Saw My First 6th Gen In Person
Discussion in '6th Gen 4Runners (2025+)' started by Rick G., Mar 15, 2025.
  1. May 7, 2025 at 2:49 PM
    #271
    FourBelugas
    FourBelugas New Member
    23 white ORP
    Holup... Someone bought it and traded it in after only 800 miles, or is it like a demo/loaner car from a dealership? Frankly if I was looking at it I don't know which is more preferable....
    In any case, 54k for a pre-owned Sport....yikes....
  2. May 7, 2025 at 2:54 PM
    #272
    Hagerty's Drivers Club magazine has a nice write up.IMG_1532.jpgTook them 16 years to make!
    317 lb-ft of torque which peaks at 1700rpm?
    Wait the Hybrid has 465 lb-ft of torque?
    AmericanGI likes this.
  3. May 7, 2025 at 3:06 PM
    #273
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Yeah the combined torque figures are impressive...
    But I'd give the a couple years to work the kinks out personally.
  4. May 7, 2025 at 3:14 PM
    #274
    This writer is awesome. Makes me think I can just slide over and pic one up.
  5. May 8, 2025 at 8:08 PM
    #275
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    @FourBelugas
    My point exactly, look at this rad limited 4th Gen just came across. I’d take that over a 6th
  6. May 9, 2025 at 2:00 PM
    #276
    LastRide
    LastRide New Member
    2024 Limited - Classic Silver
    I really, really hate those wheels. The 5th gen ORP wheels (which I have on my 2024 Limited) aren't the best looking wheels ever, but those 6th gen wheels are horrible IMO.
  7. May 9, 2025 at 3:16 PM
    #277
    banjos-n-beer
    banjos-n-beer New Member
    Steve
    Maine
    2018 Pro
    I saw a “25 TRD Sport pass by me from the oncoming direction. At first I wasn’t sure if it was a Tacoma or 4Runner. It resembles a 4Runner but wasn’t overly exciting.
    I missed out on a sweet 3rd gen today by one buyer ahead of me. That got me excited.
  8. May 9, 2025 at 3:24 PM
    #278
    FourBelugas
    23 white ORP
    For at least 55k plus tax judging by the going rate of the TRD Sports in my area, the buyer will be too pro-occupied with the monthly payment to worry about the wheels.
  9. May 10, 2025 at 12:09 AM
    #279
    TeslasBigCarbonFootprint
    2014 Neglected by the previous owners 2020 is an abused former rental... 2023 New
    The poseur-mobile folks will afford it somehow. Skipping a few oil changes and regular maintenance should help.
    I drove by Toyota Escondido this evening... A sea of Tonka-faced trucks made with Lego sets... Except for one... A Land Cruiser. A tool amongst toys, a model amongst street meat and a Les Paul amongst kazoos.
    Eh, nevermind, it's probably got that shitty powertrain...
  10. May 10, 2025 at 2:46 AM
    #280
    FourBelugas
    23 white ORP
    The LC250 is a handsome vehicle, no doubt about it, I like it much better than how Toyota "updated" the 4runner. The powertrain is what it is. If people buy them then Toyota is happy. If people don't buy them then they will pull the plug again and blame it on Americans not wanting Land Cruisers like they did last go around with the J200.
  11. May 10, 2025 at 3:15 AM
    #281
    Jennyjo14
    Jennyjo14 New Member
    Jennifer
    None
    The last good-looking Land Cruiser was in 2021. Used ones in my area are selling for $55-78K.
    Lc200 likes this.
  12. May 10, 2025 at 7:02 AM
    #282
  13. May 10, 2025 at 7:57 AM
    #283
    balong48
    balong48 New Member
    Indiana
    2011 Silver 4Runner Limited
    That’s inline with the platinum I saw at the auto show. I was hoping that was just because it was preproduction, but now looks to be a product of the hybrid battery weight.
    It’s ridiculous
  14. May 10, 2025 at 9:06 AM
    #284
    Hauling that heavy ass battery around just to give some extra torque seems like a really dumb idea. It really sucks that the LC only comes that way.
    semprenissart and Thatbassguy like this.
  15. May 10, 2025 at 9:38 AM
    #285
    Yeah. If the purpose is power, the reduced payload makes it pretty pointless.
