SPC UCA failures
Discussion in '5th Gen 4Runners (2010-2024)' started by 2021venture, May 4, 2023.
  1. May 4, 2023 at 6:40 AM
    2021venture
    2021venture [OP] New Member
    Todd
    2021 Venture
    I have SPC UCA and went with them because of adjustability. The alignment went smooth and truck rides nice meeting my expectations. I have read reports of them failing which initially had me leaning towards JBA. Anyone have experience with SPC failing or what to watch out for? I currently grease the driveshafts every 5k oil changes and will grease them also.
    kolter45 likes this.
  2. May 4, 2023 at 6:48 AM
    OverRunner
    OverRunner rebmeM weN
    Jared
    Denton, TX
    ‘21 ORP w/KDSS
    Disclaimer: Have not used these, and don’t know anyone personally who does. What I share is the fruits of my research (a several month-long comparison of over 40 UCA options).
    They seem to have a decent warranty if you cover all your bases at purchase time, but I have read stories of warranties not being honored because of a lack of registration/receipt.
    I’ve also read that if you off-road it hard, the control arm can snap where the arm meets the bushing. I don’t remember reading about any of them failing prematurely from strictly on-road use.
    They seem to be the perfect option for the light-duty crowd given their weight, cost, adjustability, etc.
    2021venture[OP] likes this.
  3. May 4, 2023 at 7:47 AM
    I have them on the shelf for my Runner. I don’t think they have had any recent issues with them and I didn’t have issues with them when I ran them on my Tacoma.
    MyWyfsRnnr likes this.
  4. May 4, 2023 at 7:48 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    I've ran SPC UCAs for 2 years, they've been great for exactly what OverRunner outlined.
    I have 3/2 Bilstein suspension lift, upgraded springs, 17x9 0/4.5, LT285/70R17 E, little bit of added weight. SPC arms and ball joints and bushings held up with all that.
    What often goes on people is the ball joints and ball joint boots. My boots never ripped, but I blew out one grease seal before from way over pumping the grease gun from inexperience.
    Recently replaced tie rods, and my shop said you got 6 months left on those SPC ball joints. I bought a replacement kit from Lordco $200-300 gunna do it myself
    MyWyfsRnnr and OverRunner like this.
  5. May 4, 2023 at 7:49 AM
    They had issues during covid because of manufacturer changes due to supply chain, and seem to have now worked out the deficiencies with new stock. From what I gather
  6. May 4, 2023 at 12:50 PM
    blksubykid
    blksubykid New Member
    4 years and over 30k miles...no issues. I just replace the ball joints as preventative maintenance tho
  7. May 5, 2023 at 10:36 AM
    4runwildintoparadise
    4runwildintoparadise New Member
    Vancouver, BC
    2021 4Runner TRD Off-road
    Suspension: Dobinsons MRR Modular Panels: Rago Fabrication Tires: Falken Wildpeaks 275/70/17
    Mine were in a batch that was received and failed. When you grab the UCA and test it for any movement or play, it would jolt and move around as well. Ball joints would also spew grease every time i started to drive or take it off on a dirt road. This was even installed by a professional company for more comfortability of having it done properly. Multiple vehicles that had them installed after on the same batch had the same problem.
    I ended getting JBA UCA's and yes they aren't like the SPC's but they are similar and I have had nothing but fun with these ones. No problems up to date and I go out just about every weekend to get my fix, so my 4Runner is well used when it comes to it's suspension.
    OverRunner likes this.
  8. May 5, 2023 at 11:46 AM
    kolter45
    Denver
    Inferno Pro & BRM Sport
    My SPCs on my taco were the bad bushings from 2019. It was like pulling teeth to get them to confess & send me new ones. Customer service blows & if you’re assigned “Todd” … good luck. He’s very difficult to work with. I wish I bought JBAs
  9. May 5, 2023 at 11:48 AM
    Vancouver, BC
    What did you end up going with?
    kolter45[QUOTED] likes this.
