Red's totally awesome 3rd gen
Discussion in '3rd Gen Builds (1996-2002)' started by Large, Nov 27, 2017.
  1. Nov 27, 2017 at 5:30 PM
    Large
    Large [OP] New Member
    Red
    Bought a pretty clean 3rd gen, semi-built for $8k .. I plan to make this my primary rig. I've owned 5 - 2nd gen tacos and always wanted a 3rd or 4th gen runner so I scooped it up.
    Has 160k ~ on the odo, and nothing mechanically wrong.
    Mods:
    Shrockworks sliders
    Shrockworks HC rear
    Shrockworks front
    OME rear lift, around 2" or so
    Needs:
    ARB F&R, has a center diff lock which worked pretty well
    More lights - lighting situation at night is abysmal
    OBA, stainless lines probably
    Going to cut off the jerry can holder on the rear bumper, useless to me
    I want to line-x the whole shebang army green or something, maybe cement color
    Projectors in the headlights
    33s, new wheels with more backspacing
    A proper front lift (on spacers now)
    A winch would help but not 100% necessary right now
    David@Toytec, ruiz4251 and jester243 like this.
  2. Nov 27, 2017 at 5:34 PM
    Large
    Red
    A group and I went to hidden falls adventure park this past weekend, the runner did pretty good for being on 265s.
    Carnage:
    Front CV broke
    Rear tail light
    Front pinion flange on the drive shaft
    Luckily I knew the CVs were in terrible shape so I had some OEM re-manufactures on order.
    This piece was inside the diff on the add side stuck in the sleeve. Removed the sleeve and lined up the splines best I could and 'gently' tapped on the diff with a rock, and it came out.
  3. Nov 28, 2017 at 8:41 AM
    Large
    Red
    For those of you that didn't see this on some form of social media this past weekend, this is the remnants of a 5th gen Pro.
    This was a pretty gnarly obstacle to say the least, the spotter told him to bump it and well he bumped it a little too hard and rolled 1.5 times landing on its side.
    Recovery took about 7 hours, it doesn't look too bad (the angle) in this picture but it's steep and there were lots of huge rocks hindering our recovery. What we decided to end up doing was putting it on its upright position and trying to pull it down, but the problem was the wheels literally melted and it was getting caught on everything on the way down. We rolled it back on its roof and slid it down, I will try to find the vids from this and post them here.
    Once down here we carefully navigated a duramax and a gooseneck through the trail with relative ease, loaded it up and went on about our day.
    Literally almost everything melted except the frame and shell..
    Bob and SnowroxKT like this.
  4. Nov 28, 2017 at 9:09 AM
    jester243
    Dan
    Spokane, WA
  5. Nov 29, 2017 at 5:40 AM
    rooster
    rooster Just trying to make it.
    2016 silver 4runner sr5
    That is insane. Never seen anything like it.
  6. Nov 29, 2017 at 5:50 AM
    Large
    Red
    More carnage.. pinion broke at the flange. I'm only on 32s so this shouldn't happen, buddy thinks the ring gear got in a bind and jammed - when that happened the pinion snapped. Ordered new diffs front and rear, ARBs & 4.56s through ECGS.. should be here in 2 weeks.
    ruiz4251, SnowroxKT and jester243 like this.
  7. Nov 30, 2017 at 7:27 AM
    Large
    Red
    OBA setup ordered, here is a quick reudamentary drawing I did
    I've got a lot of work to do over the xmas holiday. Also have a hot springs trip ORV park trip planned in a couple of weeks which I will report back on.
  8. Dec 3, 2017 at 1:34 PM
    Large
    Red
    OBA system arrived, not sure where I'm going to mount the tank. I want to mound it under where the spare was but I don't want it sticking down. Might just end up mounting it in the back somewhere.
    Quick couplers, fill chuck and ARB deflator arrived as well with some tubing fittings. I wanted to do stainless but it will be at a later date.
  9. Dec 8, 2017 at 4:29 PM
    Large
    Red
    Got some more parts in. Switches, blank banks and my regulator for the ARB manifold
  10. Dec 19, 2017 at 4:15 AM
    Large
    Red
    Went out to Hot Springs off road park this past weekend and had a blast. If you check post #6 you'll see that my front diff was broke and my new ones had not arrived yet from ECGS. My buddy happened to have a spare front diff that he let me use so we swapped it out at the park in the wee early morning. It was about 20 degrees.
    I also swapped out the other bad CV while I was under there, so I had a decent front diff and 2 new OEM cv's (refurb cv's from the dealer that is).
    Custom hood ornament
    And somewhere in there I broke one of my new cv's ... :(
    Put my old crappy one back in and it worked OK ... until I broke the front diff again in the same manner as the previous one. Snapped right at the pinion flange again ... the flange was spinning around flopping and hitting everything, I think somewhere in there it whacked the t-case / tranny kind of hard because I cannot shift in to any gear now. Truck will start fine but not move at all, and there is no resistance when shifting.
    I think the t-case was removed and reinstalled and also mounted incorrectly by the previous owner or something along those lines. I shouldn't break 2 diffs and 4 cv's with 31.5s while I am driving like a grandma. Needless to say the front IFS is going away soon :spy:
  11. Jan 7, 2018 at 5:30 AM
    rustystp
    rustystp New Member
    Rusty
    San Antonio Texas
    2018 TRD 4Runner
    BFG KO2
    New to forum and New 2018 TRD OR. Looking for a place to wheel near San Antonio. And meet other 4R owners to learn mods. Always had Jeeps.
