Saw My First 6th Gen In Person
Discussion in '6th Gen 4Runners (2025+)' started by Rick G., Mar 15, 2025.
  1. May 12, 2025 at 4:54 PM
    #301
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Happy man, life goes to plan
  2. May 12, 2025 at 5:44 PM
    #302
    Impractical buy
    Impractical buy New Member
    Windy City (ish)
    2015 Limited
    I saw this one today,
    And when I saw the back window, I thought of this right away.
    AmericanGI likes this.
  3. May 12, 2025 at 5:59 PM
    #303
    FourBelugas
    FourBelugas New Member
    23 white ORP
    Bro you are firing on all cylinders.
    If there was just the 6th gen and the GX/LC250 didn't exist, we would be more inclined to say "oh well, it's all the fat lady brought and sang". But having the 1958 edition LC250 consistently available down the isle for 4-5k discount into the mid 50k range makes the 6th gen 4R a rather awkward proposition.
  4. May 12, 2025 at 7:36 PM
    #304
    Sitting in a new 6th gen, it feels tighter even though its only -1.5" narrower inside
    BIG problem is the center console. What happened to it? I have not seen a single person say a single thing about the center console yet but holy crap its half the size of a shoebox. Its like a toddler shoe box. Its like 8" x 8" x 5" deep. The center console has gotta be like 11" down to the floorboard but they only made it like 5" deep.
    Also the plastic fake molle panels all over the place, in every door, on the sides of the center console, its not my style at all. The big oh'chit handle on the side of the console and shifter. Sitting in the passengers seat is utter chit for anyone with long legs, the glove box hangs way down and way back, wayyyyy too close to the passenger. Also when you open it the door swings down toward you so its basically laying on your legs like a freakin movie table when you open it. Good thing cause if you let it droop all your crap in your glove box is rolling out on the floor. Its weird and hard for me to love the interior.
    I have a white limited coming into the dealer later this week i plan to be there when it gets unloaded and check it out. The pictures online make the Limited interior look bangin and i am hoping the nicer seats will make me forget everything i dislike about the interior including the lack of headroom and tiny sunroof. How come nobody else has said anyting about the sunroof? Its half the size of a normal sunroof. I had a bigger pop-up sunroof in my 1989 pickup back in 1998-1999. The sunroof is absolutely tiny PLUS the headroom is cut into like 5" because of it. They coulda made the thing pop up and slide back and out under the roof rack and kept the headroom but man they robbed you big time. I am 5' 9" and my head hits the ceiling in the rear seat sitting up normal. I have to recline the seats to keep my head off the headliner in the back seat. Thats absolutely nuts.
  5. May 12, 2025 at 8:35 PM
    #305
    so weird looking, I’m sorry.
    my goodness look at this fender, in Canada a branch is 100% going in there
    2Toys and Turd Ferguson like this.
  6. May 13, 2025 at 6:57 AM
    #306
    Archer
    Archer New Member
    2025 Ice Cap 4 Runner TRD Pro
    What a bunch of haters, every new model is worse than the last until it isn't... I absolutely love mine...
    There's a few hiccups but they'll get them straightened out. There's only 2 things I don't like so far, the spare tire location, which can be fixed with a tire carrier and this huge steering wheel, which I feel is what makes the interior feel small...
    AmericanGI, Lc200 and ChessGuy like this.
  7. May 13, 2025 at 7:54 AM
    #307
    4runningMan
    4runningMan New Member
    New Mexico
    The steering wheel is huge?? Photos?
  8. May 13, 2025 at 8:58 AM
    #308
    The interior feels small cause it is smaller than the 5th gen. Its almost exactly 2" narrower inside. This seems like peanuts on paper but you can feel it when you sit in it.
    I also think the roof height is lower, or the seats are higher. My 4th gen with sunroof has more headroom than the 6th gen.
    FourBelugas and Turd Ferguson like this.
  9. May 13, 2025 at 10:30 AM
    #309
    FourBelugas
    23 white ORP
    LOL I see you are a first time 4Runner buyer signing up for somewhere in the neighborhood of 75-80k plus tax and markup, welcome to the neighborhood. I would be pissed too if I spent that kind of money on a 4Runner and don't get automatic fawning and praise like so many other circle jerk forums and facebook groups that worship big spenders.
    Turd Ferguson likes this.
  10. May 13, 2025 at 10:44 AM
    #310
    Archer
    Archer New Member
    Why so butt hurt? I'm not pissed at all, in fact I'm ecstatic with my new purchase.
    icebear, Lc200 and Daddykool like this.
  11. May 13, 2025 at 10:47 AM
    #311
    FourBelugas
    23 white ORP
    yes yes, happy noobs go around calling everyone else haters. Sure. LOL. Maybe you should stick to FB and Instagram for more likes and positive affirmations for your 80k score.
    Jennyjo14 likes this.
  12. May 13, 2025 at 11:07 AM
    #312
    Archer
    Archer New Member
    You want to get a room or something, kinda weird fascination with me or I guess anyone who buys a new truck???
