Rock slider for 1993
Discussion in '2nd Gen 4Runners (1990-1995)' started by marucus, Oct 28, 2020.
  1. Oct 28, 2020 at 4:17 PM
    marucus
    marucus [OP] New Member
    I am looking to buy use or new rock slider
    Anyone interested in selling a pair or know where can I get a new set
    Cheers
  2. Oct 29, 2020 at 12:29 PM
    trlhiker
    trlhiker Lazy Bum
    1992 4Runner SR5 V6 4X4
  3. Oct 30, 2020 at 7:18 PM
    Justthemechanic
    Justthemechanic New Member
    Nevada desert
    94 4Runner SR5, 5 speed, 3.0
    OME 2” lift, BudBuilt armor, RRO sliders, Spartan rear locker
    98T4R likes this.
  4. Oct 18, 2022 at 8:10 AM
    98T4R
    98T4R New Member
    @Justthemechanic I realize this is an old post but just purchased the Rocky-Road sliders for my 98 4runner Limited and was hoping to get some photos of your install. Please, any advise would help a lot. Thanks!!
  5. Oct 18, 2022 at 1:16 PM
    Justthemechanic
    Nevada desert
    There is not a lot of room between the frame and body, my drill would not fit. I had to use a 90 degree drill attachment to drill the holes. RR also provided “self tapping” bolts. The frame is too hard and the bolts would not self tap. So I used a tap to thread the frame. I used washers to fill the gap between the slider and the pinch seam on the bottom of the rocker panel. Good Luck!
    T4runner11 and enjm1021 like this.
  6. Oct 18, 2022 at 5:49 PM
    enjm1021
    enjm1021 New Member
    Eric
    Raton, NM
    2022 TRD Off Road 4R, 2020 Tacoma Dbl Cab & 1987 Toyota Pickup (flatbed)
    may I ask where you bought that 93 or have u had it since new?
  7. Jan 2, 2023 at 8:54 AM
    CheezePlz
    CheezePlz 2nd Gen 91
    Hey man, would you mind giving me some info on your BF A/Ts? I'm nearing the point of needing to make decisions as far as what tire size to put on my 4R. Are those 31s?
    You had posted the link for the new side decals on my thread man, thanks! Yours look great. Did you apply them yourself?
  8. Jan 2, 2023 at 9:27 AM
    Justthemechanic
    Nevada desert
    The tires are 33x10.5, the decals are factory original.
    CheezePlz likes this.
  9. Jan 2, 2023 at 9:48 AM
    CheezePlz
    That paint looks pristine man. Looks like she has been in the garage since new.
    Do you happen to have any full pictures of your 4R man? I'm trying to make decisions about a modest / tasteful lift height and tire combination and you look like you have figured that out. Did you do a lift or just go with the 33's on stock setup?
    Edit: My fault man. Just saw you have a 2 inch lift on there.
  10. Jan 2, 2023 at 10:38 AM
    Justthemechanic
    Nevada desert
    That picture was taken just after my annual pinstripe buff and polish. I am the third owner and I believe it has always been garaged.
    When I bought the truck all 4 shocks were worn out and the rear springs were sagging. I was building it for off road so I went with the Old Man Emu 2” lift kit, 4 shocks, standard rear springs and heavy duty torsion bars. It raised the rear almost 4 inches and I adjusted the front .5” above center. I really like the ride. I started out with the OME standard rear springs. But after adding a sleeping platform, armor, bumper, winch and carrying more camping stuff for overnight trips the weight went up and after 15K miles the rear springs sagged. I recently installed the OME heavy duty rear springs and it leveled it out again and the ride is still good.
    Before with 31’s.
    After new springs with 31’s.
  11. Jan 17, 2023 at 6:50 PM
    93mouse
    93mouse New Member
    R
    1993 SR5 4Runner
    Ive been trying to get a lift for my 93 or at least level the back. How did you get a 2" lift for yours? I cant find anything of that size that fits a 93. On the old man emu site i can only find lifts for a 1st gen 4r.
  12. Jan 18, 2023 at 9:39 AM
    Justthemechanic
    Nevada desert
  13. Oct 2, 2023 at 7:49 AM
    Toyo92
    Toyo92 New Member
    Carlos
    Toyota
    Engine
    where you bought it
