Rear Turn Signal
Discussion in 'Lighting' started by 4utkings62, Mar 10, 2021.
  1. Mar 10, 2021 at 3:36 PM
    4utkings62
    4utkings62 [OP] New Member
    Tony
    2007 Toyota 4Runner Limited
    2007 4Runner LTD=Rear driver side(only) turn signal doesn't work after replacing bulb. Front and rear view mirror signals work ( but flash fast) No corrosion or moisture, and brake and backup lights work.Any ideas? Thanks!
  2. Mar 10, 2021 at 3:43 PM
    jester243
    Dan
    Spokane, WA
    can you check that the replacement bulb is good? do the lights on the other side flash at a normal rate?
  3. Mar 10, 2021 at 3:56 PM
    4utkings62
    Tony
    Tried both new Bosch bulbs (even tried them on the right side) so they are good. Right side flashes at normal speed.
  4. Apr 12, 2021 at 9:02 AM
    iamincrediboy
    iamincrediboy New Member
    South FL
    If your old rear bulbs work but new ones dont, then the bulb is likely the wrong style. Took me 4 sets of turn signal lights for me to get the right one so dont think you're alone.
    As for hyper flashing, its cause your new bulb draws less power than the computer is used to sending back there, so the hyperflash is the error 'notification'. This will fix that, if you decide to continue with anything but OEM https://www.diodedynamics.com/cf18-lm449-led-turn-signal-flasher.html. The relay is under the dash, literally on the backside of the small fuse panel in front of your left knee. Youtube is your friend on how to pull the panel
