Saw My First 6th Gen In Person
Discussion in '6th Gen 4Runners (2025+)' started by Rick G., Mar 15, 2025.
  1. May 13, 2025 at 7:25 PM
    #331
    FourBelugas
    FourBelugas New Member
    23 white ORP
    Another feature aimed at commuters so they can save another few gallons a year over 20-30k miles. On a 4Runner.
    https://www.usatoday.com/story/tech/2013/11/19/reviewed-car-tech-efficiency/3637645/
    djwantke[QUOTED] likes this.
  2. May 14, 2025 at 4:42 AM
    #332
    banjos-n-beer
    banjos-n-beer New Member
    Steve
    Maine
    2018 Pro
    I don’t think it’s really supposed to be looked at from a single driver perspective. It’s the aggregate reduction in pollutants and fuel consumption that the company can tout for marketing purposes and used for calculating fleet averages.
    icebear and Thatbassguy like this.
  3. May 14, 2025 at 5:00 AM
    #333
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    Ram sells about half a million trucks per year. So 500,000 * 3.6 gallons =1,800,000 gallons of gas saved per year. Extrapolate that over all automobiles sold in the US each year and that number gets much, much greater.
    It’s just an instance where percentages look small while the actual total can be quite meaningful.
    At least that’s how I view it. But at some point all that complexity comes with a cost elsewhere.
  4. May 14, 2025 at 7:14 AM
    #334
    Even though those numbers seem big when compared to the 100s of billions of gasoline that the US uses per year it’s really not much at all. Also some of these fuel saving features like the active grille shutters may use more energy to manufacture than they even save.
    semprenissart likes this.
  5. May 14, 2025 at 7:24 AM
    #335
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    This is what I mean when I say these features weren’t necessary they sold out to the mob.
    *when I called Toyota a sell out about this before, folks got their back up and said that’s not what selling out means. But that’s something a fellow sell out would say :p
  6. May 14, 2025 at 7:29 AM
    #336
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    Fair point. Production to end of vehicle life usage analysis would need to be done to know for sure.
    And even though I am wary of things like active grill shutters, they are far less complicated than say cylinder deactivation which probably nets about the same relatively small savings percentages.
  7. May 14, 2025 at 7:54 AM
    #337
    FourBelugas
    23 white ORP
    The sheer absurdity of it all is such that, all that complexity is done so people can get 21mpg instead of 20mpg to drive their 50-80k SUVs or trucks to work, when 40-50 mpg cars are readily available from Toyota for under 25k.
  8. May 14, 2025 at 7:57 AM
    #338
    I'm still trying to figure out how Toyota doing what they need to do to make their vehicles meet Cafe requirements makes them a sellout.
  9. May 14, 2025 at 8:08 AM
    #339
    I’m implying the mob is Cafe requirements and the like
  10. May 14, 2025 at 8:08 AM
    #340
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    Agree 100%. I can understand wanting an SUV or CUV for ease of entry and egress, but the number of people commuting to work in full size land yachts or heavy duty pickups boggles my mind.
    “Bigger is better” advertising works well on Americans, despite the negative monetary impact on their finances.
  11. May 14, 2025 at 8:08 AM
    #341
    True. If every suburban dad didn't need a full size truck to commute to his desk job every day, we could probably save a lot more fuel and resources.
  12. May 14, 2025 at 8:09 AM
    #342
    The car companies don't create these requirements. The government does.
  13. May 14, 2025 at 8:15 AM
    #343
  14. May 14, 2025 at 8:18 AM
    #344
    It’s become too expensive to own and insure multiple vehicles so if you need a truck or suv for your hobbies then that’s what you are driving to work too.
    icebear, gkomo and Thatbassguy like this.
  15. May 14, 2025 at 8:23 AM
    #345
    Good point
  16. May 14, 2025 at 8:26 AM
    #346
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    I think most people like the idea of hobbies, but in reality use those vehicles once or twice a year for those intended purposes. But they still buy them nonetheless.
