Saw My First 6th Gen In Person
Discussion in '6th Gen 4Runners (2025+)' started by Rick G., Mar 15, 2025.
  1. May 2, 2025 at 8:21 AM
    #241
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    Indeed!
    Even disregarding what it says on paper, I could not keep up with it when it was accelerating. It had that short term burst that our V6 just does not have.
  2. May 2, 2025 at 10:09 AM
    #242
    Jennyjo14
    Jennyjo14 New Member
    Jennifer
    None
    Bummer, isn't it? I did, however, take a look at one and it's...
  3. May 2, 2025 at 10:29 AM
    #243
    gkomo
    gkomo New Member
    San Diego, CA
    2014 Tacoma AC 4x4
    I didn't read through the whole thread so it may have been said before... but thats giving me 4th gen 4runner vibes. As a 4th gen owner, i dig it!
    djwantke and Thatbassguy like this.
  4. May 2, 2025 at 11:31 AM
    #244
    FourBelugas
    FourBelugas New Member
    23 white ORP
    Not sure if it's a bigger indictment on Toyota or the buyers....
  5. May 2, 2025 at 12:12 PM
    #245
    Probably Toyota. The buyers probably either don't care, or they know they can get better tires.
    Trail Runnah likes this.
  6. May 2, 2025 at 12:57 PM
    #246
    FourBelugas
    23 white ORP
    Why Toyota if they know 4Runner buyers are by and large just commuters anyway and customers don't care? Sounds like overall Toyota knows their customers won't notice the difference enough to care.
  7. May 2, 2025 at 5:47 PM
    #247
    MWinkTRD
    MWinkTRD Basically Stock
    Max
    Southeast Alabama
    2023 MGM TRD ORP
    I’ve seen a few on the roads and two at the dealership but haven’t been up close to one. Went to Waffle House tonight and saw a red Limited sitting by itself so had to park next to it lol. Just doing a quick walk around the 5th gen seems wider side by side (the angle of the pic exaggerates it a little) but the looks are growing on me. The front bottom valence needs to go though IMO
  8. May 2, 2025 at 6:17 PM
    #248
    balong48
    balong48 New Member
    2011 Silver 4Runner Limited
    Man that red is beautiful.
    MWinkTRD[QUOTED] likes this.
  9. May 2, 2025 at 6:26 PM
    #249
    On paper the 6th gen is wider, but its really the track width. The fender flares stick out past the door skin like 4-5"
    Inside, door panel to door panel the 6th gen is about -1.8" narrower than the 5th gen.
    Inside, outside of front seat lip to seat lip on the 6th gen is about -1.2" narrower than the 5th gen.
    When you sit in a 6th gen it definitely feels different and smaller, even though on paper it measures +2.1" wider.
  10. May 2, 2025 at 7:55 PM
    #250
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    the 6th gen wishes it was the 4th gen! looks like a RAV4 fcked a Subaru lol
  11. May 3, 2025 at 8:13 AM
    #251
    4Hopper
    4Hopper New Member
    24 Ice Cap 4R TRDOR Prem
    Hard to criticize Gen6 styling too much because Gen5 is a mixed bag. You can tell they’re related b/c both can look handsome from one angle, and from another, maybe not so much.
    That’s why Gen3 remains the standard benchmark of what a proper 4Runner should always look like. Proportions, details, stance, everything’s easy on the eyes, from every angle. Just scale that design out for Gen7 please.
  12. May 3, 2025 at 8:55 AM
    #252
    vthoky New Member
    I saw a 6th gen (Underground) in North Carolina yesterday.
    From ten yards or so, it wasn’t super ugly, but it had potential to be. What stood out to me, though, was that the turn signals glowed red instead of amber. I just hate that….
