Spare tire?
Discussion in '5th Gen 4Runners (2010-2024)' started by mbean, Jul 18, 2019.
  1. Jul 18, 2019 at 9:28 AM
    mbean
    mbean [OP] New Member
    2017 4Runner Off Road
    3" lift, upgraded exhaust, Slee rock runners, TRD aluminum wheels and offroad tires
    I have a 2017 4Runner Off Road with 17" aluminum wheels and offroad(ish) tires. Three questions:
    1. Will the stock spare tire work with the other three wheels?
    2. If I buy a 5th wheel and tire to match will it fit underneath where the stock spare is now?
    3. Anyone know where I might find a used single wheel and tire for sale?
    Thanks!
  2. Jul 18, 2019 at 9:31 AM
    Dark Knight
    Dark Knight Get off my lawn
    1. Why would it not work
    2. Yes (assuming 285/70/17 and smaller size)
    3. Facebook market place.
    Thatbassguy and WallyT4R like this.
  3. Jul 18, 2019 at 9:53 AM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    Stock spare rim is 7" wide so although it'll work with larger 285s it isn't perfect. I use a 285 on it and don't really care... but technically it'll squeeze the tire into a slightly taller profile than if the same tire was mounted on your stock 7.5" wide OR wheels. Personally I wouldn't mount a nice aluminum wheel under the truck, it's going to get banged up with road debris and rocks.
  4. Jul 18, 2019 at 10:03 AM
    jester243
    Dan
    Spokane, WA
    the spare also does not have a TPMS in it, if that matters to your setup.
  5. Jul 18, 2019 at 10:05 AM
    WallyT4R
    WallyT4R New Member
    Welcome! :thumbsup:
  6. Jul 18, 2019 at 9:33 PM
    aroyalsfan
    aroyalsfan The Owner
    Kansas City
  7. Jul 19, 2019 at 8:55 PM
    redneckj
    redneckj New Member
    2018 TRD Off Road 4Runner
    working on it
    I have the 275/70/17 AT3W's installed on my 4runner. I found a brand new take off 255/75/17 BFG and installed it as my spare tire. Fits under the 4runner perfect and it is tucked under a little more than the stock spare. Found the BFG on offer up for $40. SCORE!!
  8. Sep 1, 2021 at 11:00 AM
    PJSnow
    PJSnow Always Learning
    PJ
    New York
    2018 Cavalry Blue TRD Pro
    Bringing this back just to confirm a couple things:
    1. 285s on the stock steel spare wheel fit fine in the factory space location (under the rear)?
    2. Do 285s fit better in the stock spare location when mounted on SR5 or TRD Off Road wheel?
    3. If using SR5 or TRD Off Road wheels as a spare, the only "modification" is the removal of the center cap correct?
    I'm looking at picking up an SR5 wheel to use as a spare instead of mounting 285s on the stock steel spare wheel and want to confirm everything before I make the purchase.
  9. Sep 1, 2021 at 1:13 PM
    MeefZah
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    1. Yes
    2. No observable difference, so.... no
    3. Correct, you would need to pop off the center cap so the hanger can 'swim' through the opening and draw tight against the wheel
    Thatbassguy and PJSnow[QUOTED] like this.
  10. Sep 3, 2021 at 10:31 AM
    MAXIM
    MAXIM New Member
    Why mount on spare steel, just get set of 5 wheels. I'd careless about additional few hundred bucks if already spending few grand.
    casafun likes this.
