Spare stored tire inside cabin cargo area
Discussion in '5th Gen 4Runners (2010-2024)' started by Ctreg, Nov 2, 2024.
  1. Nov 2, 2024 at 9:04 PM
    Ctreg
    Ctreg [OP] New Member
    Does anyone think it would be possible to run the chain from the spare tire pully up into the rear cargo area through the metal floor use it to cinch down the spare tire inside the truck?
  2. Nov 2, 2024 at 9:12 PM
    Possible? Sure, but you’d be better off figuring out an alternative method before cutting holes in your 4Runner.
    (For rare use I’d probably ratchet strap it down to the tie downs and keep it behind an upright seat, for a more permanent solution you can look into building a metal frame to slide it into.)
  3. Nov 2, 2024 at 9:12 PM
    Not really if I’m understanding your question correctly. You’d have to cut a hole in the floor for the chain, cut the pulley system off the frame and remount it upside down somehow. And even if you could, you wouldn’t want to be because the frame and body flex differently. Much easier to figure out how to secure the tire from the inside.
    Thatbassguy and NeverTooLate71 like this.
  4. Nov 2, 2024 at 9:19 PM
  5. Nov 2, 2024 at 9:24 PM
    Don't need a hoist when going with gravity instead of against gravity. Either use a Y-shaped ratchet strap or bolt a Yakima spare tire mount to your floor: https://www.amazon.com/Yakima-Spare-Carrier-Cargo-Baskets/dp/B0012SAB30
  6. Nov 3, 2024 at 1:31 AM
    joshdub
    joshdub New Member
    2020 TRD ORP
    Dumb but sure
  7. Nov 3, 2024 at 6:51 PM
    alittleoff
    alittleoff New Member
    Steve
    406
    '16 TP
    Tires stink. That's why mine stays in the factory location.
    And what if you get a flat driving down a cattle country road.:notsure:
    Well then again, some might like it.
  8. Nov 3, 2024 at 7:21 PM
    RSG sliders, Yakima Megawarrior basket, Black Rhino wheels, SOS Streamline bumper and skids, Warn VR EVO10S winch, OME MT64, Bilstein rear lift coils, Rigid Dually SS ditch lights, SR light bar, and Diode Dynamics SS3 fogs.
    The smell goes away after awhile. :D
    I hadn't really thought much about having to put a dirty flat in there, though. I suppose a tarp would be a good thing to have in that situation.
    alittleoff[QUOTED] likes this.
  9. Nov 3, 2024 at 8:03 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Mods? Don’t ask… Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS extended travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Diode Dynamics XPR reverse bulbs LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    My buddy built a little spare tire platform in the back to have his 35” spare sit up right back there, secured with ratchet straps. Took up a lot of space so he eventually welded in the swingout from 80% off road.
    This is kind of what it looked like:
    I’d ditch the chain idea. I don’t think cutting a hole there and making that mechanism work for that configuration makes much sense personally
  10. Nov 3, 2024 at 11:06 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Noo you REALLY don't want to be doing this. Creating spaces for moisture and water to get in and permanently modding something that no one would want which would really ruin your resale value.
    Why do you want to do this? What are the drivers? What do you want to get out of this?
    steelevo likes this.
  11. Nov 4, 2024 at 6:58 AM
    Manhattan
    Manhattan New Member
    Really only two places for a spare on 4Runner - stock location with stock system to access/secure it, or a bumper-mounted tire carrier/swing-away
    Sure, you could put it in the back and take up a lot of space while making the truck smell like sh*t. And, you could put the spare on your roof, raise the center of gravity and when you need it and drop it off the roof rack, you can watch it bounce 100 yards down the trail and almost hit three trucks before coming to a stop...
    (Not me, but I was right there yelling "STOP!" )
  12. Nov 4, 2024 at 7:04 AM
    2021venture
    2021venture New Member
    Todd
    2021 Venture
    Most of the time I leave it under the truck. This past trip we stayed in a cabin so had more room in the rig. It worked well anchoring down to floor tie downs. Never moved with plenty of off camber moments others in convoy had stuff hitting them in the head.
    Thacrow, icebear and Thatbassguy like this.
  13. Nov 4, 2024 at 7:17 AM
    It's actually not that bad. It only smelled when it was new.
    Plus, It's not all scraped up and dirty from being underneath. And, I don't have a tire swing to deal with every time I want to get into the cargo area.
    tk421, Thacrow, 1SilverRunner and 3 others like this.
  14. Nov 4, 2024 at 7:20 AM
    I was just thinking, may be having the tire on the passenger side would be little better? Help teeny tiny big with weight balance? Surly nothing closer to battery weight + 23gal of fuel.
