Should I change my transmission fluid
Discussion in '4th Gen 4Runners (2003-2009)' started by red-brian87, Feb 23, 2023.
  1. Feb 23, 2023 at 5:39 PM
    red-brian87
    red-brian87 [OP] New Member
    Brian
    Roanoke va
    2004 4runner limited v8
    I've got 258,000 miles on my 4th gen 4runner. I'm starting to get hard shifts in 1st and second sometimes 3rd. Also it bumps when I start after I let off the break quick or stop as well. Not all the time though. I try to baby it but it's hard sometimes I want to let the v8 run sometimes. Anyways I'm hoping that a transmission fluid change and filter will help. What do you think? Let me know oh its been about 200,000 since my last flush I don't think I'll do that though
  2. Feb 23, 2023 at 8:07 PM
    Stoney Ranger
    Stoney Ranger New Member
    Driftless Area
    '18 SR5 Nauti Blue
    4x Rockers/Skids-Dobi-275's-Fr/R Bpr-Winch-Stickers-ALF
  3. Feb 23, 2023 at 8:15 PM
    TN_FunRunner
    TN_FunRunner New Member
    Jay
    W. TN
    2018 TRD ORP, 2007 SR5 4WD
    I’d try a drain and fill but I definitely wouldn’t flush it.
    Rupp1, 4Runner75 and Thatbassguy like this.
  4. Feb 25, 2023 at 9:03 AM
    trlhiker
    trlhiker Lazy Bum
    1992 4Runner SR5 V6 4X4
    Do a drain and fill and then 100 miles later, do another drain and fill.
    Rupp1 and Daddykool like this.
  5. Feb 25, 2023 at 10:06 AM
    Daddykool
    As I understand it, this process, done over time, will allow you to remove a quantity of old fluid and replace it with new, but incrementally. Some guys measure what they remove (couple quarts maybe?), and put that exact amount of fresh in. So over time your fluid gets much cleaner. Haven’t done it but it makes sense to me.
    Adding that I don’t think a drain removes all the fluid, just a few quarts. A flush replaces it all at once. Correct?
  6. Feb 25, 2023 at 10:10 AM
    AuSeeker
    AuSeeker New Member
    2004 Limited
    Do it, I'm guessing since it's been 200,000 miles since you've done anything, it's very possible it's low on fluid, so doing a drain and fill and especially checking the fluid level correctly can only be a good thing!!!
  7. Feb 25, 2023 at 4:54 PM
    red-brian87
    Brian
    Roanoke va
    I'll do a drain and replace the filter. No flush I want some of the old clutch material to stay in it. I want to take care of it not shock it to a sudden death thanks for the input. It seems to be doing hard shifts from 1 to 3rd more often now I just did a 200 mile trip and another 200 back so I'll schedule something for Tuesday. Its fine after 3rd gear
    4Runner75 likes this.
  8. Feb 26, 2023 at 5:23 AM
    Sailormilan2
    Sailormilan2 New Member
    Dale
    2020 4Runner TRD Premium
    My Tacoma's fluid was absolutely black when I did the fluid at 90k miles. I did the drain, refill, pump out 2 1/2 qts, refill, repeat. Went through 12 qts. Went from black to dark cherry red. Then added a Purolator P1320 inline trans filters. Much easier to change than the pan filter, and is good for 30k miles. I'm working on the 3rd filter now, and the fluid is the proper shade of red. Going to do the same thing to my 4Runner.
    Ggalvis11 likes this.
  9. Feb 26, 2023 at 6:30 AM
    red-brian87
    Brian
    Roanoke va
    I'm scared to change it though but doing nothing is worse. It's been 200,000 with out service
  10. Feb 26, 2023 at 6:33 AM
    Out of curiosity, have you checked the level? It might just be low. :notsure:
    That said, a drain and refill is probably a good idea, as mentioned above.
  11. Feb 26, 2023 at 6:36 AM
    red-brian87
    Brian
    Roanoke va
    No sadly I don't even own a socket set. I'm very ashamed to admit this. I'm just starting out on my own again so I need to invest in tools.
