Rear bumper corner gap below taillights after bumper reinstall
Discussion in '5th Gen 4Runners (2010-2024)' started by Hwnrunner, Feb 10, 2019.
  1. Feb 10, 2019 at 5:02 PM
    Hwnrunner
    Hwnrunner [OP] New Member
    Hawaii
    2019 4Runner SRS Prem 2wd
    TRD Pro Struts/ Coils, Toytec 1" spacer, Dobinsons C59-505 Springs,TRD Pro Sema Wheels, TRD Pro Lower Valances, Ceramic Tint
    Hi all,
    just added the lower valances to my SR5, bumper removal was a breeze but the reinstall has me confused where the bumper corner meets the body and those 2 tiny little clips/ tabs that click on just below the taillights.
    Does this gap look correct.
    I tried different angles, applying pressure in different spots, put on/ off several times, same result on both sides, anyone know the secret to getting it to click all the way in if this is wrong?
    thank you_copie-0_20190210_134937.jpg _copie-0_20190210_134937.jpg _copie-0_20190210_134943.jpg _copie-0_20190210_135004.jpg
    Strandskov likes this.
  2. Feb 11, 2019 at 7:17 PM
    rsimi72
    rsimi72 New Member
    2017 SR5 Premium - Gray
    I’ve never pulled my bumper so I can’t comment on reassembly, but I took a few pics for comparison if that’s helpful. My gap looks a little bit tighter. I hope somebody with reassembly experience can chime in. It was dark in my garage when I took these pics so they may not be too helpful. Good luck!
  3. Feb 11, 2019 at 7:24 PM
    Hwnrunner
    Hawaii
    Thankyou, that does help. Pretty sure I'm not catching the clip right above the curve.
    Strandskov and rsimi72 like this.
  4. Feb 13, 2019 at 11:01 PM
    silversr5t4r
    silversr5t4r New Member
    Nice bro I did the same to my SR5 and mine doesn’t clip in. Even the front corner doesn’t clip
  5. Feb 14, 2019 at 4:00 AM
    DGP1961
    DGP1961 New Member
    2018 SR5 Premium
    Yeah I can't comment either but you do have an uneven gap. Went used car shopping with a relative last summer and he got a used Honda. It also had a little "tap" on the front bumper which was a little uneven. Dealer kept it a couple days and gave it to the body shop they straightened it out right no clue how though.
  6. Feb 14, 2019 at 9:48 AM
    Hwnrunner
    Hawaii
    The TRD valences are the Silver plastic trim pieces attached to the bumper in my last pic. I had to remove the bumper cover to cut the slits for the valences tabs.
  7. Feb 14, 2019 at 9:51 AM
    Hwnrunner
    Hawaii
    Thx - I didn't have an problems with the front, that went back on pretty easily for me. I've been looking at other TR4's in parking lots, I definitely did not get a full click on the clips. I worked the passenger side into almost flush now but the drivers side wont give in yet and still has a slight bulge. Wondering if taking off the taillight would help massage it in there.
  8. Mar 31, 2019 at 10:26 PM
    Hwnrunner
    Hawaii
    in case any one else also has this gap issue on the rear bumper corners, A member on T4R offered this info up and it works, no more gap. Hope it helps someone here. See post # 7.option 2.
    rsimi72 and Crossfit4Runner like this.
  9. Sep 16, 2022 at 10:21 AM
    EvilHardee
    EvilHardee New Member
    2022 ORP - Classic Silver
    I just had this happen to me and found this thread and link, and it really helped! I don't think the link above shows up for non-members...
    Just wanted to add a photo of the tab in question which got folded in/down, which causes the bulge, for folks in the future doing the same searching. ;) Just need to pull it back out enough for it to slide in above the groove like the rest of the lip/tabs. It's difficult to see this when first facing the issue.
