Shocks for 2008 T4R
Discussion in 'Suspension' started by 4runningMan, Dec 18, 2018.
  1. Dec 18, 2018 at 8:08 PM
    4runningMan
    4runningMan [OP] New Member
    New Mexico
    I've got a friend with a 2008 4runner. The stock shocks are shot. I'm not a "suspension guy". I'm at a total loss for what to recommend. Can you help me out in coming up with a good solution?
    He wants to not spend a lot of money. He said he'd just go with OEM at the dealer, but if he could get something better for not much more money, he's open to it. And if it lifted it an inch, that would be ok, too.
  2. Dec 18, 2018 at 8:11 PM
    4runningMan
    New Mexico
    Are there any options that would be a direct replacement (without replacing springs) that would lift 1/2" or 1" without compromising ride quality?
  3. Dec 19, 2018 at 8:34 AM
    I don't know if they will work, but i have the take offs from my 17 SR5 with about 800 miles on them. Front shocks w/coils, rear springs, uca's, what part of the country are you in?
  4. Dec 19, 2018 at 9:31 AM
    4runningMan
    New Mexico
    Oh man. That would be sweet if it worked. I'll look into it. I'm nowhere near you though.
  5. Dec 19, 2018 at 11:50 AM
    cmbronc76
    cmbronc76 New Member
  6. Dec 19, 2018 at 1:30 PM
    That_Titanium_4RNR
    That_Titanium_4RNR New Member
    Michael
    Greenville NC
    2006 Titanium Limited V8 4X4
    Dobinsons awning, TPMS Bypass, AIP Bypass, HCF Delete, LED License Plate Lights, LED Reverse Lights
    Go with the 5100s, ride quality will be very good, and you can use the stock springs. They have perches on the shock tube itself that allow you to select what height you want. If he only wants to level it, but needs new shocks this is a good option for him. Having these also opens up the option to use them if lifting the 4runner later too. For example, he could get lift springs like OME 885s and you could use these 5100s still.
    4runningMan[OP] likes this.
  7. Dec 19, 2018 at 1:42 PM
    MattAK
    MattAK Headin' for the hills
    Matt
    Utah
    2019 Tundra SR5 dbl cab white
    I had 5100's on both my 3rd gen and my 5th gen. The ride was excellent and I didn't have any issues with them except for the rubber boots that protect the shaft coming off on both of the rear shocks on my 5th gen. Personally I'll be avoiding Bilstein on my current 4th gen due to them refusing to warranty the shock if you take it off road or use non-OEM springs with them.
    4runningMan[OP] and SlvrSlug like this.
  8. Dec 19, 2018 at 5:45 PM
    4runningMan
    New Mexico
    Thanks, everyone. Sounds like 5100's is the way to go. So, you can install them and maintain factory rake OR level the front end. Do I have that right- 2 options?
    Also, how would you describe the ride in comparison to OEM SR5 shocks?
  9. Dec 19, 2018 at 6:01 PM
    MattAK
    Matt
    Utah
    Typically the 5100's have 4 settings you can use for lifting the front using a little snap ring set into grooves that the lower spring seat sits on. The settings are stock height, .85", 1.75", and 2.5" of lift. On my 3rd gen they were noticeably stiffer than stock. On my 5th gen they were a little stiffer but since it was such a heavy truck it still had a good ride. Can't speak to the 4th gen but I'd expect it to be stiffer than the SR5 shocks.
  10. Dec 19, 2018 at 6:41 PM
    4runningMan
    New Mexico
    Is 1.75" the setting to use to level it?
  11. Dec 19, 2018 at 6:46 PM
    4runningMan
    New Mexico
    If you set the 5100's at a setting higher than the stock height, does it preload the springs?
  12. Dec 20, 2018 at 5:32 AM
    jtice
    jtice New Member
    West Virginia
    2016 SR5
    Eibach Pro Truck Lift, 255/75/R17 BFG K02s, TRD Pro Wheels, C4Fab Front Bumper, Smittybilt 9.5 Winch, Rocky Road Super Sliders, BajaRacks Rear Hatch Ladder, SSO Roof Rack, RCI Full AL Skids
    Eibach is another option, much like the Bilstein 5100s, but said to ride less stiff.
  13. Dec 20, 2018 at 5:52 AM
    Sparkkky
    Sparkkky New Member
    2018 4 Runner TRD Off-road
    Eiback Pro lift, ARB Summit bumper, Smitty Bilt wench, Summit flood LED
    Love my Eiback shocks and springs!
  14. Dec 20, 2018 at 6:05 AM
    Narbeh
    Narbeh New Member
    Narbeh
    La Canada Flintridge
    2019 4Runner TRD Off Road Premium
    I just took off my Trd Off road premium suspension off my 2019. Front shocks UCAS rear springs and rear shocks. If he’s interested. Everything is in a box and I can arrange for shipping. I’m in Los Angeles. I even have my trd Off road wheels and tires. Everything has less than 500 miles on them.
  15. Dec 20, 2018 at 10:15 AM
    4runningMan
    New Mexico
    I'll have to verify if it's plug and play on a 2008.
  16. Dec 20, 2018 at 10:18 AM
    Narbeh
    Narbeh New Member
    Narbeh
    Sure thing, let me know buddy.
