Steering Rack and Pump Questions
Discussion in '3rd Gen 4Runners (1996-2002)' started by Firstoneman, Aug 12, 2019.
  1. Aug 12, 2019 at 6:04 PM
    Firstoneman
    Firstoneman [OP] New Member
    David
    Mozambique
    99' Surf 4x4, Auto, 3RZ w/235K+ km, Japanese RHD now rolling in Mozambique!
    UniChip
    Greetings.
    I have a 99 Surf/4Runner. I went into a shop to discuss installation of Dobinsons shocks and springs all the way round. Guy rolled underneath because I also asked to have bushings replaced for steering rack. He came out suggesting a rack and pinion replacement. Being a novice regarding rack and pinion I sort of have to take his word for it. There is some movement in a tie rod when you grab it and turn the wheels, but I don't really know if it's supposed to be like that or not. The boot on driver's side (psgr side in US) has no clamp on the inside end either.
    The vehicle has 190K on it and the roads are tough here in Mozambique and South Africa. So, I want to know how do I really determine if the R&P needs replacing? Also, what about the power steering pump? Should I consider replacing it since all this is going to be disconnected if I replace the R&P?
    Also, recommendations about which R&P parts to buy too. Not sure what the independent shop will source here. Is this an overly difficult job on this vehicle? Wondering how much time the shop should spend on it?
    Thank you all.
  2. Aug 16, 2019 at 2:34 PM
    jross20
    jross20 New Member
    Man my rack "supposedly" leaks as well. I'm still unsure.
    I'm along for the ride haha
