Shift knob disassembly so it can be painted to anything, but silver
Discussion in '5th Gen 4Runners (2010-2024)' started by 4RUnderground, Nov 3, 2024.
  1. Nov 3, 2024 at 6:22 PM
    4RUnderground
    4RUnderground [OP] New Member
    I did not want to drop $100 to buy the black shift knob and assumed there was a way to take apart the shifter so it can be painted. I tried searching previous posts but didn't find anything regarding it.
    The aftermarket ones do not have TRD embossed on top and look of less quality for $25.
    Grab a plastic pry tool and was able to take it apart.
    Toyota parts manufacturer did use a silicone to attach the larger silver trim piece to the main body of the shifter along the back side.
    Essentially the lower small silver piece pops off easily with minimal work. The larger piece takes a bit of patience and working to release the silicone or whatever thin bodied adhesive they used.
    Too late it in the evening to start prep and paint but will update once I get it back together.
    Will have to give the transfer case shifter a go next so they match.
  2. Nov 3, 2024 at 6:52 PM
    cuse93
    cuse93 Ice Station Zebra
    I already dropped the $100 on the oem transmission knob swap....but i'd be really interested to see how you make out with the transfer case knob. I'm hoping you demonstrate that the cap can easily be popped off to save me another $50. If I had the name of the guy who decided to put all the chrome and shiny shit in the ORP interior i swear I'd challenge him to Fight Club.
  3. Nov 3, 2024 at 7:01 PM
    4RUnderground
  4. Nov 10, 2024 at 5:44 AM
    4RUnderground
    Wet sanded factory silver with 600 grit. Applied satin black with satin clear to match factory sheen.
    Disassembled the transfer case knob. It is essentially a one time assembly that will require glue to reassemble. The tabs are brittle and small with no way to release.
    michow87 likes this.
  5. Nov 10, 2024 at 7:54 AM
    michow87
    michow87 New Member
    2024 TRD Pro Underground
    Looks clean
  6. Nov 27, 2024 at 4:35 PM
    Tama1968
    Tama1968 New Member
    Florida
    looks good! what type of paint/clear coat did you use. I'm debating overlays vs painting my silver trim black, but not sure what paint would hold up the best without rubbing off from daily use.
