Rebuilding small block chevy....
Discussion in 'Off-Topic Discussion' started by SR5 Limited, Nov 21, 2019.
  1. Nov 21, 2019 at 8:24 PM
    SR5 Limited [OP] New Member
    I was able to put this bare block in my 4R to deliver to the machine shop for boring .030 over, new cam bearings and freeze plugs. Then the bare block was at the exact height in the back to bolt to the engine stand to complete my build...39E37770-0B93-4E31-A047-9E0CB286E279.jpg
    SlvrSlug likes this.
  2. Nov 21, 2019 at 8:28 PM
    All forged and balanced!!!
  3. Nov 21, 2019 at 8:30 PM
    3.75 Stroke!!
  4. Nov 21, 2019 at 8:32 PM
    30-30 cam & solid lifters would be the shit.
  5. Nov 21, 2019 at 8:36 PM
    Well I put a monster cam in it first (292), with a heavier spring ofcourse. While it was in the car. But, after I lost oil pressure, and I rebuilt it, I noticed the hydraulic roller lifters left groves in the cam at only a few thousand miles. Hence I opted for a baby billet steel cam. And I love it!!! Plenty of power at lower RPM’s...
  6. Nov 23, 2019 at 8:30 AM
    BestGen
    BestGen Member #57
    Paul
    Haunted Turnbull Canyon, CA
    Sounds like a nice build. Are you still running the 292 duration cam? What's the lift on that sucker? I'd imagine at least .600..? What's the rockerarm ratio? Did you go single plane intake or dual-plane? Any pics of this beast?
  7. Nov 23, 2019 at 10:19 AM
    The 292 XFI is the biggest cam you can install without flat tappet lifters. Like I said in my previous post “the hydraulic roller lifters wore groves in the cam lobes”. “So I opted for a baby cam and I love it”, 1.6 roller tip rocker arms, heavy springs...white Bosch 36# injectors with a tune....I have videos.....
  8. Nov 23, 2019 at 10:19 AM
  9. Nov 23, 2019 at 10:20 AM
    Aluminum flywheel.....paired to a Borg Warner six-speed transmission...9F57B5BA-BFE4-48BC-A3C2-42D4755F8D0F.jpg
  10. Nov 23, 2019 at 10:21 AM
    Ready for install, yes I primed the high-pressure oil pump..4D638AB3-8584-406C-AE50-5EA5B162AC16.jpg
  11. Nov 23, 2019 at 10:22 AM
    Out and In from the top!!! With the hood attached....2C2FC8F6-3F0F-408E-9486-D783C297C610.jpg
    Benny123 likes this.
  12. Nov 23, 2019 at 10:33 AM
    It was a fun build. I can go another .010 over and produce 396 cubic inches.....6F076E06-FC7C-4722-82C4-5CD398900253.jpg
    SlvrSlug and TN_FunRunner like this.
  13. Nov 23, 2019 at 2:49 PM
    It’s Speed-Density so no MAF sensor, easier to tune. I have a removable/programmable chip...
  14. Nov 23, 2019 at 2:59 PM
    I have four different air filter/intake tubes. This is my H.A.I. (Hot Air Intake) but it looks good. I’m actually back to stock it pulls air in from the front/right headlight area....
