Rear main seal help
Discussion in '2nd Gen 4Runners (1990-1995)' started by SR5 turbo, Apr 22, 2021.
  1. Apr 22, 2021 at 9:03 PM
    SR5 turbo
    SR5 turbo [OP] New Member
    1995 white 4runner
    Ok so I need to replace the rear main seal on my 95 4runner sr5 3.0 v6 . I am really just looking for any information about the job maybe some tips and I was curious if it is going to require me to drop the trans as I was told in may not have to depending on the placement of the seal, but I can’t find anything on YouTube about the 3.0 specifically. Any help in much appreciated
  2. Apr 23, 2021 at 3:30 AM
    captsolo
    captsolo New Member
    Tom
    nassau bahamas
    2005 SR5
    You will probably have to drop the transmission. Unless it is a terrible leak, I'd consider leaving it alone. Hire a professional.
    I have a 2005 with 150,000 miles and I got a leak (few drips occasionally) from the RMS area. Two small drops a week on the cardboard in the garage doesn't bother me.
    4runner starts and runs like brand new after 15 years. Never owned a car like this Toyota. Not a speck of rust on the painted body. OEM radiator, WP, exhaust system. Amazing.
    Replaced the evaporator in the cabin and have 100% cold AC again. Evaporator core was $90 at Amazon and was a perfect fit. Had a professional shop do the job at a cost of $800.
    OEM evaporator lasted 4 years and failed. Replacement evap lasted 9 years. Now with a new one for summer.
    Replaced the AC compressor two years ago.
    Amazon.com: Denso 471-1413 New Compressor with Clutch: Automotive (made in China)
    I've never added any additives to the engine in 15 years.
  3. Apr 23, 2021 at 5:09 AM
    bthp223
    bthp223 New Member
    Nevada
    1990 4X4
    There’s a pretty thorough thread on the subject....try searching.
  4. Apr 23, 2021 at 6:27 AM
    D60
    D60 New Member
    You have to pull the trans.
    The seal also lives in what I call a carrier plate which bolts to the engine and seals with RTV -- actually may have been a paper gasket from the factory. Most of what you'll read online will say to not disturb the plate if you don't need to. Thing is, you really don't KNOW if you "need to" 'cause it can be really hard to tell where it's actually leaking.
    I contend that it is absolutely foolish to NOT re-seal the plate while in there and this should in fact simply be considered SOP when doing an RMS job on these engines.
    It is also possible to get a sleeve kit for the crank if the seal has grooved it.
    Now is the time to do your oil pan gasket if you feel that is also leaking.
    Read this before asking more:
    https://www.4runners.com/threads/replacement-engine-rear-main-leak.15537/page-2
    brownersd likes this.
  5. Apr 23, 2021 at 6:44 AM
    D60
    D60 New Member
    Here's what it can look like when you remove that plate. Note paper gasket lower left. Paper gasket lower right. NO gasket on majority of upper radius. And it was NOT stuck to the plate, it was just gone although we found a few pieces floating around back on the block
    Sooooo......that could (and was) causing a huge leak.
  6. Apr 23, 2021 at 11:31 AM
    SR5 turbo
    1995 white 4runner
    Thank you for the information
  7. Apr 26, 2021 at 7:35 AM
    watermelonman122
    watermelonman122 New Member
    Utah
    1994 4Runner SR5 3.4 V6 4wd 5spd
    Here's a picture of the seal carrier plate in my lap. It's a single piece seal and requires the transmission be removed.
    Overlandcharlie likes this.
  8. May 4, 2021 at 3:19 PM
    mjamgb
    mjamgb New Member
    mike
    Son's Gen2
    None yet
    Looks like they updated a prior "scroll and slinger" design with a bolt-on seal.