    BTW, Don't have FB, nor Instagram or any other social media
    but hey man, you do you.
  13. May 13, 2025 at 11:21 AM
    #313
    Is there a purpose of those holes other than some designer thought they looked cool?
    FourBelugas likes this.
  14. May 13, 2025 at 11:40 AM
    #314
    FourBelugas
    23 white ORP
    Oh look who's, what was it, "butt hurt", now? LOL.
  15. May 13, 2025 at 11:42 AM
    #315
    FourBelugas
    23 white ORP
    Yeah I when I sat in one I felt cramped to compared to my 5th gen.
    I'm about medium height and medium weight so I can't speak for taller and more, uh, husky, people but if I felt cramped, it ain't good, and I fit fine in a 4th gen camry which weren't the most spacious car around, and I fall into 5th gen Camrys. Maybe I just lost weight. LOL.
  16. May 13, 2025 at 11:43 AM
    #316
    FourBelugas
    23 white ORP
    It got at least one new buyer here to pay J200 money for a 4Runner. So I guess it worked?
  17. May 13, 2025 at 1:26 PM
    #317
    banjos-n-beer
    banjos-n-beer New Member
    Steve
    Maine
    2018 Pro
    Side Air Curtains. They help with aerodynamics.
    djwantke likes this.
  18. May 13, 2025 at 1:38 PM
    #318
    I’d like to know the answer to that as well, because it’s an abomination
  19. May 13, 2025 at 1:39 PM
    #319
    kolter45
    Denver
    Inferno Pro & BRM Sport
    Dude that curved glass was a pain in the ass to replace!!!
  20. May 13, 2025 at 1:44 PM
    #320
    I just can’t get past the air dam, and the side air curtain.. regulations and pressure so I hear
  21. May 13, 2025 at 1:55 PM
    #321
    banjos-n-beer
    Steve
    Maine
    2018 Pro
  22. May 13, 2025 at 1:59 PM
    #322
    Getting rid of the air dam is a 5 minute job. Not sure if you can do anything about the speed holes, though.
    AmericanGI and icebear like this.
  23. May 13, 2025 at 2:05 PM
    #323
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    The side air curtains don’t bother me as much as active grill shutters. At least the curtains are fixed pieces. Agree about the ugly air dam.
  24. May 13, 2025 at 5:38 PM
    #324
    What’s the active grill shutters?
  25. May 13, 2025 at 5:45 PM
    #325
    Theoretically, a good thing. Controlling airflow through the radiator and engine bay. Ideally, it should make the engine operate more efficiently. But, we'll see how it works in the real world.
  26. May 13, 2025 at 5:54 PM
    #326
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    One more thing to break.
    Turd Ferguson and Thatbassguy like this.
  27. May 13, 2025 at 6:25 PM
    #327
    2020 Venture / 2017 Tacoma
    This should be your first mod. MSPFTH-TP_1_4f4b880a-e8f7-4fa4-b43c-f0b105c7fd58.jpg
  28. May 13, 2025 at 6:40 PM
    #328
    Maybe toyota will offer the LC250 in non-hybrid in a few years? If they do, I’m going to seriously think about it as a future replacement for our 2018 Highlander….
    Not that the Highlander will actually need replacing anytime soon, has way less miles than my 4runner and still looks/functions brand new. But it does have an annoying ride…. I don’t drive it often, but when I do the ride either makes me irritable, or I’m overwhelmed with meh.
    What can I say, I’ve really taken a liking to body-on-frame road feel. Just something about how my 4runner moves, the soft jigging on certain surfaces, how it pitches and leans, the steering feel. It’s constantly moving but it’s not harsh. There’s no good reason to like those things on their own, but on my favorite back roads it’s just a perfect combo of comfy and unsettled that keeps it interesting. If the new 4runner/Land Cruiser architecture keeps those ride dynamics, I might just start pushing for a non-hybrid LC250 before the Highlander’s natural death. Toyota just needs to be brave and give customers some options!
    As far as people buying the new 4runners, I definitely don’t begrudge them. The main differences between it and the LC are mostly packaging and cosmetics (and available options). If you fit well in it, don’t mind the size, and like the styling, I say go for it. Sure it’s expensive, but c’mon, people are paying 80-90 grand for pick up
    Trucks and grand cherokees/wagoneers. I mean, it’s neae 100k for some of these jeeps! That’s nuts when you consider most will last 5 or 6 years before you have go dump them. People also buy new BMWs, which boggles the mind even if you hate money!
    2Toys and FourBelugas[QUOTED] like this.
  29. May 13, 2025 at 7:15 PM
    #329
    FourBelugas
    23 white ORP
    In another thread something got me thinking. If I was someone who wants one thats a jack of all trades, with the lower trim LC250 regularly now being able to be had for less than TRD Sport 4Rs, just the full time 4WD alone is worth it over the 4R where only the limited has it, never mind the exterior. If they offered it with a gas only powetrain, I would certainly consider one.
  30. May 13, 2025 at 7:23 PM
    #330
    I don’t think any of this stuff is doing much as they aren’t getting too great of gas mileage compared to the last generation.