    Forums like this skew that statement but represent only a small percentage of overall buyers.
  17. May 14, 2025 at 8:41 AM
    #347
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    My next-door neighbor is the perfect example. He’s a single guy who has been renting the house for eight years now. He drives a full size Ram pick up truck with a hemi V8. He never tows anything, never goes off Roading, and never uses the bed for anything.
    In reality, he’d be much better served with a Toyota Corolla or a Honda Civic. But it just doesn’t provide the image that he wants to project. But it’s his money.
    FourBelugas and Thatbassguy like this.
  18. May 14, 2025 at 8:47 AM
    #348
    right
    It’s a race to the bottom all in the name of MPG i’m just saying, I don’t think it’s necessary to sell the 4R
  19. May 14, 2025 at 8:49 AM
    #349
    FourBelugas
    23 white ORP
    Driving a heavy truck or SUV daily just for a hobby seems...expensive too. Depreciation is a real thing with rapidly accumulating miles on high dollar hobby vehicles. 15k miles a year adds up quick after a few years in depreciation, gas, maintenance, wear items, etc.
  20. May 14, 2025 at 9:06 AM
    #350
    The insurance alone on a commuter car pretty much cancels out any savings on fuel.
  21. May 14, 2025 at 9:13 AM
    #351
    Bishop_Sweetwater
    Bishop_Sweetwater New Member
    Bishop
    2023 White TRD Pro
    In reality, we can fall prey to the "next-door neighbor" syndrome referenced earlier. Or what I would say is captured early in the movie FIGHT CLUB when the main character has a discussion with Tyler Durden about consumerism and what of his stuff best defines him as a man. Each individual has to evaluate based on a variety of factors such as preference, practicality and price... to name a few. But at the end of the day is anyone is getting value out of gear, vehicles and the like it will be an endless pursuit to satisfy with no end in sight.
    TRD Jon says in that review that the Honda Passport is good for 90% of buyers - that is a high number but since I test drove one last week I can say that is probably true. The local Honda dealer had a 2025 4R SR5 that was preordered and then after only 100 miles the owner came in an immediately traded it for the Passport, and the same was true of a 2025 Land Cruiser on the lot. So there is some traction with rugged cross-over vehicles. And it has the vibe of a Honda Element and Pilot - both of which I liked - so the fact I can store my MTB and gravel bikes inside is a huge win. I traveled to WV (Canaan Valley and Dolly Sods) to ride and it poured for three days straight - so to have had the option to store my MTB upright inside would have been nice.
    I really enjoy my 2023 4Runner, but cannot deny that the Honda Passport have way more room to haul kids, dogs and gear for me locally in Western PA. I am also making this evaluation base on what could be best for excursions such as ski slope pickup, car camping (way more room in the passport with seats folded down), MTB hauling, and entry and exit for aging family members (the 4R is no bueno on that). I'm not there yet in terms of parting with my 4R, but can easily see the appeal for many buyers...
    2Toys likes this.
  22. May 14, 2025 at 9:27 AM
    #352
    It seems like Honda put a lot more effort into the use ability of their vehicle versus just trying to make it look cool like Toyota did.
  23. May 14, 2025 at 11:10 AM
    #353
    Jennyjo14
    Jennyjo14 New Member
    Jennifer
    None
    Jesus. I bought my beach house for $80K in 2013.
  24. May 14, 2025 at 11:30 AM
    #354
    Jennyjo14
    Jennifer
    None
    Seeing a lot more of these in my area than 2025 4Runners. Not sure how I feel about them so far.
    No regrets in buying the 2024 4Runner.
