Rear shock replacement with OME springs
Discussion in '5th Gen 4Runners (2010-2024)' started by 808stateofmind, Apr 24, 2023.
  1. Apr 24, 2023 at 1:11 PM
    808stateofmind
    808stateofmind [OP] New Member
    Looking for recommendations for replacement rear shocks for my gf's 2015 4runner. The 4runner has bilstein 5100's in the front with OME springs which I think gives 3" of lift? The rear also has OME springs which I think gives 2-3" of lift? When she first got the lift, 5100's were installed in the rear, but she was getting a clunking noise which I assume was because the 5100's didnt have enough travel for the OME springs and lift size. She current has Toytec boss shocks in the rear, but while doing a brake job the other day, I noticed one shock was leaking, so im looking to replace both rears. Looking at Icon 56505 2.0 good for 1-3" of lift or the Fox-980-24-679 2.0 IFP, good for 2-3" of lift as possible replacements. Need to know if either of these will be suitable for OME springs with the amount of lift, or other suggestions of shocks that will work.
  2. Apr 24, 2023 at 4:09 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    I have OME springs, and ICON. Can you start by taking a photo of the spring (sometime's there's a tag still on em), or maybe photo of receipt. If you know the model# of the coils google will tell you it's free height, thickness, and spring rate. Then google and compare to the shock absorber specs !
  3. Apr 24, 2023 at 4:30 PM
    808stateofmind
    Yea, i did see a tag on the spring, so Ill grab a picture. I should have taken the shock out when I was in there to measure it and find a shock that matches. The ones toytec makes now are not the same ones that are on the runner now, they have a sticker that says "BOSS" in big red letters, so thats why i was looking to go for a different brand that will work with the lift.
  4. Apr 24, 2023 at 4:57 PM
    Sure thing, I hear ya good idea. My springs have moved on to a new model# as well, but it's possible to find the old and new #'s but an identical spring. Goodluck
  5. Apr 24, 2023 at 7:28 PM
    808stateofmind
    So looking and the invoice from the lift and sticker on the spring its an OME 2889(sticker say 889x) from what i read they are medium duty coil with around 3" of lift.
    These are the toytec shocks in the rear that im looking to replace. Cant find too much info on them. (Toytec TT-75109)20230424_161139.jpg 20230424_161052.jpg
  6. Apr 24, 2023 at 8:22 PM
    Thanks dude, so some sites have said medium duty, some have said light duty for me. I think I can help a little more. I actually have OME 2884 front springs.
    Regarding 2889 rear springs, OME have about the highest spring rates out there for our trucks. The 2889's are 260lbs/in, stock is closer to 200 lb/in, so you are looking at a 30% increase. Those will also give you a 3" lift in the rear.
    Your rear shock length might be okay though. The 5100s are 2" lift rated but are are just .25" shorter than the OME nitrochargers (60080), so should be able to fit OME coils?
  7. Apr 24, 2023 at 8:31 PM
    Furthermore, I have a 3/2 lift
    3" front
    2" rear
    I little bit of added weight, medium load when loaded. But I run stock load springs since its my wife's daily still, untill I get steel bumpers.
    Important to know what's your armor, and rear constant weight?
    Also what model# are your front springs, OME-884X, 885X, 886X?
  8. Apr 24, 2023 at 8:46 PM
    808stateofmind
    So the front springs are ome 2884 with bilstein 5100. The 4runner is not carrying any extra weight, my gf uses it as a daily driver and we will use it to go to her uncles ranch and off roading to the beach.
    Just trying to make sure that the rear shocks i choose will be sufficient for the amount of lift in the rear. May even go with the toytec aluma 2.0 which says is good for 1-3" of lift and looks to be a newer version of the shocks already on the truck
  9. Apr 24, 2023 at 8:56 PM
  10. May 25, 2024 at 4:24 PM
    Gezushe77
    Gezushe77 New Member
    2018 TRD Off Road
    What did you go with? I just ordered 5100 with OME 2883 springs. After I ordered I decided to look under the truck and saw that I have OME 889x rear coil and 885x front. I bought the car used and didn’t realize it had a lift. Now I’m worried that the 5100 with OME 2884 front will have too much rake.
  11. Jul 10, 2024 at 4:40 PM
    808stateofmind
    Ended up going with the fox shocks. But now im looking into maybe doing eibach springs for the rear. The ride is a little rough in the rear end and I think its ome springs causing it. From what Ive read, 2889 springs are 260ftlbs, and eibachs are 206, so I assume it would be a more comfortable ride
  12. Jul 10, 2024 at 4:45 PM
    Acesandeights
    Acesandeights #34
    2024 ORP
    Generally, shocks (which I call dampers) dampen the ride, while springs provide ride height for a given weight. If you want to soften the ride, yes, springs can make a difference if they are softer, but the part really responsible for ride is the damper. Dampers can be overwhelmed by incorrect springs, but most (I'm going against the grain here) shocks are a one-size-fits-all that aren't tuned for your application. Long story short, I think you got the wrong damper (shock) for your application. Yeah, it might be the right length, but it's not tuned to your application and may be overwhelmed by a "too-heavy" spring.
    How was the ride with the Toytecs?
