@Rear Window Molle Panels In Stock
Discussion in '5th Gen 4Runners (2010-2024)' started by jake long15, Aug 4, 2021.
  1. Nov 8, 2023 at 12:57 PM
    jake long15
    jake long15 [OP] Cali Raised LED
    We do not have an exact rating, but we have put over 150lbs with no issues.
  2. Nov 8, 2023 at 7:47 PM
    ljerr2
    ljerr2 New Member
    IOWA
    2023 T4R Pro
    I really like this setup, but wondering based on the install video if the middle shelf can be removed from the 4R without disassembling the shelf itself. IE, can you unbolt it from the side window molle panels and remove it if for some reason you need to haul a taller item? Or would you have to take the shelf itself apart and then unbolt it from the side panels?
  3. Dec 19, 2023 at 11:13 AM
    jake long15
