Some Limiteds can't be leveled?
Discussion in 'Suspension' started by AlexM102017, Apr 18, 2018.
  1. Apr 18, 2018 at 3:27 PM
    AlexM102017
    AlexM102017 [OP] New Member
    Alex
    2014 4Runner Limited
    None
    hey guys, so im new to this whole forums thing. But i do have a question. I called a truck spot to level my runner. They said some Limiteds can't be leveled due to having something with stablizing. Can someone give me some advice? Trying to level it
  2. Apr 18, 2018 at 7:01 PM
    Dark Knight
    Dark Knight Get off my lawn
    XREAS can be a little tricky but you can do it. In my previous job at an off road shop we lifted many 4Runners that had XREAS with the daystar brand lift/level kit. All were successful and customers were happy with results.
    Another option is to just ditch the XREAS system and do what ever lift you want. This will cost more of course.
    Bob likes this.
  3. Apr 18, 2018 at 7:29 PM
    AlexM102017
    Alex
    None
    @Dark Knight man thank you so much. They wY the guy made it seem is that you can never do it. Il be taking mine to a shop then and getting it done. Much appreciated.
  4. Apr 20, 2018 at 7:01 AM
    AlexM102017
    Alex
    None
    @Dark Knight do recommend doing the whole leveling kit front and back? Or can i get away with just doing the front?
  5. Apr 20, 2018 at 7:56 AM
    Dark Knight
    You can do either. All depends on what you like
  6. Apr 20, 2018 at 8:24 AM
    AlexM102017
    Alex
    None
  7. Apr 20, 2018 at 9:34 AM
    Dark Knight
    That will work.
  8. May 14, 2018 at 11:16 PM
    Kritsana21
    Kritsana21 New Member
    Todd
    Hey Alex, I’m in the same situation as you. I’m just looking for easy and reliable leveling kits for my limited until I have money to get a full lift. I can’t make up my mind between Daystars and Rough Country. Which kit did you end up choosing and are you happy with it?
  9. May 15, 2018 at 8:49 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, Crawlorado
    Honestly, you can level out the Limited 4Runners, the XREAS system can be tricky yes, BUT we do offer a 3'' front 1.5'' full lift kit that will work with the XREAS system, or you can simply just level out the front with the 2'' spacer if that is something you'd rather do..
    We do offer both options here:
    XREAS FULL KIT
    FRONT SPACERS
    Let me know if you guys have any questions at all, I'll be more than happy to help.
    -David
  10. May 15, 2018 at 10:43 AM
    Kritsana21
    Todd
    Thanks David, looks like the front spacers only might be what I'm looking for. Does the spacers just install right on top the shocks? Or do I have to compress the spring to install it?
    Thanks Todd
  11. May 16, 2018 at 8:13 AM
    Toytec Lifts
    Denver, Crawlorado
    Hey Todd,
    So our spacers will be installed on top of the coil spring, under the top mount. So you will have to compress the coil to install. We designed our spacers this way for a reason its a lot safer and will keep the longevity of your suspension.
    The top mount spacers will force the whole assembly down, manipulating the shock to be at full droop when driving, when that happens you will have more of a chance of the shock stem being forced into the shock body..
    Here is a photo for reference...
    Now please note, that you may overcome this happening by extending your bump stop down....
    18193227_10209182007089052_5042366879154_804e53cdd591d7e4103e5ba7069134873ba6e42e.jpg
    Kritsana21[QUOTED] likes this.
  12. May 16, 2018 at 8:38 AM
    Kritsana21
    Todd
    Thank you!
    Toytec Lifts[QUOTED] likes this.
