Starting problem
Discussion in '3rd Gen 4Runners (1996-2002)' started by 1bailey, May 11, 2016.
  1. May 11, 2016 at 2:47 AM
    1bailey
    1bailey [OP] New Member
    I recently bought a sweet '01 SR5 and it's checked out great so far. My daughter tried to start it yesterday and there was nothing. I wasn't home so I told her to check the battery terminals. Sure enough, the negative was loose. She twisted it down and the lights/chimes came on, however, still nothing on the motor. I had her remove the terminal and re-attach it and the horn started going off in alarm fashion, but still nothing on the motor. I'm thinking the factory alarm system disabled the start. Any ideas?
  2. May 11, 2016 at 5:47 AM
    ramonortiz55
    ramonortiz55 New Member
    Ramon
    Do you know if the starter clicks or tries to turn the motor when attempting to start it?
  3. May 11, 2016 at 6:00 AM
    1bailey
    No sir. Nothing. Just the horn blaring, and there is power to the accessories.
    OK problem solved. Simply push the little red button on lower dash a few times and apparently that resets the disable function.
