Rear Wiper Stuck up
Discussion in '4th Gen 4Runners (2003-2009)' started by feanor387, Sep 15, 2020.
  1. Sep 15, 2020 at 3:41 PM
    feanor387
    feanor387 [OP] New Member
    2004 4Runner Sport 4.7L
    I recently found that I could not raise or lower the tailback window. After some messing around I realized I enabled the dreaded window lock. I turned that off and checked that the window would open and close. Right before I turned the motor off I apparently turned the rear wiper on. This left it stuck in full swipe position. The next morning I tried to get it to return to park using the switch and it doesn’t work. I checked the fuse and made sure the switch worked by triggering the washer. Not sure where to go from here. I even folded the blade back incase it sensed it on the glass no luck. Any help would be greatly appreciated.
    Thank you
    Troy