  10. May 5, 2023 at 5:37 PM
    kolter45
    Denver
    I have the replacement bushing they sent me. Pain in the ass to get new bushing into them. They’re fine now but not a fun experience
  11. Jul 8, 2023 at 8:55 AM
    Heckler44
    Heckler44 New Member
    Sean
    2021 Venture Silver
    My SPCs started getting bad at under 5k miles. Installed at a professional shop in Commerce City, CO. Took my 4R in for its first tire rotation and they pointed out that the SPCs were about shot. I worked with SPC, $800 later had a complete new set. IMO I don't think I should have had to pay warranty replacement costs for something they knew was an issue. Complete new set of SPCs on now. I will give them a chance but lost a lot of faith in them. I had SPCs on my Taco for over 8 years with no issues what so ever.
    kolter45 and kmeeg like this.
  12. Jul 8, 2023 at 9:01 AM
    Thanks for sharing this to save others time and money. I will keep them out of my list for my next project.
    raimieb and kolter45[QUOTED] like this.
  13. Jul 8, 2023 at 11:51 AM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
    I read about too many bad experiences with the very common SPC UCA's. That's why I chose the tried and true Dobinson's that have 3 degrees of castor correction built in. You have to have at least 1.5 inches of lift to be able to use these but they are robust and reliable.
    Here is what they have to say:
    • Complete kit for both left and right hand side, includes new ball joints (Pressed), OE style rubber frame bushings (installed), and washers
    • Has 3 degrees of caster built in, no adjustability or settings required
    • Made from HSLA (High Strength Low Alloy) Steel, 5mm (0.2") wall thickness, and powder coated black
    • Works for any lift height of 1.5" or more. Any height less than that, a proper wheel alignment may not be able to be achieved
    • Uses replaceable Japanese-made Sankei 555 ball joints, fully sealed for maintenance free life
  14. Jul 8, 2023 at 12:31 PM
    Please share if anyone knows lifted vehicle friendly UCAs that does not require maintenance like the Toyota UCA.
    If there's any long travel friendly no maintenance required ULA and LCA available it would be even better for me to take a look. Haven't decided about long travel yet due to high maintenance.
  15. Jul 8, 2023 at 4:54 PM
    nova
    nova New Member
    mike
    Prescott Valley - Arizona
    slightly modified LE
    Long travel friendly? If you’re going Long Travel you’ll be buying after market upper and lower control arms. Not SPC.
    Also, any Long Travel I’ve seen will require some maintenance (uni-ball vs ball Balljoints).
    I think it’s worth it if your activities benefit from Long Travel. It is an investment as you can no longer use any OE front suspension components.
    Good luck!
  16. Jul 9, 2023 at 4:44 AM
    2021venture
    Todd
    2021 Venture
    What I find odd is many well respected off road shops recommend SPC. I was not going the low cost route but trying to build a quality setup. I had SPC recommended with Elka's. Any guesses why shops are recommending SPC? I do agree Dobinson's look like very solid UCA. For a stronger off road UCA there are better than SPC but the adjustability of SPC is nice for easy alignment.
    travelinscout likes this.
  17. Jul 9, 2023 at 5:02 PM
    I had a local 4x4 shop give me a quote on a Bilstein upgrade. They also suggested SPC UCA’s.
    Ultimately, I decided to forgo the suspension/lift and leave it stock.
    djb1 likes this.
  18. Jul 10, 2023 at 12:28 PM
    @2021venture
    @Slopemaster
    My two cents; Bilstein's, SPC's, and upgraded springs were my local shops #1 recommendation for my budget and driving. It's a highly tested 4Runner setup for them in BC, and SPC's in particular have been solid for years. It's really only the covid manufacturing material changes that are a blemish on their record. They're still known for good quality and longevity, hence widely recommended.
    That being said
    2-3 years out of my covid SPC's and the balljoints have been given 6 months to live by my local guys. I already bought the SPC balljoint replacement kit on discount from Lordco. Right now boots leak a little grease I have to wipe each week.
    And I've posted on here for help couple times now - there's a grinding/rubbing noise sometimes when I turn hard left or right going quick up an incline. Not getting any rubbing evidence elsewhere. Could this be the ball in socket metal on metal?
