Replacement woofer on stock JBL in my gen4
Discussion in '4th Gen 4Runners (2003-2009)' started by Bill 1972, Jan 3, 2020.
  1. Jan 3, 2020 at 12:42 PM
    Bill 1972
    Bill 1972 [OP] New Member
    Bill
    2007 4runner
    I need to find a 2ohm 8" woofer for my 07 4runner w/ JBL factory stereo. Any good $50 woofers that work ?
  2. May 9, 2020 at 9:49 AM
    Johnny 4th Gen.
    Johnny 4th Gen. New Member
    Floriduh!
    My first 4 Runner SR5 Sport
    W.I.P.
    Have you tried adding a 4 Ohm resistor to a 4 Ohm woofer?
    Not sure which side , I'm thinking the positive side to make any 4 Ohm woofer into a 2 Ohm load.
  3. Jun 3, 2020 at 2:35 PM
    zbadboy
    zbadboy New Member
  4. Jun 3, 2020 at 2:58 PM
    Did a quick google search and chose this one was the cheapest. 2ohm must mean it’s a dual voice coil sub.4AD83B07-853B-43B6-8B7C-3E04CAD6BFAE.jpg
  5. Jun 3, 2020 at 3:03 PM
    For $20 more there is a Kicker I like.
  6. Sep 5, 2020 at 7:57 PM
    Ruthven13
    Ruthven13 New Member
    2003 Limited V8
    Link?
  7. Sep 12, 2020 at 6:53 PM
    BottomDwellingT4rLife
    BottomDwellingT4rLife Has an attractive member
    Anthony
    SE Tennessee
    2005 limited V8
  8. Sep 18, 2020 at 12:59 PM
    Anthony
    SE Tennessee
    2005 limited V8
    Little update on the skar audio speaker I posted. Honestly sounds fantastic, mainly for the $35 it was. I’ll do an install video or something here soon because I have to do it to my truck now too. Only difference from the normal removal of the back braces to add depth is I used the grill spacer as a speaker spacer so it is installed before the speaker instead of after.
  9. Sep 28, 2020 at 8:38 PM
    GalacticOwl
    GalacticOwl New Member
    Ryan
    Metro ATL, GA
    2008 Galactic Grey 4Runner Limited 4.7
    3/2 lift on Bilstein 5100 and OME springs 5th gen trail edition wheels Pizza Cutters (255/80r17) Toyo Open Country A/TIII Bolt on sliders BudBuilt stage 1 skid plate system
  10. Sep 29, 2020 at 2:28 PM
    GalacticOwl
    Ryan
    Metro ATL, GA
    BottomDwellingT4rLife likes this.
  11. Sep 29, 2020 at 4:38 PM
    klavender1
    klavender1 New Member
    SC
    2003 4Runner V8 4x4
    I think I'll need to replace mine soon. Any idea the wattage the JBL system is putting out?
    EDIT: Found it by searching TIS. The sub is 1.2 ohms and 65W.
  12. Feb 25, 2021 at 12:42 PM
    kafer56
    kafer56 New Member
    2006 4Runner SE 4WD V8
    Icon Stage 3 Suspension, Total Chaos Arms, Katzkin Leather interior
    @GalacticOwl Did you hook that 8" icker directly to the factory wires and amp? Or did you run a new bigger amp? Also, how does it sound compared to stock?
    Mine just blew out last night and my goal was to replace it with a factory speaker... I am old and it is too loud... lol! But they do not seem to be readily available except for used or aftermarket Chinese.
    Thank you for your help!
  13. Feb 26, 2021 at 6:26 AM
    GalacticOwl
    Ryan
    Metro ATL, GA
    Yeah, it's just running off the factory amp. It defintely sounds better than the factory sub did but I wouldn't say it's any louder.
    kafer56[QUOTED] likes this.