    Based on the overall reaction to the new 4Runner, maybe Toyota should just discontinue it and offer the LC250 in a non-hybrid trim, with a manual transmission option. I don't know how well it would actually sell. But, I'm sure it would be appealing to some of the members here
  16. May 10, 2025 at 9:50 AM
    #286
    If you havent already seen one, wait till you come around a corner and see a new well equipped Lexus GX550 with color matched plastics turning a corner or sitting in a parking lot. They are SHARP looking in comparison to the 4R and LC. Its crazy its almost the same thing just a differently sculpted body. Its way more manly than the LC even though the basic outer shell is almost the same. The proportions and lines are crazy close, the fenders are so close i would venture to say they are almost identical.
    https://youtu.be/1WNkh5WHMr8
  17. May 10, 2025 at 9:54 AM
    #287
    balong48
    balong48 New Member
    Indiana
    I’d take a non-hybrid LC250 over a 6th gen non-hybrid for sure. Only thing I’d miss is the rear roll down window.
  18. May 10, 2025 at 10:14 AM
    #288
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    I think that's how it is in Europe. Only available with a diesel engine
  19. May 10, 2025 at 12:56 PM
    #289
    I would take a non hybrid LC over the 4Runner everyday.
  20. May 10, 2025 at 1:02 PM
    #290
    The GX definitely looks better but it’s too expensive for me. I don’t trust the V6 engine either.
  21. May 10, 2025 at 1:41 PM
    #291
    FourBelugas
    23 white ORP
    Trouble with finding one of those is of course, Toyota has been moving at a snail's pace cranking them out even before the recent trade issues. I have yet to see one in person even though in my area GX460s are all over the place.
  22. May 10, 2025 at 2:07 PM
    #292
    I've seen 2 or 3, and they look really nice!
    For me, it's a toss-up between the GX and LC (regarding aesthetics).
  23. May 10, 2025 at 4:07 PM
    #293
    FourBelugas
    23 white ORP
    In Middle East and some SEAsia markets it is also available with the 4 cylinder gas without hybrid.
  24. May 11, 2025 at 12:06 AM
    #294
    gx4604life
    gx4604life New Member
    GX460
    Turbo diesel LC would be awesome!
  25. May 11, 2025 at 1:39 AM
    #295
    I think I agree with you.
    But man is that roll down rear window ever important to me for what ever reason.
    My 4R when I try to convince it I won’t miss the rear window:
  26. May 11, 2025 at 7:51 AM
    #296
    My daughter wanted to go to the LuLu store yesterday so we made the hour+ trip over to the state capitol into the upscale fancy district and i saw two yesterday. An all black with color matching fender flares and tinted windows and it was TITS! It was pouring rain and i couldnt get a picture to show up worth anything. I also saw the gold/green with painted flares lifted on what appeared to be 17s and 35s as well. I caught a trailing pic of the goldish colored one but its not a great pic. I also happened to see a 4th gen Limited with Nightshade 20s pulling one of those muck boats. This is probably some guys duck hunting rig, the basket rack on top is most likely for the big bag of decoys. This was the side of town where everybody is in a Denali or Escalade at the outlet mall, no Cutlass square bodies and Caprices in sight.
  27. May 11, 2025 at 10:13 PM
    #297
    balong48
    balong48 New Member
    Indiana
    Especially now that I’ve discovered what I call the “ultimate mode”. Tilt the sunroof and crack the back window. You get a breeze with no turbulence. It’s wonderful.
    2Toys, Archer and Trail Runnah like this.
  28. May 12, 2025 at 2:45 PM
    #298
    I parked next to a Rock Creek Pathfinder yesterday that had Toyo AT3 tires on it. It looked nice. Much better than the 6th gen. I was trying to convince the wife to get one for her next vehicle when a Grenadier pulls into the lot. She asked what’s that? and then says I want one. :D
  29. May 12, 2025 at 2:54 PM
    #299
    Happy wife - happy life. :D
  30. May 12, 2025 at 4:51 PM
    #300
    I went to the dealer to get some filters and got to see a 4runner and LC250 side to side to side. The 6th gen 4runner hasn’t really grown on me…at all. And it’s annoyingly big on the outside. The styling is just over the top, both interior and exterior. Worst thing is that I don’t think something that trendy is going to age well. Especially for most buyers that will probably be on the “mature” side of life.
    The LC250 on the otherhand, mildly handsome, understated, and unoffensive. The interior design is just right in my eyes, and the cloth seat material is perfect. Call me old, but if I wanted a long term car, I’m ok with all those things. You won’t hate looking at it in 10 years. Well, the exposed plastic cowling plastic makes up like 1/5th of the surface area of the hood area and will look like faded crap in 10 years, but that should be easy enough to paint black if it comes to that .
    But even if I had to replace my 4runner (perish the thought) I don’t think I could stomach the hybrid. But if toyota offered a non-hybrid LC250 with front and center lockers and sway disconnect think I could get honestly excited about the idea! Actually, I’d probably be all over the idea considering the extra height available in the back.