  19. Jul 30, 2023 at 5:40 PM
    Any of you good folks know if you can swap out SPC UCA "OG" zerk greased balljoints, for the new sealed boot model? I would think there's a new replacement kit compatible, just like the OG replacement kit I already purchased.
    redneck pilot and Old Tanker like this.
  20. Jul 30, 2023 at 6:53 PM
    kolter45
    Denver
    The ones meant for the old tubular uca? :notsure:l’d call them & ask. That’s the only way to tell for sure
  21. Jul 30, 2023 at 7:16 PM
    kolter45
    Denver
    I want to explain the process for return if you buy SPC UCAs & have issues
    If you buy them - it must be a dealer on SPCs sponser list. I got mine from a friends off road shop & they gave me shit & in the end said I was okay. They’ll ask for a receipt & double check the store isn’t selling the item below the price they demand. So talk to the person you bought it from first.
    I had to submit a photo before the UCAs were put on my truck. I was lucky & had snapped a photo of them brand new. I used that & it cleared me.
    Then I sent a video of the bushings making noises installed & it was the last step.
    They make a great product if it’s problem free! Again, this was on my taco
    djwantke likes this.
  22. Jul 30, 2023 at 10:56 PM
    Thanks man!
    I've been one of the lucky ones, my balljoints have lasted 2.5 years and I have virtually no play when jacked from lca, as well as prybar under tire. They leak grease tho, especially the one side that I blew the seal over greasing like a rookie :).
    When you say bushing were making noise, you talking about the two bushings, or the balljoint in the boot?
    Also what did the noise sound like!?
    I'm trying to diagnose my "grinding" noise
    TY
  23. Jul 31, 2023 at 9:27 AM
    update
  24. Jul 31, 2023 at 6:31 PM
    kolter45
    Denver
    The 2 bushings for the uca bolt. They had a bad batch for about a year. I bought mine because I wanted to support local. It’s was that notorious clunk noise pulling up to a stop. Even my neighbor was like wtf man! He’s an f150 guy but loves my Tacoma. It’s the 2.5 gen with the 4.0 just like my 4Runner. Lift looks awesome now but it was some work getting this far
  25. Jul 31, 2023 at 9:21 PM
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
    I have installed a ton of them and I really like them for the adjustability etc. I also like carrying one replacement for the trail that is conceivable to replace with limited tools. You aren't changing a uniball on the trail very easily haha. I had a SPC ball joint failure due to not greasing sufficiently. Totally on me. I've been 100% happy with mine and have not gotten a defective one out of the 10+ I've installed for customers. (Not using it doesn't happen, I just have not seen an issue yet; to be fair, I haven't seen any issues with the delta joints either).
    Superdave1.0, djwantke and kolter45 like this.
  26. Feb 20, 2024 at 1:34 PM
    Horhay
    Horhay New Member
    North Carolina
    2015 Inferno 4Runner TRD Pro
    Saw this thread and wanted to contribute. I got less than 20K miles out of mine before the bushings started to shift around and the ball joints failed. SPC offered to partially warranty them but after the $275 core charge plus the cost to install and an alignment, I'm out over $700.
    For reference, I've got a 2015 TRDp.
  27. Feb 21, 2024 at 1:03 PM
    new sealed joints done
  28. Feb 21, 2024 at 2:23 PM
    I’ll stick with my OEM control arms. No maintenance or squeaking.
    semprenissart, djwantke and Rocko9999 like this.
  29. Feb 21, 2024 at 2:39 PM
    Very true, OE quality often doesn't have these notorious aftermarket issues.
    I ain't using OE control arms on a 3" lift and 285's on Spidertrax tho :p
  30. Feb 21, 2024 at 2:50 PM
    2021venture
    Todd
    2021 Venture
    I have convinced myself to go with Dobinsons UCA if or when the SPC fail. What I still find odd is it seems like most well respected off road shops recommend SPC. My assumption is this is based off of easy alignment adjustments.
    MyWyfsRnnr, Rob41 and djwantke like this.
