Recovery Points Snatch Strap
Discussion in '5th Gen 4Runners (2010-2024)' started by RiverDog, Jun 28, 2025.
  1. Jun 29, 2025 at 6:12 PM
    I'm just going to add that it is important to buy name brand, rated recovery gear. Not cheap Junk off of Amazon, buy the stuff that the pros use. You may never have to use it, but if you do it could be a matter of life or death.
    Thatbassguy and Captain Spalding like this.
  2. Jun 29, 2025 at 6:26 PM
    @Trail Runnah for those who are new to all this, can you elaborate please?
    What are the reliable name brands that the pros use?
    What about the ratings? For shackles? Straps? Kinetic ropes?
    djwantke likes this.
  3. Jun 29, 2025 at 7:00 PM
    That was debunked in that thread. The rear hoop is sized for recovery. Hell, the front hoops on 4th gen Tacos and 6th gen 4R are the same size and attach the same way, and they're finally advertised by Toyota as recovery points.
  4. Jun 29, 2025 at 7:48 PM
    Beachguy
    2024 TRP ORP
  5. Jun 29, 2025 at 9:23 PM
    I reread the whole thread today. Must have missed the debunking. Can you point me to it please? I only balk at the notion because the construction of the front loops and rear loops are really different.
  6. Jun 29, 2025 at 9:33 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Ya no I agree, if we’re talking about the rear hooks..I don’t care what YouTube or threads say, doesn’t the manual explicitly state do not use rear hooks for recovery (because sure they might work ok, until the time the dont)
  7. Jul 9, 2025 at 4:49 PM
    java
    java phoRunner
    2023 ORP ice cap
    too poor for mods
    The transformation is complete!
    scottiezilla[QUOTED] likes this.
  8. Jul 9, 2025 at 4:56 PM
  9. Jul 9, 2025 at 5:05 PM
    scottiezilla
    scottiezilla New Member
    Bro you never explained the original pic n now the controversy deepens…I’m heading to darkweb
    java[QUOTED] likes this.
  10. Jul 9, 2025 at 5:05 PM
    java
    java phoRunner
    2023 ORP ice cap
    too poor for mods
    lol whats there to explain?
  11. Jul 9, 2025 at 5:10 PM
    scottiezilla
    Ummm hello Mc @java Fly
    the first pic you so casually dropped had the rear window “whitened” n I wanna know how…N WHY?!?!?
    Snow, like the rest of the pic
    Photo play, like the rich n famous
    Or is the plot thicker….
