Saw My First 6th Gen In Person
Discussion in '6th Gen 4Runners (2025+)' started by Rick G., Mar 15, 2025.
  1. May 19, 2025 at 7:43 PM
    #421
    mac1usa
    mac1usa New Member
    Wow those ranges are unreal. Now just imagine you are towing a boat or camper and then presumably the ranges he mentioned in the video are reduced even more!
  2. May 19, 2025 at 7:52 PM
    #422
    Not 6th gen 4runner but similar, this lifted Land Cruiser is used as a dealership rental vehicle. Not sure what's the story. No one wanted this Land Cruiser with spacer lift + wheel spacer + 285/75R18 tires? No idea.
  3. May 19, 2025 at 7:59 PM
    #423
    It looks like there’s enough room where they could have made the tanks a few gallons bigger. It makes no sense.
  4. May 19, 2025 at 8:01 PM
    #424
    They were probably asking some absurd price for it and it was sitting collecting dust.
    kmeeg[QUOTED] likes this.
  5. May 19, 2025 at 8:06 PM
    #425
    FourBelugas
    FourBelugas New Member
    23 white ORP
    There is more than enough room for another 3-4 gallons if they bothered. Heck the GX comes with a 21 gallon tank and there is still a little room to spare.
    But they won't, all those "my first 4R evah!!!!" buyers will just buy it and accept as the norm.
    I don't have a horse in this race since i am not in need of another vehicle currently and my tow vehicle has a 48 gallon tank. :D
  6. May 19, 2025 at 8:41 PM
    #426
    Tow vehicle? How many vehicles do you have?
  7. May 19, 2025 at 9:01 PM
    #427
    FourBelugas
    23 white ORP
    too many according to the wife, not enough according to my friends.
    We have 8 vehicles in the family right now, the F250 is rarely used but does come in handy. My excuse is at least 2-3 of the cars will be kids' first car since 4 of the cars are older than 19 years, and the other 4 were bought in the past 3 years to replace the first 4, but the first 4 cars refuse to die. LOL. That's what happens when we keep buying simple Toyotas and Fords.
  8. May 19, 2025 at 9:27 PM
    #428
    Speaking of collecting dust, this was collecting dust since 4/28. It was listed over $69K as I remember and now it's $64K.
  9. May 20, 2025 at 7:44 AM
    #429
    You can start your own used car dealership. :D
    FourBelugas[QUOTED] and kolter45 like this.
  10. May 20, 2025 at 8:16 AM
    #430
    Insanity.
  11. May 20, 2025 at 8:53 AM
    #431
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    How dare you make fun of me
  12. May 20, 2025 at 9:25 AM
    #432
    4Daughters
    4Daughters It’s how I know God has a sense of humor
    Ken
    Powder Springs, Ga
    2022 TRD ORP; Silver; too many port options...Ah well...
    TBD
    AmericanGI and icebear like this.
  13. May 20, 2025 at 9:42 AM
    #433
    He just says it’s longer and narrower.
    It looks like there is plenty of room to have made the fuel tank even longer.
    4Daughters[QUOTED] likes this.
  14. May 20, 2025 at 10:52 AM
    #434
    FourBelugas
    23 white ORP
    I will be the worst kind of car dealer that gets high on his own supply with my hoarding tendencies of older simpler cars. If I had my own car lot it will be filled with low mileage pre-2009 Corollas and pre-2007 Camrys that are priced too high to sell.
  15. May 20, 2025 at 12:24 PM
    #435
    4Daughters
    Ken
    Powder Springs, Ga
    TBD
    My apologies; I posted the wrong video. Tinkerer's Adventure did a comparison between he LC250 and the FJ Cruiser, and mentioned that there is a hybrid-specific cross member on the LC250 that takes away space that otherwise could accommodate a larger gas tank. The GX550 cross member is in a different position because it's not a hybrid, and it has a larger gas tank as a result. Same may apply to the 4Runner? Starts at 9:38.
    https://www.youtube.com/watch?v=onpbKja9n7E&t=639s
  16. May 20, 2025 at 12:44 PM
    #436
    I think one of Truck King’s videos shows the rear of the tank and how there is plenty of room before the rear axle to have made the fuel tank bigger.
    FourBelugas likes this.
  17. May 20, 2025 at 12:48 PM
    #437
    FourBelugas
    23 white ORP
    No, the gas only 6th gen gets a 19 gallon tank
    https://www.toyota.com/4runner/features/mpg_other_price/8642/8648/8634
  18. May 20, 2025 at 12:50 PM
    #438
    FourBelugas
    23 white ORP
    Tinkerer's video showed that too where the FJ had a tank shaped to fill in the space around the rear axle, where as the LC250 just kind of stops quite a bit before the axle and ends in a rounded flat end with no attempt to use the dead space.
    4Daughters likes this.
