Side rails won't fit a Limited
Discussion in '5th Gen 4Runners (2010-2024)' started by Don19Toy, Sep 8, 2019.
  1. Sep 8, 2019 at 1:16 PM
    Don19Toy
    Don19Toy [OP] New Member
    Don
    2019 4Runner Limited
    Ordered mud flaps and running boards online, both said they were compatible with 2019 Limited. But neither fit, and seller has now modified his posting that they'll only fit SR5 & TRD, but not a Limited.
    Is there something different on that body style?
  2. Sep 8, 2019 at 2:26 PM
    Toffees
    Toffees Stuff and things
    Micah
    LA
    16 LE
    Tell us more about the rails you ordered. And what fit issue are you experiencing? Limited has a different rocker trim than the other models plus it has XREAS which will be secured to the frame in that general area. Some issues may be workable and other will not be.
  3. Sep 8, 2019 at 3:39 PM
    BigCountryT4R
    BigCountryT4R New Member
    Abilene, Texas
    2019 4Runner Limited 4x4, Magnetic Gray
    Buy a TRD Off-Road Side rocker and install those to replace the Limited ones, and you are done.
  4. Sep 8, 2019 at 6:23 PM
    Jemplyr77
    Jemplyr77 New Member
    Brian
    Oklahoma
    2019 MGM Nightshade
    Tinted windows. USR tail lights.
    I have OEM running boards and, although I do not have mud flaps, they would easily fit. I suspect they wouldn’t with some non OEM boards though. XREAS would be a non issue in my case.
  5. Sep 8, 2019 at 6:41 PM
    WallyT4R
    WallyT4R New Member
    The lower trim on the limited probably has to be removed before you can install that stuff. Check out @Agent_Outside 's thread. The lower trim on the limited either needs switched over to the other trims stuff or taken off completely or modified in some way.