  12. Jan 8, 2018 at 10:49 AM
    brochacho
    brochacho New Member
    2018 Sequoia TRD Sport
    How the hell did it catch on fire??
  13. Jan 16, 2018 at 11:52 AM
    Large
    Red
    Welcome, there's a meet this weekend at wolf caves not too far from you. I won't be able to make it unfortunately - work is in the way of me working on the runner. I have all the parts waiting to be installed but no time :(
    No one knows really, but it originated from under the hood.
    Snorkie and Bob like this.
  14. Jul 13, 2018 at 5:07 AM
    Large
    Red
    Been a while, but I've been busy working the past 5 months or so and haven't had time to do anything. I plan to actually start building it this weekend so I figure I will get some things out of the way. I am installing my switches and going to try and wire them all up. First order of business was to remove the single din so I can add the switch panel:
    Grab your favorite adult beverage and mock up on the panel under the single din. These will be for what I'm calling the 'utilities' of the runner; compressor, train horn, winch and locker switches. The other 6 gang switch will be for lights only. Not sure of all what will be installed but will have rock lights, ditch lights, side marker lights, maybe remove the 2 PIAA's from the front bumper and put some cubes or spots.
    Also started on the plumbing for the OBA and locker manifold, if anyone else is doing something similar make sure you teflon tape THE F out of the fittings. After everything is installed the worst thing is having to go back and find a leak somewhere.
    Manifold with the solenoids mounted, you can also see the 100 psi regulator with a psi gauge on it. Don't want to blow a seal on either of the lockers, and ARB says 100 psi max on them I think.
    Will update more as I go.
    Snorkie and jester243 like this.
  15. Jul 16, 2018 at 1:57 PM
    Large
    Red
    Worked on the runner a bit this weekend, rear is pretty much done and I really want to start the front next weekend hopefully but my schedule will be pretty busy so we will see what happens. Started with the rear lower links - bent the passenger one somewhere, no idea where so ordered some rokmen (sp?) beefy ones, and yeah they are beefy for sure. Looks about twice the diameter and double the weight.
    Passenger side one was a bitch to remove I guess due to the axle shifting, in any case there had to be some maguyver like finagling on the rear axle. With a floor jack and a wedge I got it in there relatively easy.
    Driver's side was the same thing, but went right in.
    Old rear end:
    New rear end:
    Went with ECGS 4.56s (only plan on running 33s) and ARB lockers. Front is next but this South TX heat is murderous for a ginger. I also have no friggin clue where to mount the viair tank, seen plenty of places on T4R but don't like any of them. Trying to decide whether I should scrap the tank for a smaller one, or maybe cut out the back of the runner where the spare was and make a recessed storage tank like SMP fab did on their bandito build. WHAT DO?!
    Snorkie likes this.
  16. Oct 11, 2018 at 7:42 AM
    Large
    Red
    Been a while but been working on this trick on and off when I can.
    Old diff / new diff
    Old diff / new diff
    Also bought a couple of RZRs and getting in to the scene, I love these things. One is a RZR 900S, other is an XP 1000
    Trail repair:
    more fun:
    more fun 2:
    Had someone smash my mirror, this bih was $1,500
    Anyway, the runner rolls now and should be trail ready before the month is up. Will post some updates when I can.
    Snorkie and ruiz4251 like this.
  17. May 16, 2019 at 5:32 AM
    Large
    Red
    So it’s been a while, new-ish 285 KM2s on TRD pro 17s. Viair tank mounted where the spare used to be, plumbing and wiring done, front end all done with new parts, new steering rack, lots of other small bits I’m probably missing.
    OffRoadScott, Snorkie and jester243 like this.
  18. Jun 21, 2019 at 7:59 AM
    Large
    Red
    Scooped up a new hi lift for $40 from a friend.
    I also called addicted offroad and apparently my bumpers will ship out today.
    Not getting my hopes up though.
  19. Jul 22, 2019 at 7:18 AM
    Large
    Red
    Went to Hidden Falls adventure park this past weekend and had a blast. We did about 60 miles of trails, from mild to wild. Unfortunately I didn't get many pics but I will share what I did get.
    So a new guy tagged along with us, he was a pretty good dude. Unfortunately he stuck his arm out of the window and smashed it between his door and a rock wall. Dented in his door even, I don't know how he didn't break it to be honest but he was a good sport about it. Unspoken rule #1, keep hands and feet inside.
    And this is my 6 week old truck, someone decided to put a dent in it and not tell me. Looks like I can just pop it out, I'm sure it will leave a wrinkle though.
    Snorkie and Daria like this.
  20. Aug 7, 2019 at 5:30 AM
    Large
    Red
    Couple more pics of the rear bumper, don't mind the paint job - I just didn't want it to rust.
    The build quality is nice but I was missing bolts and blinkers that I paid extra for.
    Their customer service is terrible.
    Here is my $600 steering rack, been on 2 trips, maybe 800 miles total on the rig and it leaks.
  21. Sep 13, 2019 at 8:03 AM
    Snorkie
    Snorkie New Member
    Chris
    99 4runner 2.7L
    lockers, bumpers, sliders
    You seem kinda cool, you wanna be friends?
  22. May 4, 2020 at 10:43 AM
    Large
    Red
    Small update