  19. May 20, 2025 at 5:50 PM
    #439
    MartyG
    MartyG New Member
    Marty
    Florida
    Cavelry blue 4runner
    2"lift infotainment
    I just bought a used 4 runner with 50,000 very clean no accidents , to me it was a no brainer . well established reliability record . ant i was not paying the kind of money that there asking for a new one with an all new drive train aspecialy with whats going on with the new tundra and the taco . If i was buying new after testing both i would go for the new land cruiser in my opinion it rides much better. and is a land cruiser . Ill probably get chastised for saying that
  20. May 20, 2025 at 7:58 PM
    #440
    I’m betting the tank size is for manufacturing simplicity and differentiation.
    One tank for all 4Runner’s and Land Cruisers (assuming the LC is literally the same part) saves on logistics and inventory.
    It also offers a nice small way to upsell, whether it be to the extra efficiency of the hybrid or to the GX.
    If Toyota could get us all to buy a GX or LX instead of any of the others, I bet they would try.
    It’s definitely not an EV conspiracy thing, especially since it’s Toyota.
    But also that things like this have been a hallmark of automotive trims for a very long time.
    From…
    • cruise control being excluded from Maverick XL’s (and many base trucks) in the earlier years
    • last-gen Colorado WT’s not getting an overhead console with the sunglasses holder nor steering wheel media controls
    • full-time 4WD being removed from all lower trims when the 5th gen arrived
    • 4WD Silverados no longer get a two-speed transfer case standard
    • etc.
    That said, in my personal experience, the Subaru Ascent has the same size tank and LA driving does not do its fuel efficiency any favors so I felt the squeeze there.
    Part of the reason I skipped the Frontier and Xterra as well when shopping, since they have a 21 gal tank.
    The 3rd gen’s tank is at 18.5 gallons too which hasn’t stopped the “3rd gen best gen” either. (of course pros, cons I know)
  21. May 21, 2025 at 4:07 AM
    #441
    NoDak
    NoDak New Member
    JR
    North Dakota
    mostly the tank size for any toyota model is roughly determined by what range target toyota is trying to hit for a model (also to add from the post above about simplicity within a model and manufacturing one tank instead of 2-3 types for a model like they did before)
    typically toyota likes to get between 400-600 miles range on a tank.
    i think the lowest is the corolla in the mid 400's and the camry is like mid 600's (just remember its dependent on a trim within a model)
    most BoF i think are in the 500 range while unibodies vary wildly
  22. May 21, 2025 at 5:16 AM
    #442
    Toyota wants to upsell the GX which they are making very few of and aren’t available to purchase? That makes no sense.
  23. May 21, 2025 at 7:21 AM
    #443
    I wrote: “If Toyota could get us all to buy a GX or LX instead of any of the others, I bet they would try.”
    They realistically cannot do that. They still need the volume of less-expensive models and their current production mix reflects this reality.
    If you were reasonably certain you could make thousands more per unit made in your factory and still sell every one, wouldn’t you try?
    When supply constraints were hitting hard in 2020-2022, many base trims disappeared or were harder to find across the board. (Honda got rid of the base LX trim, brought it back in ‘23, then canned it again, etc.)
    Combine that with automakers pairing that with striving to move up-market, selling to the richest is currently a solid business strategy.
    See: Mazda’s shift to being more premium and Bentley breaking sales records in 2020.
    I don’t expect there to be as many 4Runner SR5’s on lots compared to pre-2020 for this reason, especially with MSRP set thousands below the TRD Sport.
  24. May 21, 2025 at 7:55 AM
    #444
    :rolleyes:
  25. May 21, 2025 at 8:04 AM
    #445
    o_O
  26. May 21, 2025 at 11:36 AM
    #446
    FourBelugas
    23 white ORP
    It's amazing what mental gymastics people will come with instead of just considering the possibility that Toyota doesn't care since there is no shortage of "muh first 4Runner EVAH so happy to join the fam!!!" buyers who will buy anything with the name "4Runner" on it.
  27. May 21, 2025 at 11:48 AM
    #447
    Archer
    Archer New Member
    2025 Ice Cap 4 Runner TRD Pro
    Tell us you don't like the new 4 runner without telling us you don't like the new 4 runner. Geeez
  28. May 21, 2025 at 11:50 AM
    #448
    Hopefully when the well runs dry of 4Runner newbies and they start piling up on the dealer lots like the Tacomas and LCs are Toyota does a refresh and fixes a lot of these dumb flaws.
  29. May 21, 2025 at 12:35 PM
    #449
    FourBelugas
    23 white ORP
    Tell me you spent new LC200 money on a 4Runner without telling me your spent new LC200 money on a 4Runner. LOL.
  30. May 21, 2025 at 12:37 PM
    #450
    FourBelugas
    23 white ORP
    Never under-estimate the sheer volume of people used to monthly payments on everything to add one more monthly payment financing their way to exude a "stealth wealth" look. Some people's entire personality is tied up in their whip.
