Spare Tire Removal
Discussion in 'Wheels & Tires' started by Boatanchor, Jul 29, 2023.
  1. Jul 29, 2023 at 9:55 AM
    Boatanchor
    Boatanchor [OP] New Member
    Buddy
    2012 SR5 4Runner
    Hi, I have a stock 2012 SR5 of which I am the original owner. It’s been a great car (125k miles) …absolutely no issues…just tires, brakes, fluid changes, windshield and a battery. Last week I had a flat tire. Went to change flat with the spare and the damn underneath spare would not lower. The chain mechanism was apparently rusted/broken. I’ll confess spare has never been lowered in 125k miles. Now, I’ve got to tow car to a shop to cut the tire holding bracket or whatever and remove/replace the rusted mechanism. My suggestion for all “stock” drivers….maybe on a nice day take the time to lower your spare and lube the chain mechanism and check spares’ air pressure. …just a precaution.
  2. Jul 29, 2023 at 10:21 AM
    wingo
    wingo New Member
    2020 Venture
    Routine maintenance is a must. Even things you never use. My dealership checks the spare when I rotate the tires.
  3. Jul 29, 2023 at 11:26 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    That sucks to hear, feel for ya.
    I just lowered my spare first time since buying new in '16, 89,000kms. Luckily no probz. But ima lube it now.
    Did you try "everything" before getting a tow and writing it off as needing to be chopped?
  4. Jul 29, 2023 at 11:36 AM
    colbydog
    colbydog New Member
    Massachusetts
    2023 Magnetic Gray ORP
    My truck’s new, but will be lubing the chain/fluid film and getting one of those discs that snug up against wheel to keep most debris out. But I’ll probably be doing a five tire rotation. No one does that anymore, but I think, along with the above, it ensures you have a serviceable spare, and you can get to it.
    Sorry for your bad luck though
    Spare Parts and Firefly21 like this.
  5. Jul 29, 2023 at 11:48 AM
    Add this to the list of things I haven't thought about protecting, but Toyota world has. My kids have a father who will teach them these things lol
    2018 Limited likes this.
  6. Jul 29, 2023 at 11:57 AM
    Great idea.
    That’s a big can of worms you’re opening. I think you’ll find the spare wheel is steel and doesn’t match the others. The spare also doesn’t have a TPMS sensor in it. FWIW the owners manual specifies a five-tire rotation for 4Runners with 20 inch wheels.
  7. Jul 29, 2023 at 5:32 PM
    Oakboro, N.C
    Luckily the 5 tire shuffle has enabled me to keep an eye on this mechanism. Have the 20" wheels ans wanted to maximize the spare for once.
    Captain Spalding likes this.
  8. Jul 30, 2023 at 4:03 PM
    TrailSpecial22 New Member
    PA
    soak that mother down with some HD pentrating spray and pray!
  9. Mar 21, 2024 at 8:27 AM
    BantamEddy
    BantamEddy Grand Poo Ba
    2021 Silver ORP
    Dobinson MRRs, Method 701s, Greenlane Bumper, Sherpa Winch, Black Oak Lightbar Greenlane Roof Rack & Ladder
    Just went through this myself! Just as I was beginning to wonder how much force the Toyota provided rod could bear, the rust gave. This is after a PB blasting. So thankful, this was in my driveway. I got a dang utility knife blade in one of my brand new wildpeaks. :mad:
    3JOH22A likes this.
  10. Mar 21, 2024 at 9:08 AM
    PA
    Frustrating as hell!!
    BantamEddy[QUOTED] likes this.
  11. Mar 21, 2024 at 12:03 PM
    steelevo
    Utah
    This is a good reminder OP!
    I lower my spare and check the tire condition and pressure with the 5k tire rotation.
  12. Mar 21, 2024 at 5:24 PM
    2018 Limited
    2018 Limited New Member
    BDR
    2018 Limited
    “My kids have a father who will teach them these things lol”
    “When I was a young man my father didn’t know anything but as I get older I realized boy has he learned a lot. “
  13. Apr 15, 2024 at 9:24 AM
    laxman09
    laxman09 New Member
    Mahoning Valley, OHIO
    I have chain on my spare sprayed during my yearly FF undercoating.