  14. Sep 24, 2021 at 8:12 PM
    BigChungus
    BigChungus New Member
    Benjamin
    2005 sr5 4runner v8 4x4
  15. Sep 28, 2021 at 1:01 AM
    Anthony
    SE Tennessee
    2005 limited V8
    Sorry, haven’t checked in in a while. That speaker worked well. You have to trim stuff in the back of the factory box due to the magnet being bigger but it wasn’t really all that hard. I did this in both my mothers 4runner and my own Although I am not using it anymore. I honestly couldn’t stand the factory amp stuff powering all of the truck. Sounded like garbage compared to a base aftermarket radio. So I rewired all my door speakers and put in an aftermarket head unit. I have to say, the factory jbl speakers sound amazing even compared to aftermarket speakers. Only running the 4 doors(6 speakers) at the moment but I am wired up for my sub. Just been lazy. If anyone is in Chattanooga area and wants that speaker for free just let me know
    Edit: to add, just to inform. You do have to cut the factory wire harness where it connects to the speaker and put regular female speaker adapters on it.
  16. Mar 10, 2022 at 1:45 PM
    quinletc
    quinletc New Member
    2008 SR5
    Is it obvious which wires connect where? If not, can you provide a little help - newbie on wiring car speakers.
  17. Mar 10, 2022 at 3:29 PM
    iamincrediboy
    iamincrediboy New Member
    Central MD
    Page 2 gives the wire colors from the head unit to the speakers.
    If you're asking about the literal connections in the car itself:
    -all 4 door speakers are behind the door trim, youtube is your friend on how to remove
    -the headunit you have to remove the center console and front HVAC trim panel to get behind, again youtube is your friend for videos
    quinletc likes this.
  18. Mar 11, 2022 at 9:46 AM
    quinletc
    quinletc New Member
    2008 SR5
    Sorry, I was not specific enough. When replacing the factory sub on the JBL Synthesis system, with no changes to anything else, how do you wire the new sub?
  19. Mar 11, 2022 at 11:17 AM
    iamincrediboy
    Central MD
  20. Apr 5, 2023 at 8:23 PM
    gkomo
    gkomo New Member
    San Diego, CA
    2004 4Runner Limited V8
    I just picked up a Rockford Fosgate 8" 2ohm shallow woofer. I'm assuming i'll have to cut off the OEM connector and like hard-wire the leads into the new sub? Anyone have some insight into that process?
  21. Mar 28, 2024 at 2:01 PM
    Westy
    Westy New Member
    brenton
    2003 4Runner Sport V8
    How did that Rockford Fosgate sub workout with the stock amp? I'm deciding between the Fosgate and the Pioneer TS-A2000LD2.
  22. Mar 28, 2024 at 5:46 PM
    gkomo
    gkomo New Member
    San Diego, CA
    Works fine, an upgrade from stock for sure but doesn’t thump with the stock amp powering it. I’m definitely happy with the purchase of the RF 8”.
    UFlaw98 likes this.
  23. Mar 29, 2024 at 2:17 PM
    Westy
    Westy New Member
    brenton
    Is the model number the Rockford Fosgate P3SD2-8? In a crutchfield review I read I'l have to modify the subenclosure to make this sub fit. did you encounter any issues with this sub in the stock sub enclosure?
  24. Mar 29, 2024 at 5:40 PM
    gkomo
    gkomo New Member
    San Diego, CA
    I’ll try to find the P/N I purchased, for some reason I can’t find my email confirmation. I did have to modify the mounting holes, basically drill new holes and I had to modify the connector to get it work. All very easy to do. If you get a shallow mount subwoofer it’ll fit in the stock ‘box’ minus the new holes you have to drill for mounting it.
  25. May 5, 2024 at 3:10 PM
    Westy
    Westy New Member
    brenton
    The install was easy and the sub sounds great. The Rockford Fosgate shallow 8" sub was definitely a great option for <$200 and I didn't have to replace the amp to push it.
    UFlaw98 likes this.
