Rock Rails
Discussion in '5th Gen 4Runners (2010-2024)' started by JRome, Oct 10, 2024.
  1. Oct 10, 2024 at 7:30 AM
    JRome
    JRome [OP] New Member
    2024 Toyota 4Runner
    My new 2024 4Runner came with factory installed rock rails. I believe they are made of 2" tubular steel. I'm trying to find a set of detachable steps, so that I don't have to replace the rails. The only steps that are sold in sets of 2 are from N-Fab, but the N-Fab rails they fit are only 1.75" tubular rails. (JPTS32) The N-Fab customer service team tells me that I might have to make a slight modification to get the steps to fit correctly. Any other reasonably priced steps I should be looking into? Will the N-Fab rails fit my rails? Thanks in advance!
  2. Oct 10, 2024 at 7:47 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    I have the factory frame mounted rock rails. N I doubt those will be a direct bolt on.
  3. Oct 10, 2024 at 7:59 AM
    Startrek
    Startrek New Member
    use grinder to make it fit. cardboard template it. easy.
  4. Oct 10, 2024 at 9:43 AM
    KCSilverTEP
    KCSilverTEP New Member
    2016 Silver TEP
    mostly stock for now
    I went down this road a few years ago and yes it is possible to fit those to the OEM rock rails. You will need to grind a fair amount from the step supports and need some washers as the spacing between the supports are not exactly the same. I have not mounted them because the steps do extend out from the body and did not want bang my shins on them in the garage. I can post some photos if it helps
  5. Oct 20, 2024 at 6:19 PM
    Jorgem2
    Jorgem2 New Member
    2024 4runner TRD PRO
    Hello there.
    If you have the Factory Rock rails I can trade you for my 2024 factory predator steps.
    If you are not to far away from South Florida
  6. Oct 20, 2024 at 6:38 PM
    cuse93
    cuse93 Ice Station Zebra
    I spec'd my '24 ORP with the OEM rock rails assuming (incorrectly) that they would also be able to serve as a step. Nope. But they do look good though. I'll probably swap them out at some point for steps because I mostly don't need the protection of the rock rails.... I like GoRhino RB30s.
