Seizing brakes
Discussion in '4th Gen 4Runners (2003-2009)' started by HoBoDanny, Feb 15, 2019.
Front, rear, or both brakes seizing.
  1. Front
    0 vote(s)
    0.0%
  2. Rear
    50.0%
  3. Both
    50.0%
  1. Feb 15, 2019 at 6:22 PM
    HoBoDanny
    HoBoDanny [OP] Dude...
    Daniel
    Kentucky
    2004 SR5 V6 4WD 4Runner
    Looking for info from you all on the brakes seizing. Is it primarily front or rear? Thanks!
  2. Feb 18, 2019 at 8:28 AM
    RonT4R
    RonT4R New Member
    Ron
    Virginia Beach
    2007 4runner SR5 4WD
    I have replaced the calipers on the front of mine several times. I only had one go bad on the rear.
  3. Feb 18, 2019 at 10:34 AM
    HoBoDanny
    Daniel
    Kentucky
    Have you done the 5th gen upgrade or just oem replacement?
  4. Feb 19, 2019 at 7:06 AM
    RonT4R
    RonT4R New Member
    Ron
    Virginia Beach
    OEM replacement
    HoBoDanny[OP] likes this.
  5. Feb 19, 2019 at 7:20 AM
    blackoutt
    blackoutt New Member
    Southern IN
    2007 4Runner Limited V8
    Adventure Build
    replaced my fronts with OEM 4th gen fronts at 86k miles over 4 years ago and make it a point to clean and cycle them with a c-clamp at least once a year and they're still good. Just found a rear seized recently at 166k miles and replaced with 5th gen calipers which are almost the same thing, same pads.
  6. Feb 19, 2019 at 12:09 PM
    HoBoDanny
    Daniel
    Kentucky
    Ever regret not doing 5th gen in front as well? Did changing the rears to 5th gen make much difference?
  7. Feb 19, 2019 at 12:51 PM
    blackoutt
    Southern IN
    Adventure Build
    No for the front, they are already the sport sized brakes so I doubt it would make much of a difference. With nice powerstop Zsomething pads bedded in on their slotted and cross drilled rotors and stainless lines all around, brake performance is pretty good.
    Also no for the rears, it feels like it did before my 4th gen caliper seized but the cost was only a couple bucks more so I figured might as well add another "mod" to the list.
    HoBoDanny[QUOTED][OP] likes this.
  8. Feb 19, 2019 at 1:33 PM
    HoBoDanny
    Daniel
    Kentucky
    Thanks. I don’t think I have the sport brakes though. So I may still look into doing the fronts. Im not planning on replacing them until they go bad but I would like to have a plan for when they do.
  9. Feb 20, 2019 at 4:50 AM
    blackoutt
    Southern IN
    Adventure Build
    I think I even have a pair of 4th gen sport calipers new sitting in my parts bin if you don't decide to do 5th gen. Depending on where you're at in KY I could drop them off for cheap, I go to Eastern KY often to camp.
  10. Feb 20, 2019 at 11:14 AM
    MP21
    MP21 New Member
    1998 T4R 4x4 V-6 & 2008 T4R 4x4 V-8 & 2004 T4R 4x4 V-8 & 11 Sequoia Platinum
    Every one in my signature are heavily modified and to much to list.
    155K+ and no to either. Love the Texas weather- no salt
  11. Feb 20, 2019 at 12:25 PM
    HoBoDanny
    Daniel
    Kentucky
    Awesome I’ll keep that in mind. I’m in Frankfort so not that far from IN.
    Wondering if the salt may be the problem.
    blackoutt[QUOTED] likes this.
  12. Feb 28, 2019 at 8:05 AM
    AirWarrior
    AirWarrior New Member
    Loren
    2005 4Runner SR5 V8
    Aux Air Bypass
    I've replaced my front calipers on my 2005 about every two years, for the last 6 years. I'm looking to either find a Brembo kit or other aftermarket caliper for the fronts. I'm tired of replacing these calipers and rotors.
    Is there much to mod to install 5th gen calipers?
  13. Feb 28, 2019 at 8:11 AM
    MattAK
    MattAK Headin' for the hills
    Matt
    Utah
    2019 Tundra SR5 dbl cab white
    0 modifications required, they bolt right on. The only thing you have to be concerned about is your wheels clearing the 5th gen calipers. My OEM sport rims cleared the 5th gen calipers just fine, not sure about the other rims though.
  14. Feb 28, 2019 at 8:22 AM
    AirWarrior
    Loren
    2005 4Runner SR5 V8
    Aux Air Bypass
    Interesting that's probably why the 5th gen TRD pro wheels have an offset. Maybe that will be the push to pull the trigger on new rims.
  15. Feb 28, 2019 at 1:05 PM
    HoBoDanny
    Daniel
    Kentucky
    Started this thread to see if I really needed to replace mine with 5th gen. It’s cool that it’s helping others get more information as well. Guess I’ll be getting parts together to do the swap on mine.
    TN_FunRunner and WallyT4R like this.
  16. Mar 4, 2019 at 7:30 PM
    TN_FunRunner
    TN_FunRunner Custom Title
    Jay
    W. TN
    2018 TRD ORP, 2007 SR5 4WD
    Good info here.
  17. Mar 5, 2019 at 2:34 AM
    Benny123
    Benny123 Toyota enthusiast
    Southeast Charlotte, NC
    2016 Nautical Blue SR5 Premium
    LEDs all around, otherwise bone stock.
    Did the rear calipers several times, fronts once. 2007 SR5.
