehicle didn't move toward either side. Even when I held the wheel it was strong enough to twitch still.
    First thing that came to my mind was tire pressure but all is good..
    Any ideas? Has anyone had this issue? I haven't taken look yet, its late night now.. I sure hope it has nothing to do with some rust on the frame.
    Thanks.
  2. Mar 6, 2023 at 12:03 AM
    GreatWhitePig
    GreatWhitePig New Member
    Inner/outer tie rods. Check by jacking up and checking for play on wheel at 3 and 9 o clock.
  3. Mar 6, 2023 at 2:22 AM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    Did it continue to twitch, or just do it on that roadway?
    if it only did the one time then it could of been the road, or maybe some road debris got stuck between the brake pads and rotor, and nothing to worry about.
    If it not and it doing it all the time or off and on, it could be several things, as mentioned tierod ends, brake calipers starting to seize up, warped rotors, brake pad build up on the rotors, wheel bearing/s going bad, or road debris still stuck in the brakes.