  15. Nov 4, 2024 at 7:30 AM
    It might, but it's way more visible on the passenger side. On the driver's side, I barely notice it.
    I also have a bunch of recovery gear and tools underneath the platform on the right, which probably weighs more than the tire.
    kmeeg[QUOTED] likes this.
  16. Nov 4, 2024 at 7:34 AM
    Factory spare location in my 97 Grand Cherokee was standing up in the cargo area on the driver's side. It definitely took up room, I removed it a few times when hauling stuff.
    SUPER easy to get in and out. It had a factory cover on it, so it didn't smell until I replaced it with a new matching spare when I upsized to 31s. It didn't last long, but I'm weird and like new tire smell.
    The cover had a zippered pocket, I stored my recovery strap inside the wheel.
    Agree the best location is a swing out. I don't have confidence mine would even crank down at this point after 10 years in New England.
    I carry a compressor and a plug kit, the spare is the last resort.
  17. Nov 4, 2024 at 7:39 AM
    Manhattan
    Definitely driver's side for visibility
  18. Nov 4, 2024 at 7:40 AM
    On the other 4R site, there was a guy wanting to mount a 35 under his, i did a bunch of measurements and found that with slight modding you can put a 35 in the stock location.
    I have 2 4R and run a 32.5x11.5 and a 33x12.50 in stock location and its pretty tight but i can get a finger between the tire and the tight spots. With an hour and a welder and some fab skills you can easily notch and weld up the areas that need to be clearanced and fit a 35.
  19. Nov 4, 2024 at 7:45 AM
    Quite a few vehicles had the spare standing up in the back on the drivers side even the early suburbans and others. The main thing in these vehicles including your Jeep was the wheel well was further ahead and the tire basically sat in the pocket behind the wheel well, to the rear pillar.
    The 4R wheel well is so far back, you cant fit a spare behind the wheel well, its gotta go beside the wheel well and hangs way out into the cargo area like so
    I mean it works, it certainly fits, but its not tucked in behind the wheel well and against the glass like your Jeep and most all the others are.
  20. Nov 4, 2024 at 7:53 AM
    I never owned a Jeep. I don't need it tight to the glass. I have a bunch of smaller items behind it, on top of the wheel well. It takes up about 25% of the floor space in the cargo area, which I find acceptable. Others might not like it. But, I think it's better than some other options.
  21. Nov 4, 2024 at 7:59 AM
    A swing out will always be in the way of accessing the cargo area, and blocking your rear view. I personally think it's one of the worst options.
    Crank the tire down and hose down the mechanism with lube periodically. The one in my '03 worked after 15 Wisconsin winters, although it was a bit stubborn.
    Stoney Ranger likes this.
  22. Nov 4, 2024 at 8:35 AM
    UncleShorty
    UncleShorty New Member
    You gonna put a 50 lb rocket in the back of your Runner and aim it at the back of your head?
    Yamahamer, Thatbassguy and Rocko9999 like this.
  23. Nov 4, 2024 at 8:39 AM
    I was directly talking to the other guy, who said he had a jeep, and i was using your picture as an example of how our vehicular modes of transportation wont allow the tire to tuck in behind the wheel well.
  24. Nov 4, 2024 at 8:58 AM
    50 lbs? Lol, try 90 lbs.
    Are you assuming that it isn't secured?
    In addition to being secured, 90% of the time, it's behind the rear seat-back.
    Edit: But, I do understand that it's a potential concern. Any unsecured cargo can become a projectile in a collision.
  25. Nov 4, 2024 at 8:59 AM
    I figured you were addressing me, since you quoted me.
  26. Nov 4, 2024 at 9:17 AM
    100% valid, I didn't think about blind spots.
  27. Nov 4, 2024 at 7:11 PM
    Why not do what Land Rovers have been doing for years: Strap it TO THE HOOD.
    andrewtheadventurer likes this.
  28. Nov 4, 2024 at 7:18 PM
    Manhattan
    Oooh… I like that idea. But first, we’d have to go to 29x9.5x15s though.
  29. Nov 4, 2024 at 7:23 PM
    Henry J
    Sacramento Ca
    When I got my front bumper at Demello in Riverside I was checking out their rear bumpers for 4Runners and Fjs. He said he was moving his spare inside because of the weight distribution too. I haven’t been back in over a year, but you should call Jason up to see if he built out the solution he had drawn up.
  30. Nov 6, 2024 at 7:21 PM
    Lol, that’s some nightmare shit right there. Laughing not laughing