  12. Feb 26, 2023 at 6:52 AM
    Polymers
    Polymers New Member
    2014 Limited 4WD
    Bought my truck with 120K miles. Tranny had never been serviced according to records. I did the same as @Sailormilan2
    using a 50:50 mix of Toyota ATF WS fluid with Valvoline Maxlife due to the fact I purchased 6 quarts of WS at dealership with plans to do a drain and fill 2-3 times instead of a flush. After reading and watching many diy, decided to go ahead with a flush using cooler lines. Needed to buy 6 additional quarts on a Saturday afternoon and dealership was closed so I picked up 6 quarts of Maxlife (1/2 price of WS fluid) and added the 50:50 mix two quarts at a time. Procedure was not too difficult after watching Car Care Nut how to video. Original fluid was pretty dark and had a fair amount of fine metal particles in it. Changed filter while in there. Was a little concerned about removing all the clutch material with a flush but the truck shifts great and after 12k miles all is good.
    Foothills likes this.
  13. Mar 9, 2023 at 6:01 PM
    red-brian87
    Brian
    Roanoke va
    I did a fluid change with a filter. It didn't help. It seems to be acting slightly worse.third gear shudders the whole car and I get it to change gears and it goes away. The mechanic said he didn't see any metal. And I personally saw the fluid come out and it was redish black so not too bad. I guess I will have to buy a new tranmission. I am thinking of a heavy duty one so it will last a looong time.
  14. Mar 10, 2023 at 12:49 AM
    GreatWhitePig
    GreatWhitePig New Member
    Need to lube the driveshaft. The clunking after hard braking and after take off is the driveshaft clunk.
    Kfish likes this.
  15. Mar 10, 2023 at 8:08 AM
    xtremewlr
    xtremewlr New Member
    Todd
    Tucson, AZ
    2003 4Runner V8 Limited 4WD
    Lots with more in the works
    Probably a failing solenoid then. You can get replacement solenoids but I have not had to do that on mine yet. I doubt you need to replace the transmission.
    RockAuto has all the shift solenoids. - https://www.rockauto.com/en/catalog...40,transmission-automatic,shift+solenoid,8476
    As for a "heavy duty" transmission, there isn't one for the 4runner. The A750F that you have is it. It's a good transmission when properly maintained. Mine has 330k miles on it and works fine.
  16. Mar 10, 2023 at 3:50 PM
    red-brian87
    Brian
    Roanoke va
    It's an aftermarket one that I found online a750f. My tranmission shakes in 3rd bad and does hard shifts. I think the fluid change aggravated it. I wanted a cheap fix but oh well I think it's dying
    GreatWhitePig likes this.
  17. Mar 10, 2023 at 6:26 PM
    xtremewlr
    Todd
    Tucson, AZ
    So agian, I'll state that there is a possibility that it's just a failing solenoid. Talking to my Toyota master mechanic budy, he told me the a750f is also know for valve body corrocion. I would say take the truck to a competent transmission shop and have them diagnose the issue. You might be able to have either a solenoid only replaced or the whole valve body done and not have to buy another transmission.
  18. Mar 10, 2023 at 6:30 PM
    red-brian87
    Brian
    Roanoke va
    Should I take it to ammco or toyota?
  19. Mar 10, 2023 at 6:44 PM
    xtremewlr
    Todd
    Tucson, AZ
    Toyota will probably just want to replace the transmission. Aamco might be the better choice, unless you can find an independent transmission shop locally. General repair shops can't always troubleshoot transmissions well IMO.
  20. Mar 10, 2023 at 6:45 PM
    red-brian87
    Brian
    Roanoke va
    Thanks I'll check out a local shop!
    xtremewlr likes this.
  21. Mar 11, 2023 at 11:36 AM
    Libagui
    Libagui New Member
    Librado
    2006 Silver 4runner limited.
    I changed it at 196,000 miles, and added lubeguatd additive. It's been working awesome, just reached 217,000 miles.
