Skid plate and front bumper options for a 2011 4runner limited
Discussion in 'Armor' started by Trevor_Reynolds, Mar 24, 2021.
  1. Mar 24, 2021 at 7:57 AM
    Trevor_Reynolds
    Trevor_Reynolds [OP] New Member
    Trevor
    2011 Toyota 4runner limited
    None yet
    What's up everyone. i have recently purchased a 2011 4runner limited and was wondering if anybody had any recommendations for brush guards and skid plates! any help would be appreciated!
  2. Mar 24, 2021 at 8:08 AM
    Welcome to the forum Trevor.
  3. Mar 24, 2021 at 8:14 AM
    I'm interested in skid plates too. I'm somewhat concerned about this duct work to send air for cooling since the low hanging bumper is blocking air. I haven't seen a solution to support this duct work fixing to the skid plate.
    I also want skid plates that does not require removing support braces.
  4. Mar 24, 2021 at 7:21 PM
    T4runner11
    T4runner11 Member
    NYC
    11 SR5P MGM
    TRD Pro Bilstein Suspension TRD Pro skid plate TRD air filter TRD Pro Wheels (21) w Nitto Terra Kicker speakers with kicker amp
    Buy a TRD skid and swap it on. Should bolt right up.
  5. May 10, 2021 at 6:53 AM
    2011Trail
    2011Trail New Member
    Will the TRD Skid Plate fit on a 2011 Trail?
  6. May 10, 2021 at 1:34 PM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    That's interesting. Never seen that before. Looks like it interfaces with the cutout present on the 5th gen OEM skid...but later models don't have the duct, just the cutout on the skid.
  7. May 10, 2021 at 1:41 PM
    This duct work only comes with Limited trim. (Pic taken from 2019 Limited)
    Other trims do not have this duct work.
    MeefZah[QUOTED] likes this.
  8. May 10, 2021 at 6:37 PM
    T4runner11
    T4runner11 Member
    NYC
    11 SR5P MGM
    Remove the duct and skid and the TRD skid bolts right up. TRD hardware is used for the front and the stock hardware for the rear 2. Use a good anti-seize on all between oil changes. On an 11 Trail with KDSS there might be a clearance issue.
  9. Sep 1, 2021 at 1:03 PM
    Firesq14
    Firesq14 New Member
    11 Salsa red pearl aka Shakira
    Toytec lift level kit, trail face and ass lift.
    I beg to differ, I just swapped my 2011 sr5 for a 2011 trail bumper and this duct work was on the 2011 sr5.
  10. Jul 12, 2022 at 11:52 AM
    Cedric39
    Cedric39 New Member
    Ced
    Gray 2011 SR5
    I have a 2011 SR5 Premium and just put on the RCI Skid and Filler plate. Not sure about your duct work there. Mine doesn't have that. Install was a bit tedious by myself, but once I figured out a good way to support the weight while lining up the bolts, it was pretty smooth.
  11. Jan 10, 2023 at 3:47 AM
    RockinRobin
    RockinRobin New Member
    Robin
    Black 2013 Limited 4wd
    is the TRD plate beefy? Being Factory they are usually light weight. My 2013 Limited is thin and already rusting apart due to IL winter salt. I seen the RCI was aluminum but $400. Just want a good solution w/o the cost. Thanks for info (replies)....
