Seatbelt fraying
Discussion in '5th Gen 4Runners (2010-2024)' started by KHV, Sep 18, 2023.
  1. Sep 18, 2023 at 12:09 PM
    KHV
    KHV [OP] New Member
    I have a 2018 4runner Limited with a little less than 55000 miles on it. The seat belt on the passenger side and passenger rear had become very difficult to retract and extend and have frayed. Picture below as example. There has been no known damage other than trying to retract and expand the seatbelt.
    Anyone else have this problem?
    Much appreciate any sharing as Toyota doesn't seem to want to repair at their cost for SeatBelt warrantee.
  2. Sep 18, 2023 at 1:09 PM
    LA260
    LA260 New Member
    This happened to my old MDX and it was a mouse/rat that got in there and chewed the seatbelt no joke. Take a good look all around the interior to see if there is any evidence of mice/rats activity
    Rocko9999 likes this.
  3. Sep 18, 2023 at 1:16 PM
    KHV
    KHV [OP] New Member
    Well that would be gross. But very much appreciate your response.
  4. Sep 18, 2023 at 1:18 PM
    San Angelo
    San Angelo New Member
    That looks Dale Earnhardt bad for a belt. Did they give you the cost to replace?
  5. Sep 18, 2023 at 1:23 PM
    KHV
    KHV [OP] New Member
    $700 +|-
  6. Sep 18, 2023 at 1:29 PM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    The OEM seatbelt is expensive to replace. Mine is old and does not retract fully but enough to not be in the way. With you, your retractor motor etc should still be in good shape. Unfortunately, it's a seat belt. Not an item one want to cheap out.
    That does look like it was chewed by a rat or someone cut it. The material around it still looks in good shape. Normal wear and tear is uniform.
  7. Sep 18, 2023 at 1:29 PM
    San Angelo
    Check with a body shop. They can sometimes do it cheaper.
  8. Sep 18, 2023 at 1:32 PM
    jvinhj240
    jvinhj240 New Member
    Ben
    send someone in TX, they replace all belts with color choice, I think around $100 each, I did mine when It was brand new, I hate black color anyways.
    Google: seatbelt restore if you're interested.
  9. Sep 18, 2023 at 2:06 PM
    KHV
    KHV [OP] New Member
    So, good news and bad…
    Total cost almost $900, good news is they ordered one of the two belts incorrectly, so have only replaced the back seat.
    I will go to a repair shop for the second one.
    Thank you all for your input.
    kolter45 likes this.
  10. Sep 18, 2023 at 2:32 PM
    Daddykool
    So you decided it’s not defective belts?
  11. Sep 18, 2023 at 3:08 PM
    Yoda_Mike
    Yoda_Mike New Member
    Michael
    South Glens Falls, NY
    2019 Toyota Tacoma TRD Sport
    Check with the dealer. I don't recall for sure, but I think components related to the SRS system might be covered under an 8year 80K mileage warranty. I believe that is enforced by the federal government. Those seat belts have a pre-tensioner in them so they are part of that SRS system, and may be covered. Don't quote me on this but I think I'm recalling it correctly.
    Rocko9999 and Captain Spalding like this.
  12. Sep 18, 2023 at 6:13 PM
    KHV
    KHV [OP] New Member
    The dealer corresponded with Toyota who indicated they were not defective but damaged. I felt they were damaged due to defective retration system.
    Daddykool, Toyota did, not me…
  13. Sep 18, 2023 at 6:15 PM
    Yoda_Mike
    Michael
    That’s a bummer. Maybe you can make a stink with corporate…
  14. Sep 18, 2023 at 6:18 PM
    KHV
    KHV [OP] New Member
    I kept the old seatbelt and thought it was worth another try with corporate Toyota. I appreciate your note.
    due to a parts snafu they had the wrong belt part for the passenger front, I may check with a trusted mechanic to see if they can do that safely but less than the 450 the dealer wants for the front seat
  15. Sep 18, 2023 at 6:25 PM
    Yoda_Mike
    Michael
    They are actually pretty easy to change. Just have to be certain the battery is disconnected while doing so, so you don’t set off the pre-tensioner. You are supposed to detonate them before disposing of the old one. That was always fun in the shop! Lol
    RumHamRunner73 likes this.
  16. Sep 18, 2023 at 7:15 PM
    Same thing with getting rid of sodium filled valves. Good times!
  17. Sep 18, 2023 at 7:53 PM
    alittleoff
    alittleoff New Member
    Steve
    406
    '16 TP
    I know that I'm late to the conversation but, that looks like damage from it being shut in the door sticker/latch.
    If you bought the vehicle used, no telling what could've frayed it like that. Possibly a sharp edge on a child safety seat or...
    Glad its been replaced for your piece of mind.
  18. Jan 22, 2024 at 12:56 PM
    COWaterBaby
    COWaterBaby New Member
    Dianne
    2011 4Runner Trail
    I have a similar seatbelt issue. Mine is almost severed. NO rats, no mice, nor has it been slammed in the door. I saw the (what looked like a cut) and then from showing a few people, it had another cut looking frayed area, then another and now I cannot pull it out, it is stuck. It is my suspicion that something like the teeth of the mechanism inside is cutting it up. Today I Googled and found this page. Anyone else have this issue? I have not had many people sit behind me so it cannot be wear. From what I understand, if you have an accident, cutting these belts take determination.
    Lagertha likes this.
  19. Jan 22, 2024 at 3:49 PM
    HuskyMike
    HuskyMike New Member
    A sharp knife makes pretty easy work of it. I had to cut my son out of his seatbelt once ( kind of a long story but it was not because of an accident or anything like that).
  20. Jan 22, 2024 at 5:09 PM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    "In the unlikely situation that there are issues with the seatbelts or airbags, this warranty will cover all repairs for 60 months or 60,000"
  21. Jan 23, 2024 at 7:41 AM
    jgalt
    jgalt New Member
    I had this type of damage happen in a new Honda once. Turns out it was flash on the plastic trim piece opening were the belt enters/exits. The flash was almost razor sharp and sawed the belts while in use. This particular case was the rear passenger side and required a lot of the interior to be removed to replace.
  22. Jan 23, 2024 at 8:21 AM
    Rocko9999
    2011 Limited
    Great point. Follow it all the way back to the winder. Has to be something causing this.
  23. Oct 21, 2024 at 12:10 PM
    Lagertha
    Lagertha New Member
    Geneviève
    2018 silver 4Runner TDR Offroad
    3" leveling kit
    Just so you know that I have the exact same thing on my 2018 4runner TRD OffRoad. Started with one passager to now the two side passenger. Rarely use them. it is very strange.
