Shudder/slight bucking in lower RPM's - 2006 4Runners
Discussion in '4th Gen 4Runners (2003-2009)' started by hayzjj02, Nov 6, 2018.
  1. Nov 6, 2018 at 7:13 AM
    hayzjj02
    hayzjj02 [OP] New Member
    Hello everyone, I can use some help/pointers with my 2006 SR5 4Runner. Lately i have been experiencing a shudder/slight bucking with my 4Runner while in lower RPM's. it happens while slower acceleration or a cruising speed within 1-2,000 RPM's and lightly touching gas pedal. i have replaced trans fluid and had diagnostics ran, nothing coming up.
    Any/all help is appreciated, Thank you!
  2. Mar 5, 2021 at 9:19 PM
    KwiggzXX
    KwiggzXX New Member
    Kat
    Black 2007 Limited 4runner V6
    3inch suspension lift on 33” Fuel Gripper M/T and 20” Moto Metal rims
    Did you ever find the issue? I have a 07 Limited 4runner that i bought a few weeks back and i’m having the same issue suddenly.
  3. Mar 6, 2021 at 6:59 AM
    Toy Yoda
    Toy Yoda New Member
    That member hasnt been active in 2 years...
    If you have a shudder issue you should check for any trouble codes first, can check them at auto zone for free if you dont have a scanner. Should also consider doing a trans fluid exchange or multiple pan drain & fills if the trans fluid hasn't been changed at proper intervals. Do you have maint records for the 4runner to verify if the trans fluid has been changed? They also made a shudder fix additive that may help the issue before getting into physical repair.
    bear1998 and KwiggzXX like this.
  4. Mar 8, 2021 at 11:43 AM
    KwiggzXX
    KwiggzXX New Member
    Kat
    Thank you for the reply! I ended up doing a drain and fill on the trans pan and it fixed the issue! Thank god!
    Toy Yoda likes this.
  5. Mar 8, 2021 at 11:47 AM
    Toy Yoda
    Toy Yoda New Member
    Good to hear! Do a few more to ensure you have mostly new fluid in there. How much fluid came out on the drain & fill??
    KwiggzXX likes this.
  6. Mar 8, 2021 at 12:10 PM
    KwiggzXX
    KwiggzXX New Member
    Kat
    About 2 quarts. It was low forsure. We did it a couple times so the new fluid could filter through a bit. She’s running like a champ now so i’m just thankful it was a easy fix.
