Rear window control
Discussion in '4th Gen 4Runners (2003-2009)' started by RonT4R, Mar 19, 2019.
  1. Mar 19, 2019 at 4:09 AM
    RonT4R
    RonT4R [OP] New Member
    Ron
    Virginia Beach
    2007 4runner SR5 4WD
    Anyone know how to disable the rear window controls on my Key FOB? Several times I have gotten up in the morning and my back window has been down all night, once when we had a heavy rain. I tried gluing the button so you can't press it but over time it started working again.
  2. Mar 19, 2019 at 8:32 AM
    DGP1961
    DGP1961 New Member
    2018 SR5 Premium
    Don't believe you can keep the fob from controlling them but I could be wrong. You can't just stop what ever it is your doing?? :notsure:
  3. Mar 19, 2019 at 12:12 PM
    RonT4R
    Ron
    Virginia Beach
    Thing is I walk around the house with my keys in my pockets and I have no idea when it happens.
  4. Sep 2, 2020 at 5:24 PM
    wjbzone
    wjbzone New Member
    William
    2006 Blue
    I want to know the same thing. Never used it except by accident. I'm drying out the floor boards right now because the rear window was down last night during a major storm. Didn't know it until this morning. I park on a hill so the water flowed all the way to the front seat floor. I might super glue the button on the FOB.
  5. Sep 3, 2020 at 3:39 AM
    RonT4R
    Ron
    Virginia Beach
    I tried super glue, doesn’t work. Only thing I can think of is buying new key fob housings that does not have the rear window button.
  6. Sep 3, 2020 at 12:34 PM
    V4runner
    V4runner New Member
    Vikash
    2019 Sr5 Premium
    Daystar Leveling Kit
    dealership can disable code on remote. I had them enable mine to open with a push of the button.
  7. Aug 31, 2024 at 6:32 PM
    DDDDDuane
    DDDDDuane New Member
    DDDDDuane
    Brooklyn, NY
    2003 Toyota 4Runner Sport Edition
    I live in Brooklyn, NY . I'm a tradesman and I use a 2003 4Runner to go from job to job...I came out 4 weeks ago on a Monday morning (after not using the 4Runner for 48 hours). The rear window was open and $1000 worth of tools were gone (a crime of opportunity upon finding that rear window open. I checked the rear window when walking away and it was closed). I replaced all my tools and have been trying to park it within visibility from my home windows. I looked at the 4Runner about 1am last night, it was fine and I went to sleep. I awoke about 7 am and looked out the window THE REAR WINDOW WAS OPEN....I ran out of the house panic stricken...everything I replaced was MIRACULOUSLY still there... I think someone else's transmitter is unintentionally opening my rear window.... Any easy way to change the frequency that opens that rear window? Any suggestions would be appreciated...Thanks in advance...
  8. Sep 2, 2024 at 2:41 PM
    RichInKy
    RichInKy New Member
    Rich
    2004 4Runner V8
    I've had it happen on my '04 T4R and our '99 Sienna with the power door. I stopped carrying the keys in my pocket and that solved the problem. When I get home I check the hatch window before going inside and the keys go on the hook and stay there. Part of my getting ready for bed routine is to lock the doors from inside the house where I can see the brake lights flash.
    You might try popping open the fob and see if you can remove the plastic button. If not I'd try putting a thick piece of plastic over it (like the kind they use for blister packaging) and then duct tape over the top of it a few times.
    DDDDDuane likes this.
  9. Sep 12, 2024 at 11:10 AM
    DDDDDuane
    DDDDDuane
    Brooklyn, NY
    Thanks for the input...This has never happened before in the 3 years I've owned this 4runner. I am using a new transmitter and the rear window open button may be more sensitive. I did drop the keys coming into the house both times. That could have triggered this new more sensitive remote...
    RichInKy likes this.
  10. Oct 1, 2024 at 2:38 PM
    Two4Runner
    Two4Runner New Member
    Lance
    4Runner
    On some remotes you can split the case and put tape or something non- conductive between button and contact
  11. Oct 2, 2024 at 6:54 PM
    LOSTR4
    LOSTR4 New Member
    Just a couple
    I upgraded to a DEI/Viper alarm and remote start and I no longer need to worry about that feature...my OEM keys are thrown in a drawer now...problem free for the last 8 years!
