Roll call...What state are you in?
Discussion in 'General 4Runner Talk' started by Walio4runner, Aug 7, 2025.
  1. Aug 12, 2025 at 8:10 PM
    Tama1968
    Tama1968 New Member
    Florida
    2018 SR5 Premium Magnetic Grey Metallic/2019 SR5 Celestial Silver
    north central Florida is home base. frequently found in Mississippi, South Carolina and South Dakota too, depending on which branch of the family we're harassing20241116_114438.jpg .
  2. Aug 13, 2025 at 5:24 AM
    And here I am hoping New England becomes the 11th province.
  3. Aug 13, 2025 at 5:48 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Dont be foolish my friend :p the USA is a phenomenal country to live and work, google Vancouver cost of living lol
    jwctaco, Steely123 and Thatbassguy like this.
  4. Aug 13, 2025 at 6:04 AM
    You know that you can move to another country if you want to, right?
    2ndGen22re, Toy4X4, djwantke and 2 others like this.
  5. Aug 15, 2025 at 4:10 AM
    jwctaco
    S.W. Michigan
    23’ T4R
    We even have a department that will help you pack your bags :crazy::canada::oldglory::crapstorm:
    MMarch likes this.
  6. Aug 15, 2025 at 6:11 AM
    New Mexico
  7. Aug 15, 2025 at 7:30 AM
    Lilbill
    Lilbill New Member
    Billy
    Louisiana
    2017 black 4runner
    2.5/1.5 daystar lift 1.25” spidertrax spacers 285/75/17s Satin black wrap
    Baton Rouge, Louisiana
  8. Aug 15, 2025 at 5:52 PM
    West Coast, Sierra Mountains
    Central California, from the Pacific to the Sierras!
    Spare Parts, AuSeeker, Toy4X4 and 2 others like this.
  9. Aug 15, 2025 at 6:18 PM
    :toast: :rimshot:
    jwctaco[QUOTED] likes this.
  10. Aug 15, 2025 at 6:29 PM
    Gman2530
    Gman2530 New Member
    2018 SR5 4wd 4Runner
    IMG_5614.jpg Barracho …. :ohsnap::nuclear: Good one!
    State of Flux. SoCal
  11. Aug 15, 2025 at 6:31 PM
    Beautiful shots!!!
  12. Aug 24, 2025 at 5:35 PM
    Sean
    Sean New Member
    Sean
    Mass.
    2020 4 runner SR5 Premium
    NB most might know this location
  13. Aug 24, 2025 at 5:57 PM
    Pentangler
    Pentangler Happy Member
  14. Aug 25, 2025 at 5:55 AM
    4runner184
    4runner184 New Member
    2011 SR5
    Canadian approved. Very nice.
  15. Aug 25, 2025 at 7:05 AM
    Shanky
    Shanky New Member
    Wisconsin>>Arkansas>> Florida>> Alabama>> West Germany>> Florida>> Michigan>> Texas>>Michigan>>New York>>Michigan>> Ohio>>Michigan>> New Mexico>> California>>Florida (now)
  16. Aug 25, 2025 at 12:10 PM
    kolter45
    Denver
    Inferno Pro & BRM Sport
    Virginia & Colorado & OBX
    Sean likes this.
  17. Aug 25, 2025 at 12:45 PM
    02and24
    02and24 New Member
    kevin
    02 sr5, 24TrdPro
  18. Aug 25, 2025 at 1:40 PM
    MMarch
    MMarch If I knew then what I know now…
    Quincy, WA
    2022 TRD Pro
    Washingtonistan, but as soon as interest rates dip a bit we are out of here for the free state of Idaho.