  25. May 14, 2025 at 11:47 AM
    #355
    I have a friend that ordered an F250 diesel back in 2016 with no trailer hitch. He lived in an apartment and was a single guy at the time. He ordered it without a trailer hitch to save money and when i questioned him about it he said
    "i aint ever gone tow a trailer so i figured i'd save money ordering it without it"
    He wanted the truck to look big, he has since owned about 5 or 6 of them, he normally keeps them about two years and trades out for a new one. Its all about the image for him, not the functionality or fuel mileage.
    He now has a house, a kid, a wife, and still has an F250. He works for the gubbamint and sits at a desk all day. It wont ever have a shovel in the bed or a tool box full of tools.
  26. May 14, 2025 at 12:37 PM
    #356
    FourBelugas
    23 white ORP
    Unless you are a terrible driver, adding an economical sedan or small crossover is very cheap for a person with existing policy on something like a 4Runner. Ours was like an extra 70 dollars a month for our 2025 sedan.
    If I was driving 15k a year, gas along would save me more than 2-3 times the cost of the insurance and registration of a brand new small car. Then we have paying extra for the AT tires(can't have all seasons now can we) tires on a truck or SUV, the brakes, transmission service, diff service,transfer case service, driveline parts, what have you. Everything on a BOF Offroad oriented SUV costs a lot more per mile than a vehicle optimized for highway efficiency, that's just the way it is.
    Then the depreciation, 100k on a 25k sedan depreciates it far less than 100k on a 70k 4Runner. I bet 100k miles on a 4Runner costs the owner about as much as a whole economy car on depreciation alone.
    compare the 5 year cost to own between a 2024 4runner
    https://www.edmunds.com/toyota/4runner/2024/cost-to-own/
    and a say, corolla hybrid
    The cost of ownership is a whopping 26k more with a 4runner if owner drives it 15k miles a year, with fuel being a 3x multiple on the 4R. The difference for 6th gen will be even bigger with most trims being 10-15k more now to purchase compared to the previous gen. 26k is coincidentally the price of a Corolla hybrid. Adding a small car will further increase the gap since additional cars don't incur as much insurance cost per vehicle as the first one.
  27. May 14, 2025 at 12:46 PM
    #357
    Can you imagine what the people who drive Mercedes and Cadillac think when they buy a new vehicle and trade it in 4 years later and have lost 60% of the sticker price. Its absolutely nuts how fast the standard line of BMW, Mercedes, and Cadillac depreciate.
    Example, a 2021 Mercedes S 580 was $115-$120K depending on options
    That vehicle with 35,000 miles is currently worth $63,000
    That vehicle has depreciated a whole new 4runner in 4 years.
    Example, a 2020 Cadillac CT6 was $60-$75k depending on options
    That vehicle with 70,000 miles is currently worth $32,000
    That vehicle has depreciated a whole upper trim level Rav4 in 5 years.
  28. May 14, 2025 at 12:50 PM
    #358
    FourBelugas
    23 white ORP
    Yep, even with residual value champs like Tacos and 4Runners, 100k miles on the clock makes a huge dent in the value of the car. 40% depreciation on a Camry sounds bad but it's only 10k. 30% on a 65k 4runner(which is common now) is almost 20k. All for what? Go to Moab once every two years? camping trips? I say people should buy whatever they want but at the same time, driving that 4R for commuting 15-30k a year makes my head hurt from running the operating cost per mile times annual mileage in my head, to me it is bizarre to spend 10-20k a year on commuting by most of the buyers who can't even pay cash for their car. IRS per mile rate is now 70cents a mile.
    In most populated states a person making 100k a year takes home about 63k a year if the person maxes out the 401k contribution. So up to 1/3 of the take home pay is used just for commuting on one vehicle, in perpetuity, before the cost of paying the note. Yikes.
  29. May 14, 2025 at 1:16 PM
    #359
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    The people buying the German cars are mostly leasing. Not sure about Caddy’s.
  30. May 14, 2025 at 1:18 PM
    #360
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    And my insurance wasn’t that much higher when I had multiple vehicles. Essentially because you prorate your yearly total mileage across how ever many vehicles you are covering.
